  • Announcements
    • Alan Longmire
Joshua Wilson
Tang burning
Thank you for the advice Alan i went ahead and did it and it did get the job done but left kind of a big hole ill have to fill with epoxy. Maby next time i will try soaking my antler a month or 2 before I use it i hear this method works well. I will continue on with this build and show a picture when finished. I am kind of a beginner at blade making but I will do this one correctly I burned the tang through and out the other side i will fill it with epoxy add a pommel then peen what tang is left.
Edited by Joshua Wilson
Antler smells kind of like...................., well guess I can't say that here! But it is bad and it does not work well as Alan said, and you have found out!
Drill it and then resort to these!!! Broaches I made and the pieces of tubing I cover them with when not it use! I ground them down and file my own teeth in!! These were made from a couple of Old Hickory knives picked up at the yard  sales and at the local Misson for a couple of bucks. Grind down or cut off excess metal making sure you leave enough metal for the teeth to be cut in. HINT: You can always take off more but it is hard to put it back!!
Drill as deep as you need and waller it out. Then grab the broaches and go to work. The hole may be a little larger and that is OK as long as you fill to the bottom with epoxy! Even with burning the tang in your hole gets larger so the eposy has to do the work!
A couple of tips:
Use 30 min epoxy.
Thin the epoxy to get it to fil the entire void
Use one of those stirrer straws like you get at Macky Dees with your coffee. The stirrer goes in first and allow for the air to escape as the epoxy fills the void!  Also works to puddy the epoxy to make sure it fills the entire void!
Edited by C Craft
Dude this is awesome thanks. I have a few old kitchen knives i can make these tools from. I will still continue this knife build tho. Even tho the hole is a bit big it will still make a solid knife when epoxied and peend on the brass pommel im gonna make.
Also, drill a couple of holes in the tang and make sure that epoxy fills them. That makes essentially "rivets" which grab the tang much more securely.
Another approach is to use a piece of commercial hacksaw blade to make a broach with the only downside beign that it is .135 (3.45mm) over the teeth but that can also be ground down for narrower blades. Having two of these with a thick and thin would cover all needs I would think.
For antler, boil for about 45 minutes and the core is soft, so you can just press the tang in. You're only limited to the porous part that way, which is less wide then the brown center. So if your tang is wider then that, this method doesn't work. Nice thing is though that you don't need glue either. The core itself already contains the glue which is released by softening it. Though if the tang is very narrow and/or relatively short and the porous part is very open, you do need a filler to fix the tang in place.
