David Forsman 7 Posted December 31, 2017 Share Posted December 31, 2017 Im interested in participating in the 2018 kith. Would a project done exclusively in stock removal be acceptable for the kith? Link to post Share on other sites
Joshua States 2,500 Posted December 31, 2017 Share Posted December 31, 2017 I vote yes. As I said in the other thread, there are no "standards" to meet in the KITH other than make something that fits the theme and do it to the best of your abilities. If stock removal is what you do, then do the best damn stock removal you can manage. Just my nickel's worth. 1 “So I'm lightin' out for the territory, ahead of the scared and the weak and the mean spirited, because Aunt Sally is fixin’ to adopt me and civilize me, and I can't stand it. I've been there before.” The only bad experience is the one from which you learn nothing. Josh http://www.dosgatosdesignsllc.com/#! https://www.youtube.com/channel/UCdJMFMqnbLYqv965xd64vYg J.States Bladesmith | Facebook https://www.facebook.com/dos.gatos.71 https://www.etsy.com/shop/JStatesBladesmith Link to post Share on other sites
Pieter-Paul Derks 316 Posted December 31, 2017 Share Posted December 31, 2017 I also have no problems with stock removal, part of the fun is seeing different approaches to the same theme. http://mefecit.nl/ Link to post Share on other sites
David Forsman 7 Posted January 1, 2018 Author Share Posted January 1, 2018 Thanks for your encouraging words. I plan on participating this year for sure now unless the theme ends up being something well outside my wheelhouse. Link to post Share on other sites
Jeremy Blohm 575 Posted January 1, 2018 Share Posted January 1, 2018 Magic theme is ahead by a long shot and by tomorrow it will be set in stone (or steel) that the magical edged blade is the 2018 KITH theme. Link to post Share on other sites
Jeremy Blohm 575 Posted January 1, 2018 Share Posted January 1, 2018 Stock removal has me thinking about borrowing a plasma cutter and going all out with some crazy design. What high carbon steel would you get in half inch sheets? Link to post Share on other sites
Geoff Keyes 672 Posted January 1, 2018 Share Posted January 1, 2018 I think it's more of what kind of steel can I get in .500, rather than what kind. Aldo has 5160 in .750 and .375, but no .500. If you want .500, you may have to break down thicker stock to get it. g "The worst day smithing is better than the best day working for someone else." I said that. If a thing is worth doing, it is worth doing badly. - - -G. K. Chesterton So, just for the record: the fact that it does work still should not be taken as definitive proof that you are not crazy. Grant Sarver Link to post Share on other sites
Jeremy Blohm 575 Posted January 1, 2018 Share Posted January 1, 2018 (edited) 15 minutes ago, Geoff Keyes said: I think it's more of what kind of steel can I get in .500, rather than what kind. Aldo has 5160 in .750 and .375, but no .500. If you want .500, you may have to break down thicker stock to get it. g There has to be some kind of 4x8 sheet of high carbon steel. http://www.angelswords.com: "supposedly" uses s7 to CNC machine blades Edited January 1, 2018 by Jeremy Blohm Link to post Share on other sites
Geoff Keyes 672 Posted January 1, 2018 Share Posted January 1, 2018 First of all, S7 is hardly high carbon steel (it's some kind of steel like material from hell). Second, I don't know what they start with for size. Third, if Angel Sword told me it was raining, I'd step outside and see if I got wet. Check out The NJ Steel Baron and see what he has. Whatever it is, it's gonna cost ya. Geoff 2 "The worst day smithing is better than the best day working for someone else." I said that. If a thing is worth doing, it is worth doing badly. - - -G. K. Chesterton So, just for the record: the fact that it does work still should not be taken as definitive proof that you are not crazy. Grant Sarver Link to post Share on other sites
Jeremy Blohm 575 Posted January 1, 2018 Share Posted January 1, 2018 10 minutes ago, Geoff Keyes said: First of all, S7 is hardly high carbon steel (it's some kind of steel like material from hell). Second, I don't know what they start with for size. Third, if Angel Sword told me it was raining, I'd step outside and see if I got wet. Check out The NJ Steel Baron and see what he has. Whatever it is, it's gonna cost ya. Geoff That's why i used "" with supposedly because i dont believe anything he says but i kinda figured he was using some sort of high carbon steel. How its made had a show about CNC machined swords and they were high carbon steel. I was kinda hoping to get it at my local steel supplier or at least have them order it and that might save me some on shipping, i just want to know what to ask for. Link to post Share on other sites
Zeb Camper 787 Posted January 1, 2018 Share Posted January 1, 2018 5 hours ago, Jeremy Blohm said: That's why i used "" with supposedly because i dont believe anything he says but i kinda figured he was using some sort of high carbon steel. How its made had a show about CNC machined swords and they were high carbon steel. I was kinda hoping to get it at my local steel supplier or at least have them order it and that might save me some on shipping, i just want to know what to ask for. 3 words... Foam, sword, fight. I have not forgotten. I will defend my honor! Link to post Share on other sites
