Toni 1 Posted July 18, 2017 So, I some time ago got myself a double sided diamond stone, been trying sharpening with it a bit, it's going okay, though maybe I need a bit more patience. Anyways, What's the proper technique to use? Some tell you to do a slicing motion on top of the stone, which has done alright for me. Some tell you to do a back 'n forth motion, which has given me the best edges so far. And some tell you to do a circling motion, which I have found quite bothersome as the hilts of some knives seem to get in the way. Share this post Link to post Share on other sites
James R.Fuller 15 Posted July 18, 2017 Motion isn't so important. I have seen a bunch of different people achieve the same results using all sorts of different types of knife strokes. What is important is keeping a consistent angle and a consistent amount of work on both sides of the average blade. You should use whatever motion is going to help you stay the most consistent. Share this post Link to post Share on other sites
Doug Crawford 32 Posted July 19, 2017 I tend to use a back and forth motion for rough material removal and end up polishing with just the forward motion, and strop backwards. My own preference, I'm sure there are some with lots more experience that have different methods Share this post Link to post Share on other sites
Karim 62 Posted July 19, 2017 i second all above and would add that the stone needs to be flat and soaked, so make sure that is the case before starting the job. Consistency in the angle is the most important. Share this post Link to post Share on other sites
