IMPORTANT Registration rules Read more... ×
Mark Tuck
buffing compound
Hey guys I'm working on putting mirror finishes on  couple of knives and I was wondering what kind of  compound to buy? I always take the blades to 1000 grit on my belt sander.
I hand sand mine up to 3,000 "paper" (more of a spongey pad) from Advanced auto parts. Its still not a true "mirror" polish, but I don't think that's even possible on steel.
Hand sanding gets a finer finish than belt sanding IMHO and at 1,000 grit I don't think you're ready for compound yet. Lots of people use "Mother's Metal polish" and rotten stone for hamons. I just use the 3,000 grit paper though.
You are going to want to go higher than 1000 grit, 2000 at the minimum.  I would suggest a green compound, which is supposed to polish hard and soft steels.  If you look up "stainless steel polishing compound", green compounds come up.  I am not a big fan of mirror finishes, so I don't do them, but to each their own.  Good luck with it!
For a full mirror finish you will want at least three compounds and different wheel types.  Jantz Supply has a good description of the process in their catalog.  They recommend starting from a machine finish 1000 grit to a sisal wheel with an emery-based cut-and-color compound followed by a felt wheel and a green compound for stainless, white diamond for non-stainless, and finally red rouge on a loose muslin wheel.
Never forget the buffer is the most dangerous tool in the shop and is trying to kill you at all times!
Sorry for the hijack and newbie question, @Alan Longmire what is so dangerous about the buffer?
They have a tendency to grab onto whatever you are buffing, and throw it at high speed.  Even if you are being very careful to make sure a knife would get thrown away from you rahter than into your groin or chest, the act of ripping the blade out of your hand can cut some finger off.
Maybe buffers should be added to that list of "Things you don't realize can kill you"
When I took machine tool our instructor showed us pictures of a guy with a Phillips head screw driver lodged into his pelvis. He had been polishing the rust off, had it ripped out of his hand and straight into his crotch. Very sobering lesson to a bunch of teen boys let me tell you.....
Knifemaker Gordon Dempsey was killed in his shop when a buffer grabbed a knife he was working on, threw it at him and pierced his heart.  That is why I will only use the bottom half of the wheel turning away from me.
I’m beginning to see, thanks all.
Spot on correct Wes if your blade is above the center line of the buffer you run the risk of having it thrown back at you...Personally in addition to keeping the blade below the center line of the buffer I make sure my body is never directly infront of the buffing wheel...Ie...I stand off the the side a bit
I don't buff blades, but I have had a briar pipe bounce off my shoulder and somewhere in the garage there's a sterling silver pin I never found.  And that's with a slow speed machine running around 1100 rpm.  Don't know if I'm man enough to use one that runs at 3200 rpm...:ph34r:
Before I realized how dangerous they were I had built a couple because I thought I had to use them. THEN I was warned about them. THEN I had my first "organic learning experience". After I changed my pants I reevaluated my needs, changed my methods and restricted my use to "If there isn't another way and only in the most cautious manner possible". It is NOT a case of "if" they are going to rip something out of your hands but "When" is it going to happen? I never get anything above the lowest 1/3 of the wheel and prefer to have it set up diagonally on a corner of the table with nothing under the wheels so when it happens the blade is, hopefully, flung  unimpeded far away with as little chance of a bounce back as possible. When I get a chance I'll post a pic of my "buffing station".
ETA: I am looking to hear from 'Smith's who have used the cork, and other polishing belts, on their grinders.
Edited by Vern Wimmer
Fortunately I saw enough warnings on this subject, and still I got caught.
Even if you are lucky and don't get hurt, blades don't like being thrown like that.  Considering where you are in the process when polishing, it's never good.
My belt grinder is one of those models with a belt on one side and a stone on the other, stone is long gone and I've been meaning to make and fit a MDF/Superwood wheel on the open side to use for sharpening.
Fortunately a friend did some reading on that and thankfully pointed out you need to approach the machine from behind when doing this, so the wheel turns away from you.
