• Announcements
    • Alan Longmire
Salem Straub
New hammer acquisition, 300 lb. Beaudry!
37 posts in this topic
Well, I had enough of trying to track down hammers, afford them, dicker over price, lose deals from distance and competition... so I contacted my friend Larry Langdon and sure enough, he had a good project hammer to sell me.
It's a #9 Beaudry Champion, the slack belt type, the 300 lb. model.  It needs dies and a sow block.  Overall it's not too badly worn but has a good surface rust coat from sitting idle in  a warehouse in Seattle for decades.  Larry threw in a jackshaft setup including 7.5 hp 1100 RPM 3 phase motor, a big flat pulley he fabricated for it, the right 3-groove sheaves to achieve speed range, and shaft and bearings so putting together the drive tower should be relatively simple.
I got a monster sow block from some old steam hammer with it too, which he'd found and been saving as a starter block to shape a smaller sow for the Beaudry from.  That's the most daunting part of the whole project, it's a lot of metal removal but I have no doubt it'll get done in the end.
I drove over to southern Idaho Memorial Day weekend to get it, 1200 miles round trip and 48.5 hours total.
Here's some pics...
18740205_1379980175411388_13639970732655
18765563_1379980705411335_52803529750031
18740795_1381176278625111_13696298684325
18740306_1381176118625127_11046422098749
18838993_1381176221958450_37164573361864
18700337_1381176108625128_32876317815895
I'll post more when I've made some meaningful progress towards getting it running!
1 person likes this
Nice!  That's a wonderful hammer, very smooth and controllable when set up well.   There is one over on Muary Island, or used to be.  Might have been a 250.
Nice pick-up. Looking forward to seeing the restoration and running of it. I can't wait for the day when I have both the funds and space to hold a hammer or press. Keep us posted.
1 person likes this
This should just be heavy enough to move some metal... :P
'Grats, looking forward to seeing her all done up. You guys in the US definitely have the advantage on items like this.
Congrats Salem, I am eager to see what you make when you get it running :)
Y'know, the Stagmers over at Baltimore Knife and Sword have one of those, a little smaller but the same type.  If you need any help with the setup give Kerry or Matt a holler, it might help things go smoothly.  Nice score!
How cool is that? bet you  will have that up and running in record time.
Chris
As a fellow 300 lb. Beaudry owner let me say congratulations and welcome to the club:)
Here's what I've been up to with this hammer!
I got the brake cleaned out and freed up, loosened.
19113547_1396483763761029_33546942019844
Yesterday I cut the broken adjuster bolt out, and put a new one in for now. Probably go with something less tacky, ultimately.
I reefed on it super hard, sprayed pen oil all over, left overnight.
19225644_1396483160427756_12909615566803
Came out today, and used a mild steel set hammer and sledge to rap upwards on the guide wedge. After a little of that, more reefing on the adjuster, until finally the wedge began to slide up a bit.
19145996_1396483400427732_46190263658703
You can see the rust line where the ram sat in one spot for a long time! Not super deep pitting though.
19145966_1396483673761038_62472311706805
I slapped some scrap together to make a quick "Big Ghetto Wrench" and hauled away on the crank pin nut.
19113759_1396482077094531_44347797183036
And voila! The ram dropped farther in the guides, to bottom dead center, and the main shaft turned fairly easily.
19225031_1396483293761076_11895015838098
Lots more drop with the crankshaft rotated and the ram free.
19145831_1396483753761030_39641837538052
Crankshaft rotated to bottom position. Not hard at all with the brake and ram freed up!
Upon observation earlier, I saw some not totally dried grease hanging at the bottom of the crank bearings on both sides of the frame, leading me to hope that the shaft had not seeped full of water and rusted solid to the bearings over time. Seems like that worked how I'd have wished after all!
19060193_1396483583761047_49748908654557
Now I have to make a 2.5" square (IIRC) driver/wrench to turn the set screws for the spring arm tension adjustment, and break all that free and take it apart so I can remove the ram to polish all of the moving bits up.
More...
One end of the idler/brake linkage pivot shaft. It was well corroded from water getting into the oil holes and down into the babbitt bearings. The linkage was frozen and would not pivot, necessitating the freeing and removal of the old shaft.
19260266_1398717026871036_53348528903589
I finally got the shaft out, it took a lot of Blaster and hammering back and forth on the ends, using a mild steel set hammer to cushion the blow of an 8# sledge. It was rusty enough to be scrapped, but the babbitt itself in the frame will live to fight another day.
