Still a few spears and javelins ....
Ibor
Beautifully forged sir!  Very impressive.
George Ezell, bladesmith
Buffon
view some of my work
RelicForge on facebook
Thanks!
And a few more .....
Wavy Celtic spear, total length 30 cm, maximum width of 5.5 cm, hole 23 mm, weight 325 gram.
Central spear,Przeworsk culture, total length 34.5 cm, maximum width of 5.3 cm, hole 20 mm, weight 370 gram.
Last spear,iron age, length 29.5 cm, max width 5.2 cm.hole 23 mm, weight 421 gram.
Spear, Carolingians, length 49.5 cm, max width 48 mm, hole 22 mm, weight 690 gram.
Longer Angon 49 cm, max width 45 mm, hole18 mm, weight 360 gram.
Shorter 38 cm, max width 40 mm,hole 17 mm, weight 290 gram.
Spear and eye ... what can they have in common?
Symbolism.
This symbolism is present on many iron spears, especially on sleeves spears, in the Przeworsk culture.
Interestingly, Dr. Bartosz Kontny writes, from which I drew the picture.
The spear has a length of 36.5 cm, a hole of 21 mm, weight 300 grams.
...and more ....
Vimose two spears.
The length is 44.5 cm,hole 20 mm,weight 320 gram.
The shorter is 38 cm,hole 19 mm, weight 260 gram.
..and,early medieval spear.
Length 42 cm,hole 25 mm, weight 395 gram.
...and ancient Germanic two spears,longer is 46 cm, hole 22 mm, weight 530 gram.
The second one is 41 cm, hole 20 mm, weight 415 gram.
  • 3 weeks later...
Fact ... I did a couple of them ... hahahaha ...
And another .....
Longer, early medieval, 42 cm long, 20 mm hole, weight 500 grams.
Hexagonal sleeve, decorated.
The second is 34 cm, hole 18 mm, weight 300 grams.
The longest 54 cm, hole 19 mm, weight 585 grams.
Center 48 cm, hole 18 mm, weight 340 grams,
The shortest 43 cm, the hole 17 mm, the weight 315 grams.
  • 3 weeks later...
Beautiful work,Ibor,simply incredible.
A couple of questions,if it's ok:Whence such cool-looking "fibrous" steel?(incredibly good-looking stuff!:)...Homemade?Old industrial stuff?...
Also:You seem to like that bright finish on most,if not all,of your stuff.Is there much historic evidence that it was normally done so in the past,or is it your own interpretation/preference?
Thanks,and keep up that great work!(And a Tremendous output!)
Respect,Jake
Good work Ibor. If you don’t mind me asking, how do you create/maintain the ridge in the middle of the blade? Thanks.
Jake welded pieces of old, fibrous iron into a rod and forge out of it, or if I have some bigger piece of it out of it.
I find them on the scrap.
As for finishing (shine or mat) I do it as iron tells me .... because it wants it anyway or maybe .... maybe it's stupid but many times i did something like i put it on but it was different ... just the material he wants is a spear from him it will be a spear and not an ax ....
Charlez spear forge on the side of the anvil and every now and then I put into the mold and hammer 5 kilos of wale..hahahah ....
Recipe for a spear with a "ridge" after the old.
1.Clean the hearth
2.Make a fire
3. Iron the 2.2 cm thick iron rod to flatness at one end
4.This flat end is formed in the sleeve
5. Move the rod under the "leaf" of the spear
6.Profile the leaf on the anvil
7. Apply the leaf in the form of a 5-kilogram hammer
8.During some time profiling on the anvil
Give your neighbor a sharp wooden pole.
Bon Appetit!
  • Like 4
:lol: Thanks Ibor
I do not know what to say that has not already been said. Your work is very impressive, especially when you consider:
On ‎8‎/‎20‎/‎2017 at 3:50 AM, Ibor said:
Zero  electric welding & zero power hammer.
I love the spears, and the fact that you do a lot of historical replicas is wonderful.
Thanks gentlemen!
Old iron, fibrous, is a fairly difficult material for forging due to contamination and frequent delamination of the material.
It is necessary to weld and weld it in high temperature, and therefore it must be brewed to not burn it.
I do not always like this, I often do the old iron, when it is warm in the cherry color, I calmly do not delicately ..... but unfortunately when the iron I want to pick up after acid picking "fiber bands" do not see them too well.
I do not use borax when I weld it and not once it happens that I burn ... it is difficult to do and I continue to do .....
I try to operate as easily as possible the tools and techniques that blacksmiths could use hundreds of years ago.
It gives me great pleasure and satisfaction ... and some financial income .... hahahah .......
