lachlan 0 Posted January 30, 2018 Share Posted January 30, 2018 Could someone please tell me, or link me to a pre-existing post explaining if there is any difference between linen and canvas micarta. Link to post Share on other sites
Zeb Camper 787 Posted January 30, 2018 Share Posted January 30, 2018 (edited) Micarta is made from a compress of cloth, or paper glued together with phenolic resin. In other words, linen micarta is made with stacked linen; canvas is made from canvas. I beleive linen has a finer grained look to it. Canvas will naturally be more course looking. Edit: welcome to the forum! Edited January 31, 2018 by Zeb Camper Link to post Share on other sites
Gerhard Gerber 482 Posted January 31, 2018 Share Posted January 31, 2018 To add to that, you can use Hessian, Cotton, and even (I guess some but not all) synthetic material. Strangely enough I've never found good canvas to use, from the stuff I use I've learned the following: Linen micarta is so far the nicest to work with.....behaves well for the lack of a better description. The Cotton micarta tends to melt and smear at time like when using a Dremmel, I'm sure this is either the dye or some function of the cotton fibers and the resin. Wool cloth smells like burning hair when worked, but makes good grippy micarta The way I see it the good properties of micarta are toughness, looks and grip when wet. I believe this is a function of the material fibers, the resin fills the gaps in-between but does not penetrate the natural fibers used in the material. Link to post Share on other sites
Brian Myers 134 Posted January 31, 2018 Share Posted January 31, 2018 Personally I like using construction paper. You have a lot of control over the colors and stacking different colors the grinding through them make for a great effect. Once the handle shaping is done, a few minutes on a buffing wheel takes it to a nice shine that seals it, but it stays fairly grippy. Here's a few pics of some micarta handles I've done. Link to post Share on other sites
Doug Lester 408 Posted January 31, 2018 Share Posted January 31, 2018 To translate hessian to American English, that's burlap. Doug 1 HELP...I'm a twenty year old trapped in the body of an old man!!! Link to post Share on other sites
Alan Longmire 3,878 Posted January 31, 2018 Share Posted January 31, 2018 Just to add a point of clarity, micarta is a trade name for only one product, phenolic resin-empregnated cloth made by Westinghouse and originally used for electrical insulating properties in large switches and such. They used brown canvas. Later on they did produce the linen versions and both black and white paper versions, still using phenolic resin. It's a little tougher than the epoxy-based kinds, but not so much that you'd notice on a knife handle. One of these days I want to try some with white and off-white heavy rag paper to see if it looks more like ivory... 1 Link to post Share on other sites
Gerhard Gerber 482 Posted February 1, 2018 Share Posted February 1, 2018 I tried paper once, brilliant definition of the layers, problem I had the (Polyester) resin was it didn't penetrate the paper all the way, and I got delamination while cutting out the scales. Always wanted to try with very little hardner so it has time to soak, but I'll save that for the winter, in our heat the reaction is very quick.... 12 hours ago, Alan Longmire said: Just to add a point of clarity, micarta is a trade name for only one product, phenolic resin-empregnated cloth made by Westinghouse and originally used for electrical insulating properties in large switches and such. They used brown canvas. Later on they did produce the linen versions and both black and white paper versions, still using phenolic resin. It's a little tougher than the epoxy-based kinds, but not so much that you'd notice on a knife handle. One of these days I want to try some with white and off-white heavy rag paper to see if it looks more like ivory... 100% correct, and you'll note (on Youtube etc) knife companies no longer claim to have Micarta handles.........for the life of me can't remember the term they used....... The ivory-look was my main reason for wanting to try paper, the wet colour of the paper as well as the resin will have an effect, needs some experimenting. Link to post Share on other sites
