• Announcements
    • Alan Longmire
Robert Burns
Voivode Bowie WIP
22 posts in this topic
Some of you may know this and others not, but each year I like to do some type of Halloween themed knife, and while it may be early on yet in the year, I wanted to make sure it was done in time for this Halloween. A few years back I did my Van Helsing Bowie which was based around several elements of the Van Helsing legends/ stories. This is what I had come up with:
20729675_10213076736489410_5079740689442
Pretty much from the moment I finished the Van Helsing bowie I wanted to do its brother in the style of Dracula. Each time I attempted this project I found my skills lacking for what I wanted the end result to be, so now three years later I am making myself finish the set.
Now due to having other paid work to complete this project will go in fits and starts, but at this point the blade is successfully heat treated and ready to be polished and etched. I started this project over two months ago and only have time to work on it a few hours at a time, but by hell or high water I will have it ready in time for Halloween!
Now with all of that being said the name of this bowie (as the title of the thread suggests) is Voivode which was the title of Vlad Dracula a.k.a. Vlad the Impaler. Voivode translates roughly to prince or ruler in the native tongue of that time in the kingdom of Wallachia. The styling I will use on this knife is a blend of the historical Vlad Dracula and the modern myths around the figure. Hopefully everything will come together in such a way that it will embody the character we all know from tales of horror.
So without further ado let's get cracking shall we?
This whole blade will be forged in a multi-bar construction from  1084 and 15n20. There are two billets that will comprise the edge, one being a jelly roll and the other being crushed W's. First the billet for the jelly roll is welded, drawn down, and rolled up.:
19905331_10212812223996763_1401062020032
19989304_10212812099593653_5982264663721
20031680_10212812104313771_2315875986933
It is then welded together, cut, etched (to check the pattern), then drawn down to 1 1/2" x 3/8" flat bar.
19989586_10212812102273720_6083044332041
19961295_10212812171595453_6519960241435
19990193_10212812104473775_8251688975274
Next we start on the W's billet:
20046802_10212812133554502_5513872234685
20031792_10212812102953737_8462899034975
 I drew this billet down and re-stacked it six times to achieve a low layers Ws, this was then drawn done to 1" square and twisted:
19983268_10212812099313646_2973491364692
19989371_10212812103233744_1783336147911
Each of these bars were 4 1/2 inches long and drawn down to 3/4" square. I then cut two pieces of jelly roll billet to a matching length. I then took a piece of the jelly roll billet and cut it in half length wise.
19961466_10212812101873710_8030296859323
Then with the top bar of JR in place it is fully encasing the crushed Ws:
19989736_10212812104793783_4273350295445
19989681_10212812102633729_5440109342836
After forge welding, this is what the bar looks like. In the future with this type of pattern I think it would be wise to increase the thickness of the outer layers as they ended up getting a bit thin.
20046437_10212812103673755_2102622498810
 I then cut this bar in half and welded it to its self:
19989678_10212812096673580_3570516530177
19959181_10212812102793733_2670537787909
I then cut this in half and forge welded it again to give four bars.
19989524_10212812097273595_4885902651543
And that completes the edge bar.
Now for the other bars I wanted to have them be a more basic pattern so I about twenty layers and three billets of JR evenly placed throughout. This was then welded together, drawn out and cut for re stacking:
19959210_10212812099553652_8155743271790
19905183_10212812101833709_6396903271991
20031915_10212812097233594_4949243469149
20046405_10212812098633629_2080072000358
Then to add some additional interest, I added .30" W2 in between the layers, this was then drawn out to almost 50 inches of 1/2 inch square bar:
20031888_10212812097953612_7594443843281
20108437_10212812097913611_6614976577297
20139588_10212812098113616_5225289845941
20046540_10212812096753582_2594516686600
20106258_10212812098833634_9159930878307
19961194_10212812100153667_2783770434684
19990482_10212812100513676_1368934618364
I gave these bars a Turkish twist configuration so every other bar twists the opposite direction from the previous one.
19642232_10212812100953687_1566406878075
20017756_10212812101753707_8828771681280
 After being re-squared and ground clean on their mating surfaces we can now see how they will be ordered in the billet. Between the edge and back bars I placed a single piece of 15n20.
19990377_10212812100673680_6918413801273
I trimmed a bit off the ends of the Turkish twist bars to make everything even and tack welded it all together.
19959345_10212812099993663_7630259286697
Then it was all forge welded:
20031741_10212812100033664_2970997790824
The next installment of the thread will cover the blade forging. Thanks for looking!
And this post should bring everything up to date.
First I forged the tang. My intention is to do this as a take down construction hence why the tang is so long.
20140007_10212831367555340_6480263092261
Now that I have something to hold on to I can cut the billet free from the handle and check the state of the welds.
