Posted
As "Old Man Winter" is hanging on,  I have  gotten into the habit of running the forge for at least  a couple  of hours the first thing in the morning just to  warm the shop even though I have plenty to work on without do more forging.
Recently I got permission from my friend Jean-louis Regel to reproduce in my opinion one of his most beautiful Damascus patterns and thought that some of you might be interested  in how I  go about it.
I didn't want to ask him to go through all  of the steps that he used to get the pattern as it  is fairly complicated one but as best that I can figure out from a photo of one his knives,  this is how it should be made:
A= 1/8" 1080(1084)
B= 1/16" 15N20
Welded pieces referred to as  "Billet"
1)The initial stack:
AA-B-A-B-A-B-A-B-A-B-A-B-A-B-A-B-AA
2)  Once welded cut into  two  pieces 1 1/2" wide x ?  &  stack:
     AA-Billet-AA-Billet-AA
3)  Do a "W" squeeze and forge to 1 1/2" wide
     Then cut into five equal length pieces & stack:
     Billet-A-BB-A-Billet-A-BB-A-Billet-A-BB-A-Billet-A-BB-A-Billet
4)  Weld and then square on the bias
     Orient so that the internal lines direct toward the center, 4-way & weld
5)  Tile cut & weld
I'm fairly certain that I won't recreate the pattern perfectly as every piece of my Damascus is always unique and has  some degree  of distortion but hopefully it will turn out  something like  this:
jean-louis damascus_opt
Here's my initial stack:
IMG_7097_opt
Once welded I cut it in two  and added more 1080 to  the stack:
IMG_7099_optIMG_7101_opt
To this I flipped  it 90 degrees and did a "W" squeeze drawing it out to 1/2" x 1 1/2" x whatever.
IMG_7104_opt
This I cut into  five equal lengths and stacked:  Billet-A-BB-A-Billet-A-BB-A-Billet-A-BB-A-Billet-A-BB-A-Billet
IMG_7107_opt
This stack was too  thick to go through the door of my  forge so  I  welded it in three parts and then combined them:
IMG_7108_opt
The next step  was  to square this billet  on the bias:
IMG_7111_opt
This is where I stopped for  the day.  I'll try to keep  you updated with more as I progress with this one.
Gary
ABS,CKCA,ABKA,KGA
Posted
Nice. Does the pattern have a name?
Posted
Not that I know of.  I don't believe that I've ever heard Jean-louis apply a name to any of his patterns.  It's pretty isn't it?
Gary
ABS,CKCA,ABKA,KGA
Today I got the billet squared on the bias, drawn out, surface ground & 4-wayed.  Tomorrow hopefully I'll get the second 4-way done and be ready to tile cut.  (the x's on the four pieces are for orientation since the pattern is  directional)
IMG_7115_optIMG_7117_optIMG_7118_optIMG_7126_opt
Edited by Gary Mulkey
Gary
ABS,CKCA,ABKA,KGA
Posted
Absolutely
Posted
6 minutes ago, Charles du Preez said:
Absolutely
If I can get even close to  what Jean-louis had I'll be extremely happy.
Gary
ABS,CKCA,ABKA,KGA
Posted
I’m sure you will. Looking at that first picture, I would love to see the evil twin of this (A&B swapped).
Posted
I missed this post Wednesday, but I'm glad I caught it now.  The pattern in that first pic is incredible.  I'm eager to see the Mulkey version of it!
-Brian
Posted
Me too !!..........B)
If ya can't be good don't git caught  !!                                        People who say stuff can't be done need to
        git the hell outta the way of people who do stuff   !!!
Show me a man who is called an expert by his peers
And I will show you a good man to listen to ......
Show me a man who calls himself an expert
and I will show you an egotistical asshole...............!!
Posted
Gary, I see why you liked it because that is great pattern for Damascus. Never seen anything like it!  I am anxious to see what you come up with!!
Posted
I got the 4-wayed billet drawn out to 1"x1"x ?.
IMG_7127_opt
I then cut it into four equal length pieces and surface ground two sides of each.  This I tack welded together into a second 4-way.
IMG_7118_optIMG_7134_opt
Once welded I did an additional squaring on the bias to get the final pattern.
IMG_7136_opt
Here's the billet drawn to size for tile cutting.
IMG_7140_opt
And my first look at the pattern.  ( the ugly gray blotch is the remainder of a MIG tack weld on the ends of  the 4-way and will come off when tile cut)
IMG_7146_opt
The next step  will be to surface grind two sides and tile cut.
Gary
ABS,CKCA,ABKA,KGA
Posted
I'm very grateful for these step-by-step processes you post Gary. They are extremely inspirational. I hope you post some intermediate pics of the tile cutting & welding steps.
Posted
Will do.
Gary
ABS,CKCA,ABKA,KGA
Posted
Here's a look at my process for tile cutting.  I number each tile primarily for orientation so  that I get them tack welded correctly.
IMG_7172_optIMG_7199_optIMG_7203_optIMG_7205_opt
Gary
ABS,CKCA,ABKA,KGA
Posted
Truly inspirational! And the sneak peek of the pattern before cutting the tiles looks extremely promising. Looking forward to the result.
Posted
Thanks Gary!
I got  the blade forged to shape  this morning.
IMG_7209_opt
Here's a look at the pattern after a rough grind and quick etch.  It will get a lot more contrast after H/T'ing, a proper hand sanding  and a full etch.
IMG_7224_opt
Gary
ABS,CKCA,ABKA,KGA
Posted
Man, that is a success!
I appreciate you showing hte steps to the mossaic work.  One of these days I'm going to give that a shot.  It is still of a brain bender for me right now.
I reacall that you preferr welding without flux.  Is that true through all of these steps?
-Brian
Posted
Yes.  The only time I used any borax was to  prevent scaling during the normalizing  process.
Gary
ABS,CKCA,ABKA,KGA
Posted
Very nice!  That is a cool pattern, and I looks good when it distorts in the knife forging too!
http://www.krakenforge.net/
Posted
Well, it's not the same as JLR's pattern, but dang man, that looks nice!
Posted
Thanks.  I didn't expect to be able to exactly duplicate his pattern but I'm satisfied with the outcome.
Gary
ABS,CKCA,ABKA,KGA
