Philip Patton
My first Framehandle WIP
This is my first attempt at a frame handle knife, and it has taught me many things
The blade was made from some Randy Haas stainless steel damascus, and is friction fit into a channel in the frame and is pulled tight to the guard by a bolt.
The handle is made from horn I stabilized,  wrought iron, and copper. The handle is held together with 9 pins and epoxy.
Edited by Philip Patton
Photo placement.
  • Like 3
Thank you posting this.  I am learning and really want to make a frame handle bowie.  Instructions like this are worth their weight in gold for a students of steel like myself.
2 hours ago, Kreg said:
I am gonna wave the rookie flag here......why not just make a full tang handle?? Curiosity got the best of me. Great looking knife btw.
One reason is the type of guard you want to use. The frame handle lets you slide a thin guard up to the base of the blade-- to do the the same thing on a full-tang knife, your blade has to be significantly wider than your handle.
Basically, the frame handle lets you combine aesthetic features of full-tang and hidden/through tang type blades that couldn't otherwise coexist.
It also has a bit of a "how'd he do that?" factor when the frame material matches the blade and there is a solid guard in what looks like a notch in the full tang.
