Alan Longmire
Things you might not know can kill you
7 minutes ago, Alan Longmire said:
If it's totally rusted the plating is gone, for the most part.  It is probably safe to forge, in other words.
Thanks. it is totally rusted. Also, if i have something that is plated but I would like to use, can you grind the plating off?
Usually not a good idea, because then you have toxic dust everywhere.  Thin galvanizing (zinc plating), the shiny kind, can be removed by an overnight soak in vinegar or a few minutes in muriatic/hydrochloric acid.  Hot-dip galvanizing, the thick, dull greyish crystalline-looking kind, can also be removed by a soak in muriatic acid, but since it's so thick it takes longer to remove.
Chrome plating can be ground off, but wear a respirator rated for particulates.  A paper mask won't cut it.  And wear rubber gloves, finely powdered chrome can cause a nasty rash.
Cadmium, though rare these days, will kill you slowly in dust form.  A big problem here is that cadmium plating looks a heck of a lot like the relatively harmless zinc chromate you see on hardware these days.  That sort of gold-ish with hints of blue and purple, found on a lot of tractor hardware and such.  Cadmium has more of a grayish-gold tinge and more of a rainbow effect, but they are darned similar in appearance.
Zinc chromate-plated spanner:
Cadmium plated parts:
Electro Loh's Cadmium plated finishes
Wow, they look exactly alike to me. So... maybe just stay with rusted metal from the junk yard till I'm more familiar with the different types of metals and whats safe/best to use.
Always a good idea.  B)  Leaf springs, axles, sway bars, SOME coil spring,  that sort of thing.  Used springs may be subject to fatigue cracking, new spring drops are better.  Dunno if there's a spring shop at Kitty Hawk, though...
Uuuuhhhhhhh... I just Welded on some of that. What are grade 8 bolts coated with? I thought it was zinc. I didn't breath it, but not a good idea anyway?
Cadmium is one of those heavy metals that you do NOT want inside your body. You know that pink Himalayan salt? Yeah, that's cadmium giving it that color.....and the blue stuff? That's cobalt . Another toxic heavy metal you do not want to eat.
Usually  that color on grade 8 bolts is zinc chromate.  Cadmium is mostly used now in aerospace, chemical processing, and other critical applications where something absolutely can't rust.  But it used to be widely used on car parts.  Welding on any plated metal is a bad idea without a respirator and/or positive fume extraction.  Heck, even welding stainless produces hexavalent chromium, which is pretty bad for you as well.  So given that "chromate" part of zinc chromate, it might release 6Cr when vaporized as well.
I think we can agree heating plated stuff is a bad idea.
I am an aerospace machinist, and while legally i cant give any details, i can confirm that theres quite a bit of aerospace parts that get cadmium plated. Nasty stuff, you really dont want to be around it.
I was going to post this in a new topic, but it won't let me.
A home built power hammer warning.
Power hammers will kill you.
I expeirienced the spring "grenade" followed by flailing arms today.
If you think you should rebuild a part; rebuild it. Also, dont use pipe for any structural joints.
Try not to get yourself killed like I almost did
I'll post aftermath pics when I have better service.
  • Sad 1
Wow! That is seriously ungood.
Glad you are OK.  It sounds like an opportunity for a spontaneous wardrobe redecoration.
So, What happened is:
I got eveything finished except for paint, so I decided to run it pedal to the metal.
"ThukThunkThunkSNAPBOINGSLAP SLAP!!!
It worked great for a few blows (although quite scary) then the wrist joint snaped, and then the arm got caught on the frame on the way down. This sent the spring flying out the door of my shop. The spring was cut at a very sharp angle that could've impaled someone. It also bent the reinforced 1/8" thick crank plate straight up and may have ruined my pillow bearing.
I only took pics of the wrist joints and the spring. I get to rebuild this tomarrow all because I ran those makeshift wrist joints against my better judgement.
You can bet that I'll be going over the whole thing before tryin it again.
Yikes! Glad you, everybody nearby and everything nearby were unharmed. Could have been much worse.
If you think something is overbuilt, add a bit more to be safe(r). Glad you are ok....
I got another one :unsure:
Pressure release valves on propane tanks can kill.
In Virginia, you can have temperature changes of 40° in a day.
I got my 100lb tank filled bright and early when it was a cool 60° and left it at the shop door out in the sun. I went about my day welding, and playing loud music and could smell propane. I thought it was just my regulator/hoses next to me, but It got thicker and thicker. I walk over to the tank, and it's just pouring out propane and Ice actually formed on the release.