19113943_1398717076871031_51712833793728
Linkage yoke removed, and a piece of 1" round cold rolled steel try-fit in for a new shaft. It fits just a little loose, but this is not an area where precision of movement is key. I'll re-babbitt or perhaps bush with bronze later if warranted.
19145943_1398717100204362_30330516236201
More...
The new treadle/brake linkage shaft needed tapered holes for the pins, and neither I or the local machine shop had a taper reamer the right size... so I cut a piece of coil spring, straightened and annealed it, and chucked it up in the lathe to make a tapered "D" style reamer.
19274782_1399303836812355_79035201298149
With a 1 degree taper cut onto the reamer, I milled off half of the diameter and stoned it smoothish.
19149134_1399303713479034_17362477895145
Quench hardened and drawn to a straw temper...
19148961_1399303896812349_76681950681136
Drilled some 19/64" holes and followed up with the tapered "D" style reamer. It cuts nice and smooth!
19149073_1399303806812358_80810253818597
New shaft installed. The brake and treadle are workably linked and operational once more! A problem though with the inboard yoke for the treadle link, is that the pin hole drilled through the casting is not centered with the through shaft. As the hole in the shaft is centered, this creates some misalignment. A taper pin still sorta fits but it may need more attention later.
19146146_1399303980145674_24632762321259
More yet...
I had an old tie bolt... 1" round mild steel, just long enough to make a treadle from. Here I'm roughing the bend in cold using a big piece of RR track as a bending "fork" and a cheater pipe. I then tuned the curve a bit with a 10 lb. sledge over the big sow block.
19149236_1400498263359579_26772580857885
I cut and drilled some 2" x 1/2" bar to fit the treadle pivot dogs, a short one on this side, with the bolt/treadle welded directly on...
19225431_1400498430026229_40520846797999
It makes a nice arc matching the outer circumference of the foot of the frame, and is adjustable in height/angle by the arced slots for the front mounting bolts.
19260650_1400498476692891_64392260687227
My Airco CV300-II Mig over to the left... made short work of solid welds for the round-to-flat joints.
The spring is too wimpy to work by itself, regardless of that I left excess treadle bar running out to the back, which will have a sliding counterweight fit to it. I plan to have both counterweight and spring there.
19149415_1400498443359561_83615338292764
Next I have to get a piece of sheared taper pin out of the bottom linkage yoke inside the frame, and make/install a new one.
More tinkering to relate...
There was weirdness in the lower treadle linkage... found there was a shattered pin in the bottom yoke, which enabled the yoke to slip on the shaft rather than pivot to push on the connecting rod.
It was a pain in the NECK to get out. In the end I had to break out a flashlight and inspection mirror to line it up correctly, then use significant force to punch and pry the pin pieces up and out.
19225786_1401613833248022_62083626867327
The yoke is in a position that makes it hard to get to the pin from below! Had to pry against the frame with pinch bars and various short punches against the pin.
19225451_1401613479914724_46989918506379
I measured the old pin, which was 3.5" effective length, and found it to be about a 1 degree taper- .360" on the small end, .500" on the big end. Set the lathe up and used the compound rest to manually cut a new taper pin. I should really be using the 18" Hendey for this stuff but it's not as tooled up as my little Grizzly is, yet...
19275093_1401613363248069_28092120641062
Not the world's best finish, but good for a pin!
19399728_1401613226581416_19535923718544
It tapped down in there nice and snug, and presto the linkage works how it should. Now I can step on the treadle and yell "bam bam bam!" all I want.
19275019_1401613189914753_70493508292865
And this last post brings me up to date for now.
I do a lot of work on my knee mill. It's already proved invaluable on the hammer rebuild, as it has for the rebuild and ongoing maintenance of my Little Giant power hammer and other machines. Just had to give it a shout out, it's an Index model 645, with power X feed and quill. I used it on the wrench to follow...
19247624_1403926356350103_64341077984290
The big set screws for the spring tension on the Beaudry have square sockets, which are a little irregular but are pretty much 1.940" both ways. I got a chunk of 2" hot rolled mild bar, and on the knee mill, roughed the sides down to 1.940" square and bored a 1" hole for a handle.
19366103_1403926643016741_17356176109368
The Beaudry Tension Wrench in full... 2' of 1" cold rolled 1018 for a handle, sliding smooth with little play through the wrench head. A cheater pipe can of course be added as necessary.
19247999_1403926653016740_89384402007076
The custom Beaudry Tension Wrench in action... gonna need to work on the threads a bit more with pen oil and possibly even heat though, we'll see.
19366457_1403926463016759_70645907885859
I'll have to turn those screws out all the way, to get the springs and ram off, to re-condition the ram's inner and outer ways and the spring-arm rollers.
