Warner Smith 12 Posted September 8, 2017 Share Posted September 8, 2017 (edited) So, my dream of one day making damascus blades seems to be more possible with the addition of a press. I'm thinking to make one like some of you guys have. Looks like it involves the purchase of a 20 ton air over hydraulic press from Harbor Freight, and the construction of a frame. I believe that I'll be able to obtain most if not all of the steel for the press from scraps from our machine shop here at work. We make print apply systems, and they have the applicators on these super strong bases. Sometimes parts from the bases gets scrapped, so I can get a couple of them pretty easily. The nice part is I would probably keep the T's in them to use for the sides of the press, saving me from having to get those pieces welded. It's pretty thick square steel.....not sure what kind (but I could find out from our machine shop) and they also have solid scraps, too, that could probably be used for make the ram. Here's a picture of one of the stands....you can see the various steel components. The steel on the base looks like 3 1/2" x 2 1/2". Thoughts on using this? To me it seems ideal....AND the price is right, too! Warner Edited September 8, 2017 by Warner Smith Link to post Share on other sites
Alan Longmire 3,887 Posted September 8, 2017 Share Posted September 8, 2017 Looks like thin-wall tubing from here, in which case no, it won't survive. You need heavy-wall, schedule 80 at a minimum. Presses generate forces that tend to result in catastrophic failure with little warning, even the little ones, because in a shop environment you usually can't hear the telltale creaking of iminent failure. 1 Link to post Share on other sites
Joël Mercier 720 Posted September 8, 2017 Share Posted September 8, 2017 1/4" thick 5" or 6" channels is ideal I believe. That's what the press at my shop is made of. 1 Link to post Share on other sites
Warner Smith 12 Posted September 8, 2017 Author Share Posted September 8, 2017 Ok...wow, I'll have to measure the thickness of that square tubing. I highly doubt it's anywhere near 1/4"....maybe closer to 1/8. It almost seems like it's WORTH it to just buy one from harbor freight, No? Warner Link to post Share on other sites
Joël Mercier 720 Posted September 8, 2017 Share Posted September 8, 2017 It may depend on your work space. Link to post Share on other sites
Alan Longmire 3,887 Posted September 8, 2017 Share Posted September 8, 2017 I really don't know much about the mini-presses folks have built, but on fully hydraulic ones 1/4" wall tubing is common. It is also always gussetted with 1/2" to 1" plate everywhere there is a weld. And that's on a 20 ton cylinder. Have you read the pinned thread on these mini-presses? 1 Link to post Share on other sites
TrentO 0 Posted December 4, 2017 Share Posted December 4, 2017 I built a coal ironworks style open face press with a 5hp motor and 11gpm pump. The main spine is W10-88 (10" wide, 88 lbs / foot). You want a lot of strength in a press to resist deformation. Link to post Share on other sites
Wes Detrick 493 Posted December 5, 2017 Share Posted December 5, 2017 Watching an i-beam flex under the forces that a press generates is a hell of a thing. “In the midst of winter, I found there was, within me, an invincible summer." -Albert Camus http://www.krakenforge.net/ Link to post Share on other sites
