Posted
The rule of thumb is ~1kW into the motor for every horsepower that comes out of it so your 1.5kW would probably be closer to 1.5hp, maybe a bit more on a good day.  More would be nice to have, but 1.5kW will make a lot of knives if the extra money just isn't there.
-Brian
Posted
That's what happens when I use an online conversion tool to translate Kw to HP...  :o  Is there a direct correlation, other than both being units of power?  I was thinking 1.5Kw output, but I can certainly see if that's the input power required instead the output is necessarily lower by quite a bit.
Posted
Yeah, they rate the motor on what it draws electrically, not what it produces mechanically.  Induction motors in this size range are often around 75% efficient which means it takes 933W to produce the 746W out (1hp).  Hence the 1kW/hp rule of thumb.
-Brian
Posted
It doesn't look like that is not a TEFC (Totally Enclosed Fan Cooled) motor.  In a grinding environment it probably will not last long.
Check out the Motors and VFDs page on my web site.
Let me know if I can help you.  I prefer e-mail.
Wayne Coe
Artist Blacksmith
729 Peters Ford Road
Sunbright, Tennessee
706-273-8017
waynecoe@highland.net
www.WayneCoeArtistBlacksmith.com
Posted
my motor is open and right next to the contact wheel and lower than my platen which i use almost exclusively never had a problem also i am running a 1.5 which is fine for most things if i spent more time making knives i would upgrade to a 2 or even a 3 if i was doing a lot of stock removal haven't changed my belt speed in 14 years might save me some hand sanding if i did
Brandon Sawisch bladesmith
Posted
Strange question I guess.......
It seems I have a choice between profile cutting (with 0.5mm tolerance), or laser cutting which is supposedly very accurate and much neater but might be expensive....
I'm waiting for quotes.....
I've asked for either 5mm or 6mm mild steel plate, is that thick enough?
Posted
Laser cut if possible, and go for 9mm plate minimum.  13mm would be even better.  The 5mm will bend under the tension, and the 6mm might unless you weld gussets on it, which will then warp it.
Posted
Thanks Alan, acted on advice from my friend with the engineering shop.........should've asked here before I requested the quotes :wacko:
Posted
New problem, the drawings are not on scale, and no scale indicated.
Both companies I contacted got back to me on the matter.
You could guess, but then you might end up with a standard belt being too long  or too short.......?
Posted
Did you send them the .dxf files, or the pdf's?  They should be able to read the .dxf's into just about any CAD software and they will come through in full scale.  They may just have to convert from imperial to metric or vice-versa.
If someone only has access to single phase power, it it feasible to use a stepper motor with a high rpm and a pulse controller to control the speed of the grinder?
Edited by Wesley Alberson
"Yeah, well, you know, that's just, like, your opinion, man" -The Dude,
Instagram: https://www.instagram.com/rougemont_forge/
Posted
That seems a strange way to go about it to me.  Would that be smooth?
  VFDs are the way to go. Single phase input, three-phase output.
Posted
Ah, ok. I thought all this time that you need 3 phase input for a VFD, and the VFD simply changed the frequency. What is the most common VFD that people buy for this setup? After a quick search I found this: https://www.wolfautomation.com/index.php/catalog/product/view/id/8663/s/ac-drive-3hp-12a/?gclid=EAIaIQobChMIupfhm6LK2QIVjVcNCh0KsAZdEAYYASABEgJ6Q_D_BwE
I made my grinder with a variable pulley system, and I'm not really happy with it, everything is too fast. That being said, I am currently powering my shop with a drop cord and I can only run 120V power to my shop. As long as I use fresh belts, wood doesn't burn and steel doesn't overheat too fast.
Posted
16 hours ago, JJ Simon said:
I just had these cut.
They are on scale.
You need to use the CAD files.
Very strange, I did send them the CAD files because I assume that's the input of the cutter, both companies came back and told me the parts are very small, like the main horizontal part on their software is 8cm long.
Anyway, I found another supplier in South Africa that sells grinders in kit form, the frame in the kit even with transport is cheaper than I can have it cut locally.
Posted
Look back in this thread to find a link to Wayne Coe's site.  He sells a couple of different models for different horsepower requirements.
Posted
My one concern is I'm now buying a VSD instead of a VFD.........I'm hoping my purchase is just described with a less accurate acronym!
  • 1 month later...
On 2/8/2018 at 10:34 AM, Alan Longmire said:
I'll just put them here on the forum as well. in all three configs, plus the assembly photo, so there!
The drawings in one .zip file: drawings1a.zip
Individually: part1.DXF Part2.DXF Part3.DXF Part4.DXF Part5.DXF Part7.DXF Part8.DXF part9.DXF baseplate.DXF  NOTE: There is no part 6.  don't ask for it!
and finally, the drawing of all parts on a single sheet of steel: onepiece.zip
These are the plans I used to build my grinder but I welded my parts instead of bolts. I love this grinder! I also modified it to run with pillow blocks and a belt because I don’t have a vfd yet. I had my parts cut on a plasma table with no holes except the large one for the motor so I can add a direct drive at a later date. I absolutely love my grinder even though it only runs at one speed.
Edited by Aaron Money
  • 1 month later...
Posted
Made from simple plate steel bolted together
Now there is a DIY I could definitely consider.
I would  think about a solid bar bolted to the base plate at the bottom of the two panels with them bolted to it.
I also think it would need a spring on the moveable arm as a tensioner.
Edited by Vern Wimmer
Posted
I tried using a spring but it seemed to develop a kind of bounce to it which was very irritating so I used a car boot gas lift from eBay
Posted
hey Gerhard,
VFD, VSD, same thing. One stands for Variable Frequency Drive, the other is Variable Speed Drive. they both do the same thing in the same way, by varying the frequency out to the motor.
My day job is as an Electrical Technician, and i use these things every day. too bad that with what they cost landed here in Zim, i could never afford one. a 1.5kW single phase in costs over $1100 US.
Ross Vosloo
Mhara Knives made in Zimbabwe
https://www.mharaknives.com
Gerhard I have a complete set of plans in DXF format that are to scale designed to be either plasma or laser cut
The difference being I sized bolt holes for drilling and tapping to eliminate as many nuts and and bolts as possible
If you still need plans let me know and I can send them to you.
Edited by JeffM
add an image