1 person likes this
Wow Salem. Coming along nicely. There is something so eminently satisfying about a restoration.
Fantastic progress.  I am really enjoying reading these posts, so please keep them coming :)
It looks like you are making good progress! Do you need a large air compressor to run this, or does it have an internal piston? There is a guy near me that has an old nazel hammer that he isn't using, and it's just sitting outside. I have been looking around for a smaller power hammer like a little giant, but it might just be a case of go big or go home.
Salem, I commend your tenacity, and being able to make parts is a great asset as well. It is a shame that so many of these old machines ended up being scraped or sit out in the weather. Back when these were made they were made to last. Often from the stories I read on this it was economic reasons and maybe some small or minor repair in the grand scheme of things that the giants were put out top pasture. The outside storage often did more damage than anything.
I am tuned in to see how this project progress. Good for you, not only will you get the hammer you want when finished, but as well you rescued a piece of history!!!
Thanks for the comments guys!
Welsey, when faced with the possibility of getting a Nazel, I think one should always pursue it... but if you actually think it might pan out, be sure to educate yourself well on how they work and what to look for when inspecting one.  They can look great on the outside and end up costing thousands more than you bargained for, to make run.  Machining big parts and the like.  They sure are sweet hammers though!
In answer to your question, this is actually a purely mechanical hammer, so air is not involved in the workings of it.  Actually mechanicals are the most efficient type of hammer, as far as electricity consumed... a 300 lb. self contained hammer would need probably twice the motor that this one takes (7.5 hp.) and a 300 lb. utility hammer would need a big compressor, probably a 15 hp rotary screw or such.  So it's the best for my situation, which right now is a 60 amp subpanel for my whole shop.  This way I don't have to upgrade my power at all, I just convert to 3 phase for the hammer with my 10 hp Phase Perfect.
That's some serious work!  Kudos to you for resurrecting that wonderful old beast, it deserves to live again.  Plus I almost spit water on my keyboard when you mentioned stepping on the treadle and yelling "bam bam bam!" :lol:
1 person likes this
Lots of action today... here goes:
As I was driving to a gig the other day, my thoughts were on the hammer... imagining the fabrication of an idler pulley. Then I realized- wasn't there an idler pulley on that old straight six agricultural motor I got with some old trucks? Had a look the next morning, and voila... there it is, lower right, 5" face and 8" in diameter, mounted on its own bearings (which are still in good shape.)
19399914_1407456989330373_46648158435150
Turning to matters of adapting the idler to the hammer, the first item was to design a mounting method. The idler arm is bent from some unknown past force, such that any wheel mounted directly to it would be severely out of plane with the hammer's drive wheel.
So, I got one of the old 3/4" nuts from the idler arm, and made a custom T-nut with it to fit into the idler arm's slot.
19400158_1407455545997184_26765328821354
Neither of the big bolts I had were the correct length, one being too short and one being too long. I decided to use the too-short one as the threads were better.
There had been a large washer/standoff on one of the bolts, on the idler- so I turned a counterbore into it that the big washer can seat into. This on the 1911 Hendey 18"x10' lathe.
19424336_1407455485997190_19350117159194
My big Hendey lathe, take a bow old girl!
19399954_1407455355997203_39170261303150
With the parts modified, and a plan in my mind, I decided to use my Airco 3A stick/TIG welder, as the leads are 50 ft. long and can run right over up to the top of the hammer to tack weld in situ.
19510192_1407447682664637_85150694556849
It was pushing 100f as this photo was taken... the wheel is shimmed up to the right height with the idler, and I have a big flat old chainsaw bar clamped to the hammer drive wheel to transfer the plane of it to the face of the idler wheel. This should make it track right when tensioning the flat belt. I have the idler mount bolt tightened onto the arm, and am tacking the wheel's shaft mount to the angle adapter plate on the idler bolt.
19420553_1407448112664594_61243346855787
I took it all down after tacking, brought it inside, and MIG'ed finish welds on all around. The plates involved act as angle adapters as well as standoffs to achieve correct distance from idler, and correct alignment with the drive pulley.
19260740_1407447995997939_15958062385083
Mounted back up to have a look...
19399993_1407447915997947_48080361679258
From the off side...
14591684_1407447762664629_60882600153152
Observe the tiny blue sky gap between the wheels... you can see that they are parallel. Actually from the face angle of the belt they are more co-planar yet.
19430136_1407447942664611_15833249677076
The hammer as he sits now.. idler installed, treadle fabbed and installed, brake freed and linkage corrected. Next is to make the adjustable connecting arm from brake pivot to idler arm.
