Daniel Cauble 77 Posted December 16, 2017 Share Posted December 16, 2017 (edited) **NOTE: My memory of some things is a little foggy. This project was ongoing and posted on my IG with some details not here I imagine @caublestonecutlery This is about 30% of the steel I made this year. Some of it didnt make the cut as I was experimenting and testing different parameters of the furnace and run. Average spark of this seasons orishigane The puck that the spark belonged to Cut puck in half. Rather porous to be expected, but still very dense Polished and etched to show dendritic structure Edited December 16, 2017 by Daniel Cauble Link to post Share on other sites
Daniel Cauble 77 Posted December 16, 2017 Author Share Posted December 16, 2017 (edited) Spark test showing extremely high levels of carbon Very neat puck. This one showed a gradient of cast to steel. Break on the edge indicated cast Spark test of steel portion Another steel portion As we move into the cast region the spark starts to turn red and shorten Another very short reddish spark Cast Steel Here is a sample piece from same puck showing gradient Not really sure why i posted two of identical pic. Fuzzy pic of same piece etched Better pic of etched surface Time to cold break with 12# sledge Fractured like glass Polished and etched a sample More dendritic structure Beautiful colors Edited December 16, 2017 by Daniel Cauble 1 Link to post Share on other sites
Daniel Cauble 77 Posted December 16, 2017 Author Share Posted December 16, 2017 (edited) One half of the first puck made into a plate, hardened and broken Beautiful break and grain Sparkin high This is half of the very colorful puck. With the higher carbon and mix of cast, wroughting was a chore but worked Very intense spark. 1.5%C+ by estimation. Probably in the 1.7-1.9 This came from a different puck, it was from an experiment with Al Hard to see, but fully dendritic Edited December 16, 2017 by Daniel Cauble 1 Link to post Share on other sites
Daniel Cauble 77 Posted December 16, 2017 Author Share Posted December 16, 2017 (edited) Very high spark. Length of sparks shortening quite a bit Some of this went in the bar, some of the rest went into a crucible Parts of it was clearly at or above 2%C 1.8-1.9%C This truly is beautiful steel Odd how the colors remain even after forging Edited December 16, 2017 by Daniel Cauble Link to post Share on other sites
Daniel Cauble 77 Posted December 16, 2017 Author Share Posted December 16, 2017 (edited) This puck was a good study The blue, clean surface. The blue color is indicative of hearth steel It cast a beautiful spark. 1.5% range by estimation This guy was a 5# monster Very big 1.7'ish Cast Edge of cast A great shot of my fingerprint Edited December 16, 2017 by Daniel Cauble 1 Link to post Share on other sites
Daniel Cauble 77 Posted December 16, 2017 Author Share Posted December 16, 2017 (edited) Squishing some of this into plates Showing that even at this high %, it is carefully forgeable for plates. The grain on this, which is the massive puck is so close to cast It was a feint gray in color. 1.8-1.9%C by estimation Sparks also indicates this 1.8-1.9%C Very short, not far from turning red. Another broken plate from a different puck It was an eventful day. I was sore, but very zen. Not bad. Not all of my material of course. Just a random pic of a random plate Bottom right chunk is Grade 1/b Tamahagane. The rest is mine. The big bar is 6 fold orishigane made by me. It is waiting to combine with this next bar. The small bar to the left is 12 fold bloom iron for the eventual core. Edited December 16, 2017 by Daniel Cauble Link to post Share on other sites
Daniel Cauble 77 Posted December 16, 2017 Author Share Posted December 16, 2017 (edited) I found out a Lowes 20 miles away had 3k firebrick. So I decided to make a traditional japanese side blown Needed a table made for this. You got that right. I had a little guidance by from a friend of a Japanese Swordsmith for the construction. The EPK clay I washed it down with was cured I wanted to leave as much ash as possible This i gently packed down More pure ash added Wetted and packed in further Rod for tekogane plate Even some japanese sword smiths use Borax for this step. A mix of some borax and rice straw ash, along with Japanese rice paper to wrap. It wraps well. No wonder they use this. Coated in more rice straw ash Clay slurry I created a year ago when these endeavors began Literally