Brian Myers 134 Posted February 1, 2018 Share Posted February 1, 2018 I've never used any other resin than the bondo fiberglass stuff you buy at Walmart. I usually cut the hardner amount by a third or even half to slow the cure time. It soaks deep into the paper and I haven't had a delam yet. Usually takes about 24 hours for a full cure, but comes out hard as a rock. It does darken the paper slightly, but not too badly. Link to post Share on other sites
Doug Crawford 32 Posted February 1, 2018 Share Posted February 1, 2018 1 hour ago, Brian Myers said: I've never used any other resin than the bondo fiberglass stuff you buy at Walmart. I usually cut the hardner amount by a third or even half to slow the cure time. It soaks deep into the paper and I haven't had a delam yet. Usually takes about 24 hours for a full cure, but comes out hard as a rock. It does darken the paper slightly, but not too badly. That’s the stuff I usually use- I’ve done blue jeans, camo, cotton fabric- tried synthetic but it doesn’t absorb the resin so it didn’t really shape and polish, just frayed. Also tried titanium ore- with less than ideal results. Link to post Share on other sites
Brian Myers 134 Posted February 1, 2018 Share Posted February 1, 2018 I think that natural materials work better with fiberglass resin. I've noted that some artificial materials actually start to break down a bit, which leads to a weaker scale. Just my two cents though. I've seen people have good results with paracord and fiberglass resin so maybe it's just me. Link to post Share on other sites
Gerhard Gerber 482 Posted February 2, 2018 Share Posted February 2, 2018 The synthetic material I used was like a canvas weaved with a synthetic thread, neon orange and neon green. The resin penetrated nicely and I believe actually melted the material a bit.....lots of orange or green ooze when pressing. Without question the strongest micarta I've made, but not pleasant to work.....it likes to burn and smear a bit making the final finish a pain. Without any doubt Linen is my favourite so far, great to work and feels warmer than the others. Link to post Share on other sites
Ross Vosloo 174 Posted February 2, 2018 Share Posted February 2, 2018 the type ive been making is with cotton material and fibre glass resin with just a drop of so of hardener. takes a long time to cure, but comes out great. i used the "just throw a wack of it in a bag, pour in the resin then clamp the living daylights out of it" trick. Ross Vosloo Mhara Knives made in Zimbabwe https://www.mharaknives.com Link to post Share on other sites
Gerhard Gerber 482 Posted February 2, 2018 Share Posted February 2, 2018 My whole knife making started because of micarta......couldn't afford micarta-handled knives, so I bought cheap knives and put micarta handles on them. One thing led to another..... As the first part of the process I bought cotton in every colour of the rainbow.....still have most of it left Get Linen......you won't be sorry http://i64.tinypic.com/ok8ymr.jpg Link to post Share on other sites
Gerhard Gerber 482 Posted February 2, 2018 Share Posted February 2, 2018 Linen that I dyed black: Link to post Share on other sites
Gerhard Gerber 482 Posted February 2, 2018 Share Posted February 2, 2018 Early days.....Red Bull Denim.....don't believe it has anything to do with the energy drink.... Link to post Share on other sites
Gerhard Gerber 482 Posted February 2, 2018 Share Posted February 2, 2018 Cotton.......customer request Link to post Share on other sites
Gerhard Gerber 482 Posted February 2, 2018 Share Posted February 2, 2018 (edited) Hessian/Burlap backed by black Cotton....and IIRC black tint mixed into the resin. BTW, if&when you tint the resin, you need to use extra hardner. Edited February 2, 2018 by Gerhard forgot photo Link to post Share on other sites
Brian Myers 134 Posted February 2, 2018 Share Posted February 2, 2018 2 hours ago, Gerhard said: BTW, if&when you tint the resin, you need to use extra hardner. Boy and how! I attempted a black tint once, turned into the gummiest mess, like jello. It did eventually harden but man it was horrible until it did lol. I think my mistake was using an alcohol based liquid tint. Next time I'm going to try a powdered stain. Link to post Share on other sites
Gerhard Gerber 482 Posted February 2, 2018 Share Posted February 2, 2018 Made jello more than once.......I use the (alu oxide I think?) powder they use to stain cement. Link to post Share on other sites