20046487_10212831367515339_6431295112849
Looks good to me, now to cut the rough lines of the point. (This will allow me to bend the pattern back in line with the flow of the blade.)
20157543_10212831376195556_7891249183798
Now I begin the rough forging:
20032128_10212833738934623_5690874863706
And a quick etch on that corner piece to see some pattern.
20108509_10212833739134628_3061781791002
And finally a normalizing cycle post forging:
20046603_10212833739054626_2565628060381
Then I left the rough forging in a vinegar bath overnight to remove most of the scale.
20156142_10212839815286528_2862728859066
Then surface ground the tang and ricasso to .25"
20228353_10212855299713629_7840872655242
 From the sharpie lines on the rough lay out you can see I will be doing my usual beveled ricasso and also another bevel on the spine. To me these are the scariest grinds because if you mess them up you pretty much have to scrap the knife and they can mess up quickly.
20108238_10212856153374970_7060344030032
20106800_10212856153894983_1952758270044
With the bevel done on the ricasso I can now move on to the spine.
20228242_10212856153334969_1688592665332
Then cleaning things up via hand filing.
20108349_10212856153414971_5555776368819
Finally I roughed in the clip:
20258043_10212892332959437_8008170486982
Then on to the primary bevel:
20748297_10213068224316611_5287364592307
And a quick sneak peak at the pattern near the tip:
20708373_10213068224276610_8831692056596
And here is the blade, as of today, successfully heat treated, and ready for the final polishing and metal carving to be done to the blade.
20729233_10213076672127801_3945391256854
1 person likes this
Well now. That was a busy day.........:o
Looks great so far.
Oooh. Eye candy. Thanks Robert
Dude!  You're on fire, and in a good way.  Pinned!
Thanks guys! Joshua I wish it was only a day! But my hope is to have the blade etched tomorrow and ready for the guard which there will be quite a delay on I think. Here are a couple of last photos from today (my wife is away so I can work late into the night :) ) I wanted to add some metal carving to this blade so that is what I have done. This first side is now all finished to a base 400 grit.
[IMG]
Cool, lots of hot work!  I'm staying tuned for this one...
Robert, this is amazing. I had to go through the patternwelding pictures twice because I got overwhelmed and lost track of what was going on.
How did you cut the decorative grooves at the base of the blade there?
Wow, I lost count as well but, dude I am loving the result! I am tuned in to this one!!!
Thanks guys,  I was able to finish the carving today and do the etch. Overall I am pretty pleased with the pattern and look on the blade.
Here is the finished carving:
[IMG]
And then the etch:
[IMG]
[IMG]
Wow, this is amazing. I can't wait to see it finished. That nickel line between the body and edge is a great look. Your Van helsing themed blade is amazing as well!
Awesome blade and great craftmenship as always. I feel proud as a romanian that you make a bowie inspired by Vlad Țepeș or Drăculea (Dracula by the foreigners) in romanian language was the name that was given by the people to Vlad Țepeș father, Vlad Dracul, because he was the member of an military-religious order, The Dragon Order - similar to The Teutonic Order or Sovereign Military Order of Malta,  that had as a symbol a dragon - named dracul by romanian people. From that symbol the entire family following the blood line of Vlad Dracul, Vlad Țepeș father was named as to be of Drăculești.
And if i may, the corect term is Voievod.
1 person likes this
Catalin, Thank you so much for the correction and additional information! As I am making the knife I am learning more about your country's history. My plan is to replicate the Iron Crown of Romania for the top but that holds the knife together.
OK.  I like what I am seeing! I got to ask though, why the nickel line?? I assume that is the line in this pic!
[IMG]
C Craft, The nickel line is there to separate the edge and back bars to give the knife an overall more bold appearance.
Just a small update today. So when planning for this knife I knew I wanted to use shibuchi for the guard and but plate (in the same way I did on the Van Helsing Bowie), but with this one being more refined and complicated I decided to try my hand at lost wax. This is my first time carving wax and it really has been fun beginning to learn the process, definitely something I want to do more of in the future.
First I made the rough cuts in the wax and roughly fit the tang. I also cut my wax too short on the back part of the guard, but as I learned that is very easy to fix.
20800363_10213121484088072_8670290873628
First things first is to add back on the piece I cut to short and to thin down the guard a bit.
20800334_10213122951484756_4609067090313
Then I began rounding the junction between the (quilion?) and the center of the guard.
20798977_10213122951844765_1850943767508
Then I carve the first channel:
20915653_10213122952124772_5648991298246
Then I add in the second step to complete the ring.
20840974_10213122952444780_7390605400192
Now I am just laying out some lines for future carving to take place tomorrow.
20841941_10213122952844790_5914043434628
1 person likes this
Captivating to follow the many facets of complications going into this one Robert.