first forging in this new forge was this project. Feel confident. The confidence was somewhat warrented, and also not. I lost about 1.5# of material into the forge, as the rod was made of orishigane, and that was my mistake. Not shown in the pics is the creation of the rod, made of material like the rest of the sword material. So it melted. Not to panic, I had the rod from the previous half and it was made of wrought iron with a much higher melting point. At this point there was no fuss, and I wire welded it to my bar that was now 1.5# lighter. It consolidated well however. As you can see I went on to fold this bar, alternating my cut and fold width wise, and length. This is a lengthwise fold Clean bar. 5 folds (Ran out of charcoal for a 6th). I will fold this 1 more time, and then stretch and cut in half, and doing the same with the bar from last year, combine them all to fold together another 6+ times. Even after 5 folds, the carbon level is very intense. Yep Edited December 16, 2017 by Daniel Cauble 1 Link to post Share on other sites
Daniel Cauble 77 Posted December 16, 2017 Author Share Posted December 16, 2017 That's it for now. Other projects have pulled my attention. Link to post Share on other sites
Alan Longmire 2,648 Posted December 16, 2017 Share Posted December 16, 2017 That is a heck of a lot of work, man, but it looks like you're well on the way! Love those blue pockets in the tamahagane. Nicely done. Link to post Share on other sites
Daniel Cauble 77 Posted December 16, 2017 Author Share Posted December 16, 2017 Thanks. Its a ton of fun. A lot of work and practice has lead to this The blues were actually in my orishigane. The grade 1/b tamahagane is just meant for my own study. Link to post Share on other sites
Daniel Cauble 77 Posted December 16, 2017 Author Share Posted December 16, 2017 This is video of my work on this last year. Link to post Share on other sites
Daniel Cauble 77 Posted December 16, 2017 Author Share Posted December 16, 2017 Again, last year making the first half of this blade. Link to post Share on other sites
Joshua States 1,670 Posted December 24, 2017 Share Posted December 24, 2017 (edited) Fascinating Captain. It looks like you had quite a number of smelts + remelts in this endeavor over what, a year or more? I admire the tenacity. Edited December 24, 2017 by Joshua States Link to post Share on other sites
Caleb Harris 51 Posted December 24, 2017 Share Posted December 24, 2017 This is impressive! Are you drawing it out at welding heat each time at this stage? Link to post Share on other sites
Dan Waddell 11 Posted December 24, 2017 Share Posted December 24, 2017 I like all the pics of stacked plates. I'm sure it's even more satisfying for you to look at! Is your feed stock all wrought / bloom iron? Link to post Share on other sites
Daniel Cauble 77 Posted December 24, 2017 Author Share Posted December 24, 2017 Each heat is basically a fold, so yea welding heat. It may get a quick low heat at the actual folding the bar over part as it is a bear to bend and work such a high carbon steel. Once tbe temps cool down cool enough as the bar is being drawn out, it feels like a thick bar of W2 or mildly the same resistance something like crucible will give the hammer. The first half i worked last year was a tremendous amount of work. I was developing my methodology while also figuring out how to get the steel the cleanest. The first half was made from melted wrought and some had bloomery bits in it. Except after reading aristotles accounts of steel in his version of a furnace, i learned that if i took the material i melted once already and melted it again, i would have a cleaner steel that had a higher homogenity in carbon. Which it did. The only drawback was the return in steel quantity was greatly diminished. I think the first bar had probably 12 melts worth of steel in it. Which incudes the remelts of the melts. Between that bar and this bar i made a fair amount for testing and even made some for trades with other smiths. Then i took a break ajd started working on other projects. Charcoal is expensive, and i get bored of making charcoal in the retort. I revived this project after spending the day at Jesvs's old house on top of the mountain. He had a lot of spare crane cable, and implored me to use it in remelts. So this past spring i decided to do probably another 20 melts or so testing out one parameter of the furnace to another. I even ran into some problems