When It gets filled cold, then the tank heats up, the gas expands causing the release valve to open. When your shop gets full of that stuff I wonder if you could suffocate or blow up?
Be careful out there!
We are all concerned with the nasty things that can arise from heating various metals, Cadmium fumes will cause you to pass out and then come too in a few minutes feeling fine till you drop dead 12 to 24 hours later.  Zinc is nasty, so is chrome and some other metals, all have been mentioned here.  But we seem to be oblivious to the hazards of the various spray cans we have in our shops.  Many contain chlorinated hydrocarbons such as 111 Trichlorethane, Methylene chloride and other bad actors.  I beg you all to read the Material Safety Data Sheet on everything before you use it.  Unfortunately, the MSDSs are sometimes not all that readily available.  You have to ask for them but if you are a business and not just an amateur you are required to keep an MSDS on hand for every chemical in your business.  I hope you all have graduated from the Scratch and Sniff Chemistry School.  There are so many hazards associated with the things we use it would take volumes to list them all.  The hardeners for Bondo and Fiberglass are Organic Peroxides that have a temperature above which they will ignite or explode.  These temperatures can be as low as 125 degrees F.  Once they reach there Self Accelerating Decomposition Temperature they ignite and burn quietly or explode depending of the particular chemical.  The amount given with the quart of Fiberglass Resin or the quart can of Bondo won't blow up your shop but they could start the fire that burns the place down.  They need to be stored in a refrigerator.  Chlorinated hydrocarbons are skin absorbable and collect in your liver or kidneys depending on the particular chemical.  You might want to research the OSHA Regs too, Methylene chloride, found in paint strippers like Zip Strip, is covered with 27 pages of regulations.  Remember always Be Safe, Be Careful be around Tomorrow.
while at winterfest a very well known artist while demonstrating warned on the hazzards of not tinning your copper.
What are the Symptoms of Copper Exposure? https://www.globalhealingcenter.com/natural-health/dangers-of-copper/
The body needs trace amounts of copper in order to function properly. But too much exposure to copper can cause a number of health problems. For instance, simply breathing in copper can cause irritation to your nose and throat. If you ingest copper orally, it may cause:
Nausea
Vomiting
Diarrhea
Liver Damage
Kidney Damage
Death
Also have been told vermiculite is very, very bad news to breath.
Although not all vermiculite contains asbestos, some products were made with vermiculite that contained asbestos until the early 1990s.[7]Vermiculite mines throughout the world are now regularly tested for it and are supposed to sell products that contain no asbestos. The former vermiculite mine in Libby, Montana, did have tremolite asbestos as well as winchite and richterite (both fibrous amphiboles) — in fact, it was formed underground through essentially the same geologic processes as the contaminants.
Pure vermiculite does not contain asbestos and is non-toxic. Impure vermiculite may contain, apart from asbestos, also minor diopside or remnants of the precursor minerals biotite or phlogopite.
have not mentioned manganese poisoning, or silver poisoning, mercury, or even tin poisoning.
Too many years grinding without a respirator, iron poisoning is a real thing. Sort of like silicosis, from steel mills.
Please, Please, Please get a Material Safety Data Sheet MSDS for everything (chemicals, metals you name it, there is one for brass hammers even) get the MSDS's and read them before you work with anything.  The life you save will be your own.  It only takes a minute or two to find out everything you need to know.  Now with everything  being on line, you don't even have to get a paper copy of them.  Some of the things you wouldn't suspect are actually hazardous.  Dawn Dishwashing Detergent gives off flammable vapors because of the alcohol in it.  One final caution do not consider yourself a student in the scratch and sniff chemistry school.  Your nose is a poor toxic gas detector and at it's worst it will work only once.  Some hazardous chemicals have a high odor threshold, by the time you can smell it you are over the exposure limit.
Is there a medical term for having a burn inside the meat of your thumb?
I regularly get it from holding on during the grind....as you should.
No blister, just feels like cooked meat inside :lol:
Happen to anybody else?
i think my right thumb is now 'very well done' :D it holds onto steel much longer now than it did a month ago!
  • Haha 1
Don't forget about your air compressor. Clean the contacts on your pressure switch and make sure the safety popoff is in good working order. If the pressure switch sticks and the popoff is bad, you have a bomb. Been there, seen that.
