ethanknott Posted March 10, 2018 Posted March 10, 2018 What kind of epoxy do you guys use for your handles and other bits? I've tried the loctite 5 minute stuff from Home Depot, worked fine but set up too fast for my liking. Got a 20 minute epoxy, 2:1 mix, from System Three. It could totally be from my inability to measure simple ratios, but I've been having issues with the epoxy letting go of the wood and/or metal. I clean and rough up all surfaces before glue up. I don't put any holes in the tang except for the pin holes, which may make a difference. Normally I use a liner of black construction paper/felt stuff from the hobby store to fill in any uneven bits between metal and handle material, also makes it look good. So basically, not sure if it's me being an inferior epoxy-er, or if I'm using an inferior epoxy.
Joël Mercier Posted March 10, 2018 Posted March 10, 2018 West System's G/Flex and Brownell's AcraGlass seems to be the most trusted. I use G/Flex. 1
Mason Simonet Posted March 10, 2018 Posted March 10, 2018 (edited) I use JB weld. On my first couple of knives I used the 5 minute stuff, and the handles are falling off of all of those knives. I haven’t had a problem since I switched. Edited March 10, 2018 by Mason Simonet
GBrackett Posted March 10, 2018 Posted March 10, 2018 I use west systems GFlex and their other products. All marine rated epoxies. 1 ”Whoever pursues righteousness and love finds life, prosperity, and honor!” George Brackett American Bladesmith's Society, Apprentice Member Hialeah, Florida
Zeb Camper Posted March 10, 2018 Posted March 10, 2018 +1 Gflex. I had to rehandle a blade not too long ago (customer didn't like the feel). It was a sandwich construction of G10 on a full hidden tang. It was a real challenge! I tried beating it with a hammer, burning it, prying it. I finally opened up a big enough crack to pry it off. Gflex is no joke.
Doug Lester Posted March 10, 2018 Posted March 10, 2018 AcraGlass or West Gflex. Either one will do fine. I've never had good luck with anything from the hardware stores. Doug HELP...I'm a twenty year old trapped in the body of an old man!!!
Al Massey Posted March 10, 2018 Posted March 10, 2018 I really like G2 epoxy from Lee Valley. Works great on exotic hardwoods.
Alex Middleton Posted March 10, 2018 Posted March 10, 2018 Maybe I'm just running on borrowed time, but ive actually had really god luck with hardware store 5 min epoxy. I put a stone bit in my Dremel and cut swirly grooves on both sides of my tang and on both handle scales and then make sure everything is clean and dry before glue up.
Thomas Kadatz Posted March 10, 2018 Posted March 10, 2018 Here is a good long thread about epoxy. Two guys researched and recorded how different epoxies preformed and made a spreadsheet telling what epoxy is best for what materials and how they all preformed. Long read but it is worth it http://www.knifenetwork.com/forum/showthread.php?t=27463
Jason McEntee Posted March 10, 2018 Posted March 10, 2018 I use Devcon Flowmix 2 ton---the 12 hour cure stuff. Have yet to have any issues with it. www.facebook.com/appleseedcustoms/
Alan Longmire Posted March 10, 2018 Posted March 10, 2018 52 minutes ago, Thomas Kadatz said: Here is a good long thread about epoxy. Two guys researched and recorded how different epoxies preformed and made a spreadsheet telling what epoxy is best for what materials and how they all preformed. Long read but it is worth it http://www.knifenetwork.com/forum/showthread.php?t=27463 Ah, the famous Glue Wars thread! I was gonna link to that later, thanks. I think I'll pin this so it wil be easy to find. Maybe move it to Fit and Finish as well. I've used many things, and as soon as I run out of the bottles of T-88 I have I will go to G-flex. Accraglas is indestructible, and I will continue using it for things like antler stick tangs. It is kind of a pain to work with, though.
