Posted
Up to you, really.  The rigidizer will help keep it in place while adding the cement coat, but otherwise doesn't do much.
Posted
Ok cool, thanks for all you advise Alan.
Posted
You will want to back the burners up some.  Having the burner mouths inside of the forge chamber is a fast way to ruin them.  Back them out so that they sit inside of their mounting tubes and then mold the refractory so that it flares.
http://www.krakenforge.net/
Posted
You're going to want a largish hole in that door to allow the back pressure from the burners to dissipate.  Especially with three of those monsters! Two would suffice.  Venturi burners don't like back pressure.
Posted
Hi Alan,
You read my mind because that was my exact next question. I will be cutting 2 large square holes in the doors with rails for bricks to slide in a out of as needed.
Posted
Were it me, I'd make three cuts for the openings, top and two sides, then fold the "flaps" outward to make shelves
Posted
Hi Vern,
Do you have a pic or a drawing of this method?
Posted
It would just be cutting 3/4 of the rectangular opening, leaving the bottom un-cut and then bending the cut portion outward. If you really need a visual I could probably make a demo on a pop can by tomorrow morning.( got to plug in my device to charge ASAP)
Posted
I think I'm picking up what you are throwing down. I'm going to make the opening with rails that I can put firebricks in from of the opening.
Posted
Wool installed and rigidizer sprayed. Now wait 24 hours.
Posted
Is that 2 layers of 1" "wool" in there ?
Posted
That is a single 1 inch layer.
Posted
I take it that you will be adding a second layer?
Posted
I can but didn't plan on it. Not sure I can because it's already been rigidized right?
"Rigidizing" that layer does not preclude adding another layer, which, IMO, you need to do. I'd run the next layer at a right angle to the first layer.
Ps: I'd stagger the joints on the second layer
Edited by Vern Wimmer
Posted
Hi Vern,
Just so I know, why do I need another layer?
The general idea of the insulation, to put it simply, is to keep all of the heat generated by the burners in a somewhat confined place for efficiency and usability. Think of your kitchen oven. How well would it work if you were, say, baking something at 425 and your oven wasn't well enough insulated and the door was open ? It might be just a bit of a problem if you couldn't get within 6 feet of your oven . There is also the little detail of the insulating material, when used in sufficient quantity, allowing us to make forge bodies, and their attendant gas plumbing, relatively safe from the effects of temperatures we expect to rise to welding, and higher temperatures. Bringing the body of the forge and/or the gas plumbing to welding temperature is, as a medical friend says, "contraindicated".
Posted
Y'all don't happen to live in upstate New York ?
  • Haha 1
Posted
Awesome thank you Vern, I ordered another roll of wool last night.
Posted
Remember to insulate your doors as well. Left unprotected they will absorb a lot of heat and transfer it to the forge shell/body.
Double tapped all on its own.
Posted
I have an entire pallet of wool if you need some to finish up send me a PM and we can work something out. Your only 40 miles away from where I'm located
Posted
Shoot man, I just ordered a roll last night. Thank you very much though.
