Inlaying stones into soft metal using a dremel
Hello fellows,
Here is how I inlayed some synthetic corundum stones (ruby/sapphire) into a piece of copper for a knife handle. I don't know if you can call it tutorial but here is how I did it:
A slot was milled, tricky to make it fit right. Also the damn mill bit liked to fly around and make a mess of things.
Then the outside of the slot was milled. But I quickly changed to files because it went faster and easier.
I found files worked much better to shape the outside, to create a collar around the stone.
Stone is ready to be set.
I set them by hammering the collar around the rim of the stone using a hammer and a rounded punch-tool.
Stones are now set and ready to be used for a knife handle in this case.
Edited by Viktor Johansson
On 8/4/2017 at 10:23 AM, Greg Thomas Obach said:
if you use a pitch bowl, it will hold your copper work piece solidly and make life much easier
nice work!
You can also super glue it to a piece of plywood.
