IMPORTANT Registration rules Read more... ×
Jeremy Blohm
Giant Tinsmith Snips
Picked these up at auction for $12
the picture doesn't do them justice. These things are huge!!!
They're called "stock shears" and are meant to have that long dropped leg inserted into a hole in the bench so you can use both hands.  Good price!
Something like a pexto plate mounted in a bench?
That, or just a hole.  Maybe with a steel collar.  Most of the lower handle should rest on the bench with just the jaws hanging off.
By the way, those are on the small side. ;)  I've seen them up to four feet long with one-foot jaws.
What are they used for Alan? What kind of stock are they made for cutting??
Sheet metal, copper, iron, tinplate, whatever you have!  That one is probably good up to 18 gauge mild steel, 12 gauge copper.
Hmm, since the years have made my toenails get really thick....
if you are not too worried to mess them up a bit, I have seen blacksmiths use these to hot-cut steel.B)
they simply stuck the square shank in the hardy and snipped off all the steel that was not needed.
its a lot quicker than a traditional hardy and you don't risk messing up your hammer.
That would be great if you hot cut the clip in a Bowie as part of the preform.
I've tried to find a video of someone using a set of these but i have had no luck.
I also think this is odd since I was just searching for an example of these shears in use today.   Somehow in the land of youtube this has not been done yet.  If anyone knows of a video please enlighten us.  =)
It’s sad to use them on hot steel. They are a fine tool for fine work. Sell them and buy an import bench shear.
I agree with sam i wouldn't use them on hot steel. Sam you wouldn't happen to know of any videos of a set of these bad boy's in use?
I will stick to using my crappy hammer and my hardie hot cut.
So I found a video with a guy using a pair of these. A little over half way through the video of this guy forging a Damascus ring.
5 minutes 18 seconds into the video.
Edited by Jeremy Blohm
