Kreg Whitehead 50 Posted November 17, 2017 Share Posted November 17, 2017 I have ALOT of spare time at work.....and earlier today on facebook someone put up a pic of their 2x42 grinder similar to mine....different brand. Someone suggested he cut the sides of it......or maybe I assumed it was the sides. I better go recheck. The edges of my platen are rounded....should I cut em square. It isnt even parallel to the belt. My plunge lines arent symmetrical because of that. I was gonna try and shim it square before I grind my next blade....but if it needs cut I will just cut it square. Link to post Share on other sites
Kreg Whitehead 50 Posted November 17, 2017 Author Share Posted November 17, 2017 My guess is that if it was square instead of rounded it will be harder to grind too far in to the ricasso....if that makes sense. Link to post Share on other sites
Mason Simonet 54 Posted November 17, 2017 Share Posted November 17, 2017 I have a 2x42 craftsman. All I did was jb weld a hardened peace of 2” 1080 steel on top of the old platen... it’s likely the platen on yours is mild steel, so you would need to eventually upgrade it to a hardenable steel anyway. If you want to keep it with the original platen, then it really depends on how rounded the edges are. slightly round edges will give you a nice rounded plunge line, although I prefer square edges then use a flex belt to round the plunges. Link to post Share on other sites
Kreg Whitehead 50 Posted November 17, 2017 Author Share Posted November 17, 2017 10 minutes ago, Mason Simonet said: I have a 2x42 craftsman. All I did was jb weld a hardened peace of 2” 1080 steel on top of the old platen... it’s likely the platen on yours is mild steel, so you would need to eventually upgrade it to a hardenable steel anyway. If you want to keep it with the original platen, then it really depends on how rounded the edges are. slightly round edges will give you a nice rounded plunge line, although I prefer square edges then use a flex belt to round the plunges. I like that plan....thanks. Sounds MUCH easier than cutting the existing one...and I can get it parallel to the belt. Link to post Share on other sites
Jason McEntee 57 Posted November 17, 2017 Share Posted November 17, 2017 17 hours ago, Mason Simonet said: I have a 2x42 craftsman. All I did was jb weld a hardened peace of 2” 1080 steel on top of the old platen... it’s likely the platen on yours is mild steel, so you would need to eventually upgrade it to a hardenable steel anyway. I had the same issue with the platen on my Kalmazoo 2x72, and I did similar to this to fix it. I used a pair of 1" platens from my 1x30 machines. Worked out great. Link to post Share on other sites
Joel Minturn 0 Posted November 17, 2017 Share Posted November 17, 2017 19 hours ago, Mason Simonet said: I have a 2x42 craftsman. All I did was jb weld a hardened peace of 2” 1080 steel on top of the old platen... I have that same grinder and one of the videos on practical upgrades for that grinder recommended using a 2" wide bit of smooth ceramic tile. In this end it does that same thing. Link to post Share on other sites