that required me to have a neureaka moment while reading Art of the Japanese Sword. This last bar is made from remelted crane cable for the most part and my hope is that the differing feed materials may lend to a contrasting hada on the blade in the end. Ive found that the feed material isnt all that important. I still have tk send pieces for analysis, but my suspicion is that the remelt process at least strips the steel of Mn in the melt. My testing with the remelts over time have indicated this. Ive melted 1018 that had .8Mn per spec sheet, and the resulting 5 fold steel example was as shallow as you would expect from Mn devoid steels. The modern steel remelt also did not require a 2nd or 3rd remelting to achieve the cleanest steel possible either. It all folds and sticks to itself like a dream. Link to post Share on other sites
Daniel Cauble 77 Posted December 24, 2017 Author Share Posted December 24, 2017 I think you have seen a lot of this live on my IG Caleb. Link to post Share on other sites
Daniel Cauble 77 Posted April 23, 2019 Author Share Posted April 23, 2019 (edited) Have been working on the ability to push carbon into high carbon steels to make them higher carbon steels using higher carbon orishigane and carbon migration principles laid out by Verhoeven. This orishigane was pulled from the furnace and knowing how well I can make ultra high carbon steel from one end of the puck to the other, used the entire mini-bloom of orishigane. Folding was conducted using my own formulation of mud and rice straw ash. From there it was folded 9 times and laid to rest until I was ready to use it. The spark yielded a rather high carbon spark. Much higher than W2, so I set out to sanmai weld W2 with orishigane at mid to high temp welding heats with soak in hopes of pushing carbon into the W2. Then drawn out into a billet to be used as core material. From there I constructed a sanmai with this material and my usual 1018 mild jacket. This time using a lower temp forgeweld to mitigate migration into the mild. Drawn out and a gyuto was made. Hardened using japanese Ht techniques and just got done machine grinding it. On to hand sanding. Unfortunately I dont have time to make this a kasumi style kitchen knife and stone polish it like I really wanted to as this is going to Bladeshow and I dontnhave time. So sandpaper, loose abrassives and etchants it is. Edited April 23, 2019 by Daniel Cauble 1 Link to post Share on other sites
Alan Longmire 2,648 Posted April 23, 2019 Share Posted April 23, 2019 Looks good! Link to post Share on other sites
Joshua States 1,670 Posted April 23, 2019 Share Posted April 23, 2019 2 hours ago, Daniel Cauble said: Unfortunately I dont have time to make this a kasumi style kitchen knife and stone polish it like I really wanted to as this is going to Bladeshow and I dontnhave time. So sandpaper, loose abrassives and etchants it is. What? No house elves? Looks great Daniel. Link to post Share on other sites
SteveShimanek 112 Posted April 23, 2019 Share Posted April 23, 2019 Lots of good work there. Link to post Share on other sites
Daniel Cauble 77 Posted May 7, 2019 Author Share Posted May 7, 2019 I said screw it and started polishing it for kasumi anyway (japanese natural stone polish). Long way to go :0 1 Link to post Share on other sites
Daniel Cauble 77 Posted May 15, 2019 Author Share Posted May 15, 2019 Some micrographs of the core steel. The core steel is again W2 sandwiched between orishigane. A few show the clean weld of the two disimilar metals. I need to obtain a few more etchants to show grain boundaries. 1 Link to post Share on other sites
Joshua States 1,670 Posted August 23, 2019 Share Posted August 23, 2019 Nice! Someday, I will make some steel Link to post Share on other sites
Daniel Cauble 77 Posted August 23, 2019 Author Share Posted August 23, 2019 It's an obsession I've fine tuned for over 6 years now. I've started micrographing my steel from the raw hearth steel. My results compliment findings in historically produced steels found by archaeologists which is neat. I am currently poised to be assisting in creating a large database of structures for other researchers to use. Lately I have pushed my furnace to cross the 2% C threshold and making larger quantities of white cast to be mixed and blended into my steel. Once carbon starts to cross 2%, ledeburite starts to form and the material starts to become a ceramic. Link to post Share on other sites
