Viktor Johansson 19 Posted August 4, 2017 Share Posted August 4, 2017 (edited) Hello, I'd like to show you some of my stuff. I've been doing this as a hobby since three years ago when I got a knife and axe course as 30-y birthday present at Erik Vargtands forge in Dalarna, Sweden. Since then I've returned to the same forge once or twice a year to forge some new stuff. Below are two seaxes, forged from bars of pattern welded steel 1095/15N20 (ebay steel). First seax has a heavy blade with lenticular cross section. Handle is made with bog oak, moose antler that we found on a field and some brass and bronze. I Think the style is more continental than viking? Maybie Anglo-saxon. I think I see some roman influences in the handle. Tang was cold-peened and you can see the edges cracked a bit. Fittings are 1 mm bronze riveted to a 2 mm brass plate that I filed to look like twisted rope or something. Second seax is more viking inspired and has wedge shaped cross section, very thin edge and a pommel that is too heavy and gives it strange balance. Fittings are cut from copper and a big block of cast grey iron (from Scania Engine block). The grey iron was boiled in lemon juice to get the grey finish. If you ever work with with grey iron use lots of ventilation and take a shower after work is done. It contains about 4% carbon and creates lots of fine powdery black dust that gets in everywhere and triggers bad skin with rashes that stick for weeks etc. Because of warping I had to heat treat three times. This left more burn marks on the surface and along the layers in the steel. I decided to keep a few of these for a more rough look. I am currently making my first sword of some kind of wootz. I'll make a post as soon as I sort some images.. Edited August 4, 2017 by Viktor Johansson 2 Link to post Share on other sites
Chris C-S 148 Posted August 4, 2017 Share Posted August 4, 2017 Thats beautiful, the second piece is stunning. Thanks for sharing. 1 Link to post Share on other sites
Viktor Johansson 19 Posted August 4, 2017 Author Share Posted August 4, 2017 Thank you Chris! I just wish I had drilled out the pommel to make it better balanced. Point of balance is like 1-1.5 inches up from guard! Link to post Share on other sites
Kris Lipinski 136 Posted August 4, 2017 Share Posted August 4, 2017 I really like the handle of the first one. You have really good sculpting skills 1 Link to post Share on other sites
Garry Keown 890 Posted August 5, 2017 Share Posted August 5, 2017 8 hours ago, Kris Lipinski said: I really like the handle of the first one. You have really good sculpting skills So do I @Kris. It is very nice overall but I particularly like the balance of blade shape to its length and width with the handle contours and materials/colours, which harmonises so very well with the entire knife. 1 Link to post Share on other sites
Viktor Johansson 19 Posted August 5, 2017 Author Share Posted August 5, 2017 You guys are very kind. Thank you! Link to post Share on other sites
Kevin Colwell 143 Posted August 5, 2017 Share Posted August 5, 2017 I agree with above post - the handle on the first one is quite beautiful. That is an impressive bit of adornment, and it is not, "too much." The brass/bronze and rivets on the butt cap are really nice. The steel looks good, too. On the second one, the pommel is a little too big. It if was a lot smaller, it would look better (and as you noted, balance better). The grey iron looks nice. I don't know if you could have gotten a similar effect with mild steel, maybe? Oh well, it is still a very nice seax. Thanks for showing them and sharing the information. 1 Link to post Share on other sites
Karim 62 Posted August 5, 2017 Share Posted August 5, 2017 Nice stuff you posted, like both handles there 1 Link to post Share on other sites
Viktor Johansson 19 Posted August 5, 2017 Author Share Posted August 5, 2017 (edited) Hello @Kevin, cast grey iron is a completely different kind of material compared to steel or mild steel. It is a class of cast iron, more close to raw pig iron and is packed full of non-ferrous substances mostly Carbon (3-4%) and Silicon (1-4%), but also lead, phosphorous and other stuff. You can't hot or cold work it (will crack and crumble) but it has good machinability, wear resistance and dampens vibrations making it widely used for casting engine blocks. As far as I know its the only type of cast iron that is still being used a lot by modern industry. It does not show much in the pictures but it is very "grainy", at first look the surface looks plain grey and smooth but at a closer glance you can see little tiny grains giving nice display of reflections. This only becomes apparent after some kind of surface treatment. I've only tested boiling in lemon extract and ferrous chloride. I didnt like the effects of ferrous chloride but lemon seems to work well to bring out the deep grey color and tiny shiny grains. It should be easy to get some from a junk-yard if you want to experiment, but take care when drilling/filing/grinding and clean off the black powder from skin directly after you're done working to avoid triggering dermatitis. Edit: I agree, the pommel too big! I made it before forging the blade and it became shorter then anticipated. Edited August 5, 2017 by Viktor Johansson Link to post Share on other sites
Phil Ullrich 22 Posted August 5, 2017 Share Posted August 5, 2017 Very nice work! Link to post Share on other sites
