Tyler B 9 Posted July 16, 2017 Share Posted July 16, 2017 Hello all, I was looking through some metal I have stockpiled over the years and came access this peice. The man who gave it to me called it wrought, and said it was an old "rock nail". I ground an inch of it with a angle grinder and etched it in Ferric chloride diluted 1 to 4 in distilled water for a few minutes. It looks almost fiberous and grainy like wood. Here are some pics, I hope it's legit so I can use it in some blade spines. What do u all think? www.facebook.com/borrorarmory Instagram borror_armory Link to post Share on other sites
SteveShimanek 112 Posted July 16, 2017 Share Posted July 16, 2017 Looks like wrought to me Link to post Share on other sites
Alan Longmire 3,678 Posted July 17, 2017 Share Posted July 17, 2017 Yep, that's wrought! It looks like a spike harrow tooth. Those are good and gnarly! Link to post Share on other sites
Jan Ysselstein 102 Posted July 17, 2017 Share Posted July 17, 2017 I would do a spark test..if that piece is shear steel it will show. Link to post Share on other sites
Tyler B 9 Posted July 17, 2017 Author Share Posted July 17, 2017 The sparks would be similar to mild steel right? www.facebook.com/borrorarmory Instagram borror_armory Link to post Share on other sites
Alan Longmire 3,678 Posted July 17, 2017 Share Posted July 17, 2017 What little sparks wrought makes are long red trails with almost no bursts of carbon at the ends. If it's shear steel they will be shorter yellow trails with ample bursts at the ends. Link to post Share on other sites
Ibor 236 Posted July 17, 2017 Share Posted July 17, 2017 It is old iron, fibrous, quite possible from before 1850.It is heavily contaminated with fibrous hereby.Usually it is iron (not steel) very soft.On the edge of the knife is very fine, after etching (I grass in the battery electrolyte) will come out beautiful fibers, but with a heated edge cutting of today's iron or steel. Link to post Share on other sites
Tyler B 9 Posted July 17, 2017 Author Share Posted July 17, 2017 Thank you all for the replies and help. Ill get it cleaned off and drawn out. I'll have some pattern welded leftovers from my seax build and I'll add some of the wrought in it. What is shear steel? Is it just another name for cast iron? Too much carbon? www.facebook.com/borrorarmory Instagram borror_armory Link to post Share on other sites
Alan Longmire 3,678 Posted July 17, 2017 Share Posted July 17, 2017 Shear steel is wrought iron that has been case hardened, then stacked and welded many times. It is the way most steel was made prior to the late 18th century, and remained common into the mid-19th century when the Bessemer process revolutionized steelmaking. And that is reducing a two-volume book to a short paragraph! Link to post Share on other sites
Tyler B 9 Posted July 17, 2017 Author Share Posted July 17, 2017 Thanks Alan, tomorrow I'll spark it and see. Shear or wrought would they both make a good small seax Spine? It sure has a wood grain pattern either way www.facebook.com/borrorarmory Instagram borror_armory Link to post Share on other sites
Jeroen Zuiderwijk 250 Posted July 18, 2017 Share Posted July 18, 2017 If it's shear it's great as edge material as well. Best to check the entire length for serious weld flaws before you make something from it, as they occur frequently, particularly with gnarly wrought. And forge it hot. Jeroen Zuiderwijk Facebook page: https://www.facebook.com/barbarianmetalworking Link to post Share on other sites