19248024_1407448105997928_35711854206975
Stay tuned!
That is looking really good! Even though mechanical hammers are more efficient, why do people still prefer air hammers? is it because your foot determines the stopping point of the hammer, rather than the amount of force that the hammer exerts?
Wesley, a few reasons... air hammers are good for not needing any height adjustment to work from a tall piece down to a small piece, and offer very good control throughout that range.  This makes the use of tooling pretty convenient.  Also, mechanical hammers above 250 lbs. ram weight are pretty rare, especially in the 400-500 lb. range.  I'm not aware of any mechanical hammers really being made over 500 lbs.  Air hammers can be as small as 50 lbs, and as large as 40 CWT (2 tons plus.)
In general, many makes of mechanical hammers were targeted at smaller shops and smaller budgets, and so many were not truly industrial quality.  Some such as Fairbanks, Howe/St. Lawrence, Beaudry, and Bradley were quite well designed and built and had their place in heavy manufacturing.  Most of the old air hammers were designed and built to do heavy and demanding work in industrial settings, and are thus quite robust in their castings and parts.
A mechanical hammer with a good brake and clutch/slack belt design can have wonderful control too, and unlike a self contained air hammer, control over the speed as well as force and height of the blow.
Not everyone does prefer air hammers though, I know some folks with informed opinions who will prefer a Beaudry or Bradley in their shops.  I'd like some day to have self contained hammers by Massey and Nazel, and utility hammers by Chambersburg and Niles-Bement-Pond, in the enormous forging shop of my dreams...
Looking at the Beaudry Champion hammers, they really have more in common with steam/utility hammers, in terms of the frame and slide configuration.  They remind me quite a bit of the Ross/Rigby hammers and the Massey "in slides"  early self contained hammers.
I really couldn't stop working on the hammer today... I did get some paying work done this evening after the shop cooled off though.
Here's the afternoon's work.
I moved to a strategy to put serious torque on the Beaudry Wrench... and the set screw broke free! It turned fairly easily after that, and after freeing the second one it was apparent that both had remained well oiled but for the surface thread.
19424422_1407660709310001_64144457910035
After surveying some options for hoisting the ram, I padded across the anvil ring with steel and timber and just turned the set screws out until the ram dropped and tipped onto the boards provided in its path.
19248064_1407660865976652_21842179023982
Inspecting the rollers... pretty rusty, no surprise there.
19423977_1407660929309979_16333793077335
This one has a major problem. A big part of the roller face is cracked and about to separate. If there had been any debate about making new rollers, this pretty much settles it. Also not a major surprise, and not a very difficult turning project.
19420598_1407660115976727_40016977280876
I took the set screws all the way out, and with pen oil and light tapping and wrenching, loosened the ram height adjustment set screw and got the wedge out.
19424540_1407660349310037_43716335191061
Delving into the mysteries of the spring box, I saw that the lower inner tie member of the casting was seriously cracked. Also, it looks as if someone in the past may have patched it at some point... trying to wrap my head around that pin thingy.
19420707_1407660162643389_88823572105421
A view of the other side of the casting... equally cracked.
After thinking about this a bit, I'm going to forgo heating the whole thing up and welding or brazing it. The height adjustment rack was still quite tight in its position and the whole spring box still has heavy support from the sides and from above; the casting is cracked through at any rate on the lower tie member, so that part can't get worse unless new cracks begin elsewhere. At any rate this crack cannot propagate further.
If I need to in the future, I'll pull it out and deal with it.
19420781_1407659759310096_47557221793936
Edited by Salem Straub
After talking about this problem with some folks, and finding that the casting is mild steel rather than cast iron, I decided to weld it after all.
Here's the first side with the crack grooved out, using a combo of angle grinder, carbide burr, and sawzall. There were some voids in the casting...
19429609_1410700679006004_60972087564125
Side number two grooved out.
19554367_1410700592339346_56414555539595
I used an old soft aluminum jaw from the mil vise as a backer for the weld.
19430121_1410700489006023_58264868445743
All welded full... second side looks more or less the same. I welded on the inside as well.
19511219_1410700662339339_71553488568420
First side after grind cleanup.
19510573_1410700639006008_61696516058023
Second side after cleanup.
19510402_1410700599006012_85197656262482
Stress relief heating up to very dull red.
19260744_1410700675672671_82628516317558
I got a big turnbuckle and some stuff for making the top linkage arm today, so that's getting monkeyed with next.
Awesome! It sucks that the original castings had voids.