Vern Wimmer 487 Posted January 1, 2018 Share Posted January 1, 2018 11 hours ago, Jeremy Blohm said: There has to be some kind of 4x8 sheet of high carbon steel. http://www.angelswords.com: "supposedly" uses s7 to CNC machine blades OH, NO YOU DIN'T ! Link to post Share on other sites
Jeremy Blohm 575 Posted January 2, 2018 Share Posted January 2, 2018 19 hours ago, Vern Wimmer said: OH, NO YOU DIN'T ! Oh YEAH Link to post Share on other sites
David Forsman 7 Posted January 2, 2018 Author Share Posted January 2, 2018 I used a cnc to mill a taper into a blade once. It worked well but I went through several sets of teeth on the shell mill. Not the cheapest method by far. Im not sure if the steel was fully annealed though. Link to post Share on other sites
Joshua States 2,500 Posted January 2, 2018 Share Posted January 2, 2018 On 12/31/2017 at 11:53 PM, Jeremy Blohm said: Stock removal has me thinking about borrowing a plasma cutter and going all out with some crazy design. What high carbon steel would you get in half inch sheets? What on earth are you thinking of making that would require a thickness of .500? A magical hammer? A magical prybar? “So I'm lightin' out for the territory, ahead of the scared and the weak and the mean spirited, because Aunt Sally is fixin’ to adopt me and civilize me, and I can't stand it. I've been there before.” The only bad experience is the one from which you learn nothing. Josh http://www.dosgatosdesignsllc.com/#! https://www.youtube.com/channel/UCdJMFMqnbLYqv965xd64vYg J.States Bladesmith | Facebook https://www.facebook.com/dos.gatos.71 https://www.etsy.com/shop/JStatesBladesmith Link to post Share on other sites
Jeremy Blohm 575 Posted January 2, 2018 Share Posted January 2, 2018 5 minutes ago, Joshua States said: What on earth are you thinking of making that would require a thickness of .500? A magical hammer? A magical prybar? Some huge spartan sword? I havent figured it out yet but if im going stock removal im going all out. But we are a bladesmiths forum so im going to keep it traditional and make a spear or dagger or seax or ??? Link to post Share on other sites
Vern Wimmer 487 Posted January 2, 2018 Share Posted January 2, 2018 6 minutes ago, Joshua States said: What on earth are you thinking of making that would require a thickness of .500? A magical hammer? A magical prybar? "Lug wrench of the Demon Studebaker" 2 Link to post Share on other sites
Jeremy Blohm 575 Posted January 2, 2018 Share Posted January 2, 2018 4 minutes ago, Vern Wimmer said: "Lug wrench of the Demon Studebaker" This theme is throwing me for a loop. It seams some people have a talent for thinking outside the box i just cant come up with anything. Link to post Share on other sites
Vern Wimmer 487 Posted January 2, 2018 Share Posted January 2, 2018 3 minutes ago, Jeremy Blohm said: This theme is throwing me for a loop. It seams some people have a talent for thinking outside the box i just cant come up with anything. How about "the watch-fob penknife of Father Time "? Link to post Share on other sites
Charles dP 589 Posted January 2, 2018 Share Posted January 2, 2018 Completely OTT but do an images search on dungeons and dragons magic weapons for some inspiration 1 "The way we win matters" (Ender Wiggins) Orson Scott Card Nos, qui libertate donati sumus, nes cimus quid constet. Link to post Share on other sites
Jonathan Silas 40 Posted January 2, 2018 Share Posted January 2, 2018 1 hour ago, Charles du Preez said: Completely OTT but do an images search on dungeons and dragons magic weapons for some inspiration Stop, I can only get so excited.... Link to post Share on other sites
Alan Longmire 3,767 Posted January 2, 2018 Share Posted January 2, 2018 Personally I think Studebakers are fairly magical... Link to post Share on other sites
Joshua States 2,500 Posted January 3, 2018 Share Posted January 3, 2018 7 hours ago, Jeremy Blohm said: This theme is throwing me for a loop. It seams some people have a talent for thinking outside the box i just cant come up with anything. Just pick up a book on mythology. Any mythology will do. Within the first couple of chapters you will have at least a half dozen magical items to choose from. Or ask the great Google for a list of magical weapons in ancient lore. 1 “So I'm lightin' out for the territory, ahead of the scared and the weak and the mean spirited, because Aunt Sally is fixin’ to adopt me and civilize me, and I can't stand it. I've been there before.” The only bad experience is the one from which you learn nothing. Josh http://www.dosgatosdesignsllc.com/#! https://www.youtube.com/channel/UCdJMFMqnbLYqv965xd64vYg J.States Bladesmith | Facebook https://www.facebook.com/dos.gatos.71 https://www.etsy.com/shop/JStatesBladesmith Link to post Share on other sites
Jon Cook 55 Posted January 3, 2018 Share Posted January 3, 2018 Discworld? It's basically mediaeval Europe. Lord Ventenari's stiletto? Carrot's dirk? Damascus from DEATH'S motorcycle? Just throwing out ideas to hopefully get the wheels turning. 1 Link to post Share on other sites
Doug Crawford 32 Posted January 3, 2018 Share Posted January 3, 2018 1 hour ago, Jon Cook said: Discworld? It's basically mediaeval Europe. Lord Ventenari's stiletto? Carrot's dirk? Damascus from DEATH'S motorcycle? Just throwing out ideas to hopefully get the wheels turning. Death of Rats Scythe! 1 Link to post Share on other sites
