JamesK
Axe Build - Steel "Powdered"
So I was planning on turning an old, rusty, cheap camp axe into a shiny Viking style axe with a modified handle. All was going well but then I noticed that around the beard of the axe the steel got way too soft, like almost play-dough like soft, every strike would send it back super far and I got a lot of folds and the steel ultimately started deteriorating. When it cooled down it looked almost powder-y and I don't know why. Could it have gotten to that point because it was too hot? Or maybe it was just really cheap steel? Also, when I tried grinding it to shape (and failed), it produced a lot of sparks so it was definitely very high in carbon. My three guesses are it was either too hot and I overheated the steel or it was a very low quality steel that deteriorated over time
Oh and if I were to buy a $10-$20 axe to try again, would I most likely get the same results with steel that cheap?
The crumblies are caused by getting it too hot.  It may also be cast steel, which is not particularly forgeable.
If it gets to that point how do I prevent it from crumbling, or how do I "reverse" it
If it gets to that point you're screwed and have to start over.  The steel has broken apart at the grain boundaries and oxidized, and nothing short of re-smelting it will fix it.
To prevent it in the first place, never get it hotter than yellow, and some high-carbon steels don't even like to be that hot.  Sparks coming off high carbon steel in the forge is a very bad thing, and indicates the steel is literally burning. Never forge colder than medium red heat.  All high carbon steels will crack if forged too cold.