I think Gil Hibben was injured really bad (nearly died from bleedout, I heard) when a buffer threw a blade into his thigh and nicked his femoral artery.
Is it not better to have the wheel on the end of the motor that makes it run backwards (if you cant reverse the polarity) and then you can work on the top of the wheel with any 'caught and thrown' objects will automatically go away from you.
That's the thing, though:  Once the wheel catches something it tends to take it all the way around, or at least 180 degrees.  I buff on the bottom third with the wheel running towards me from the top.  When it throws things, they come off the top in a high arc.
One way around that would be to rig up an adjustable guard to sit very close to the back side of the wheel. In theory it would catch and deflect anything that the wheel grabs and tries to pull around.  Then you would be able to buff on the top side of the wheel with it turning away from you, and anything that the wheel catches "should" hit the guard and end up behind the machine.   You just have to remember to keep the guard adjusted tight to the wheel as it wears away.
I only buff bronze blades. But if I do, I use a hand drill with cotton wheel, and clamp the blade  so it can't go anywhere. The only downside is that you sometimes slip off the blade, and the drill head scratches the blade. I've taped that, to stop the damage if that happens. I prefer having the blade fixed, and the drill doesn't have as much energy to throw things like a bench grinder does, which is basically a flywheel.
Aside from that, I've just learned of polishing pads, that on steel blades I find give a much better finish. My girlfriend had them for jewellery making. I've played with a small patternwelded blade I made earlier, and used the pad to polish up the pattern. The pad I used is a 3M Microfine CT2. I always found that at a 2000 grit, I'd get a very matte finish particularly on steel, and wanted to buff to bring out the shine. But with that type of pad, no buffing is needed. I've read that the grit is 1200/1500, but the finish is much better then 2000 grit sandpaper.
Good tip, Jeroen!  Alex, I and most folks have a setup with a board kind of backing up the wheels, and it does tend to deflect the larger objects into the wall (where they bounce right back!), but small stuff tends to get caught between wheel and guard.  This acts like a pitching machine by accelerating and adding backspin to the throw.  That's why I've never found that silver pin.  I heard the "ka-zing!!!" as it shot past my ear, and the pop and clatter as it bounced off the far wall and under the benches and possibly into another dimension.
I almost bought a buffer off my boss. Now I know why I don't need one :) I much prefer not to get stabbed at a high rate of speed. This makes me question my grinding practices....
Fair enough Alan.  I hadnt thought about small things like pins.  They can be just as deadly as a blade at high speeds.  We use large stand alone wire wheels at work to take oxidization off the edge of laser cut parts.  You have to keep the guards adjusted right or the SOB will suck the parts right out of your hands and spit them back at you.
If you want that mirror finish on stainless use the PINK buffing compound that K&G in Arizona sells ,use with a loose buff wheel as a final buff.
I'm going to check those 3M pads out.
Loose buffing wheels in a buffer are the epitome of "danger".
Yeah, but a loose (i.e. unsewn muslin) wheel gives the finest finish.  Like I said, I do buff pipes and jewelry, and sometimes knife handles.  Not blades, but only because I'm not into a mirror finish on steel.  Wood and silver, oh, yeah!
I really don't mean to discourage people, I just want them to be aware of the danger that lurks for the unaware or, even worse, the complacent.  Buffers have a way of lulling you into a sense of security before trying to take your head off.  Never let your guard down, and always listen to that little voice that says "are you sure this is a good idea?" when using one.  Oh, and never buff loose chain.  Unless you want to be known as Ol' Three-fingers.  That's more of a jewelry thing, but again, I want folks to be aware.  If you have to buff a chain, wrap it tightly around a dowel rod first, and buff on the rod.
A buffer is a tool, and a good one. It is dangerous- but it doesn't have to be dangerous to you if you know what you're doing. A lot of people have good tips- my personal addition is let the wheel, and the compound, do the work- not pressure.