Joshua States Posted March 12, 2018 Posted March 12, 2018 I have used (and continue to do so) a variety of epoxies. What ever you use, keep the mixing pallet and stir stick on the bench while the epoxy sets. Come back after the amount of time that the product instructions tell you it needs to set up and check the pallet and stick. If the leftovers on the mixing pallet aren't set up, you either missed the mixture or are using defective material. Take the handle apart, clean it up and start again. “So I'm lightin' out for the territory, ahead of the scared and the weak and the mean spirited, because Aunt Sally is fixin’ to adopt me and civilize me, and I can't stand it. I've been there before.” The only bad experience is the one from which you learn nothing. Josh http://www.dosgatosdesignsllc.com/#! https://www.youtube.com/channel/UCdJMFMqnbLYqv965xd64vYg J.States Bladesmith | Facebook https://www.facebook.com/dos.gatos.71 https://www.etsy.com/shop/JStatesBladesmith
Wes Detrick Posted March 13, 2018 Posted March 13, 2018 7 hours ago, Joshua States said: I have used (and continue to do so) a variety of epoxies. What ever you use, keep the mixing pallet and stir stick on the bench while the epoxy sets. Come back after the amount of time that the product instructions tell you it needs to set up and check the pallet and stick. If the leftovers on the mixing pallet aren't set up, you either missed the mixture or are using defective material. Take the handle apart, clean it up and start again. I learned that lesson at least once, and now I do exactly that. It is excellent advice “In the midst of winter, I found there was, within me, an invincible summer." -Albert Camus http://www.krakenforge.net/
Gary Mulkey Posted March 13, 2018 Posted March 13, 2018 I continue to use AcraGlas for two main reasons. One is that it has four times the resin in the mixed condition which gives it extra toughness. Two is that it doesn't degrade like most epoxies. Most will last no more that 8-10 years (or less) before degrading where AcraGlas is good for 100 years. Gary ABS,CKCA,ABKA,KGA
Clifford Brewer Posted March 13, 2018 Posted March 13, 2018 I've been using Gorilla epoxy for a few years now and had no issues with it ....... I also check the mix leftovers in the set time. If ya can't be good don't git caught !! People who say stuff can't be done need to git the hell outta the way of people who do stuff !!! Show me a man who is called an expert by his peers And I will show you a good man to listen to ...... Show me a man who calls himself an expert and I will show you an egotistical asshole...............!!
Conner Michaux Posted March 30, 2018 Posted March 30, 2018 Is this the G-flex epoxy? https://www.amazon.com/NRS-flex-Epoxy-2-4oz/dp/B002IZFPQE/ref=sr_1_1?ie=UTF8&qid=1522373858&sr=8-1&keywords=g%2Fflex+epoxy 1
Jeremy Blohm Posted March 31, 2018 Posted March 31, 2018 Here is a question i have not seen yet. What epoxy would be dish washer safe for use on stainless kitchen knives?
Alan Longmire Posted March 31, 2018 Posted March 31, 2018 If you read that Glue Wars thread, they tested for that. The general consensus is that Accraglas can handle it, but you really need pins or Corby bolts or cutler's rivets for a secure mechanical grip as well. 2 1
Joshua States Posted April 1, 2018 Posted April 1, 2018 10 hours ago, Jeremy Blohm said: Here is a question i have not seen yet. What epoxy would be dish washer safe for use on stainless kitchen knives? Dishwasher?!?! That's Sacrilege man! Even for stainless. 1 “So I'm lightin' out for the territory, ahead of the scared and the weak and the mean spirited, because Aunt Sally is fixin’ to adopt me and civilize me, and I can't stand it. I've been there before.” The only bad experience is the one from which you learn nothing. Josh http://www.dosgatosdesignsllc.com/#! https://www.youtube.com/channel/UCdJMFMqnbLYqv965xd64vYg J.States Bladesmith | Facebook https://www.facebook.com/dos.gatos.71 https://www.etsy.com/shop/JStatesBladesmith
Jeremy Blohm Posted April 1, 2018 Posted April 1, 2018 12 hours ago, Joshua States said: Dishwasher?!?! That's Sacrilege man! Even for stainless. Its not me the knives have to worry about it's the wifey. When i do dishes they are all done by hand. I dont know how many times i have told my wife there are certain things that dont go in the dishwasher and they always end up there anyway. 1
Joshua States Posted April 2, 2018 Posted April 2, 2018 On 4/1/2018 at 10:24 AM, Jeremy Blohm said: Its not me the knives have to worry about it's the wifey. When i do dishes they are all done by hand. I dont know how many times i have told my wife there are certain things that dont go in the dishwasher and they always end up there anyway. Well you'd better make her some with synthetic handle materials like micarta because any natural handle material will fail in the dishwasher. OK. So here's my secret epoxy for super duper performance under any circumstances. I can only tell you if you promise not to tell anyone else....... Simpson SET construction adhesive. This is a structural epoxy meant for anchoring steel bolts into concrete. Thick as pig snot. Sets in 7 minutes so work fast. It's a really ugly grey color, so don't get it on anything that is visible (including your fingers). Not for the faint of heart. 1 “So I'm lightin' out for the territory, ahead of the scared and the weak and the mean spirited, because Aunt Sally is fixin’ to adopt me and civilize me, and I can't stand it. I've been there before.” The only bad experience is the one from which you learn nothing. Josh http://www.dosgatosdesignsllc.com/#! https://www.youtube.com/channel/UCdJMFMqnbLYqv965xd64vYg J.States Bladesmith | Facebook https://www.facebook.com/dos.gatos.71 https://www.etsy.com/shop/JStatesBladesmith
