Adam C. Posted March 11, 2018 Share Posted March 11, 2018 The best I can tell from finding the stamp while sorting through my pile. Ford 3L54 PB OW3 323C Tried digging around on the interwebs and the heat treated guide. Wanna start moving into the known steel world and not just half assing it with unknown. Thanks for any information! ~Adam Link to comment Share on other sites More sharing options...
Vern Wimmer Posted March 11, 2018 Share Posted March 11, 2018 If no one has a definitive answer you might try a small sample "coupon" in a "harden/break" test and see if it it is hardenable. If so treat it like 5160 and you probably won't be far off. Link to comment Share on other sites More sharing options...
Adam C. Posted March 11, 2018 Author Share Posted March 11, 2018 That's what I was thinking. I've done a lot of searching online. I've gotten very little info on the composition just the part number to order replacement parts. Link to comment Share on other sites More sharing options...
Alan Longmire Posted March 11, 2018 Share Posted March 11, 2018 That would be because that's all those numbers mean. It's a pretty safe bet the leaf springs are the equivalent of 5160, or at least something that will respond to the same heat treatment recipe as 5160. Coil springs, on the other hand, are a crapshoot these days. Gotta know the year and car brand, and after 2005 or so nobody knows. 1 Link to comment Share on other sites More sharing options...
Joshua States Posted May 3, 2018 Share Posted May 3, 2018 (edited) I had a set of Ford leaf springs (actually, I still have some of it) and I did some internet searching some years ago on them when I got them. Turns out Ford used either 5160 or 1095 (yeah I know hard to believe) for their leaf springs and they used to stamp the steel type in one end. Mine were stamped 5160. I don't know how old yours are or what Ford is using now, but cut a chunk off, forge a small blade and put it through the HT for 5160 and then break it and see how well it responded. Whenever you are using an unknown or untested material, it always pays to do some testing first. Edited May 3, 2018 by Joshua States “So I'm lightin' out for the territory, ahead of the scared and the weak and the mean spirited, because Aunt Sally is fixin’ to adopt me and civilize me, and I can't stand it. I've been there before.” The only bad experience is the one from which you learn nothing. Josh http://www.dosgatosdesignsllc.com/#! https://www.youtube.com/channel/UCdJMFMqnbLYqv965xd64vYg J.States Bladesmith | Facebook https://www.facebook.com/dos.gatos.71 https://www.etsy.com/shop/JStatesBladesmith Link to comment Share on other sites More sharing options...
Vern Wimmer Posted May 3, 2018 Share Posted May 3, 2018 16 hours ago, Joshua States said: I had a set of Ford leaf springs (actually, I still have some of it) and I did some internet searching some years ago on them when I got them. Turns out Ford used either 5160 or 1095 (yeah I know hard to believe) for their leaf springs and they used to stamp the steel type in one end. Mine were stamped 5160. I don't know how old yours are or what Ford is using now, but cut a chunk off, forge a small blade and put it through the HT for 5160 and then break it and see how well it responded. Whenever you are using an unknown or untested material, it always pays to do some testing first. I agree but I am wondering, given that Furd Mangle Company uses/used 1095 or 5160 if we could sort of codify a testing procedure and the results from both steels to help folks tell the difference? If it is already in a thread, that I missed, could we link it? Just a wild thought, buuuut, if one is using springs at this point I might hazard a quess that they aren't set up to really "maximize" 1095 so perhaps multiple normalizations before quench and generally treating it like 5160 might be the order of the day. Link to comment Share on other sites More sharing options...
Ken Soltys Posted May 3, 2018 Share Posted May 3, 2018 On 3/11/2018 at 6:13 PM, Alan Longmire said: That would be because that's all those numbers mean. It's a pretty safe bet the leaf springs are the equivalent of 5160, or at least something that will respond to the same heat treatment recipe as 5160. Coil springs, on the other hand, are a crapshoot these days. Gotta know the year and car brand, and after 2005 or so nobody knows. As far as coil springs i will test each set i get, but i will try to get truck leaf springs.For important stuff i will order that to be safe.Thank you Alan. Link to comment Share on other sites More sharing options...
Joshua States Posted May 4, 2018 Share Posted May 4, 2018 7 hours ago, Vern Wimmer said: I agree but I am wondering, given that Furd Mangle Company uses/used 1095 or 5160 if we could sort of codify a testing procedure and the results from both steels to help folks tell the difference? If it is already in a thread, that I missed, could we link it? Just a wild thought, buuuut, if one is using springs at this point I might hazard a quess that they aren't set up to really "maximize" 1095 so perhaps multiple normalizations before quench and generally treating it like 5160 might be the order of the day. Whenever you are using any steel that you are not totally sure of, normalization and testing is a must, regardless of what you might "think" it is. Even when I had a steel that I knew what it was, but I had never used it before (W2 in this case) I did a small blade and tested the HT method, just to be sure....... “So I'm lightin' out for the territory, ahead of the scared and the weak and the mean spirited, because Aunt Sally is fixin’ to adopt me and civilize me, and I can't stand it. I've been there before.” The only bad experience is the one from which you learn nothing. Josh http://www.dosgatosdesignsllc.com/#! https://www.youtube.com/channel/UCdJMFMqnbLYqv965xd64vYg J.States Bladesmith | Facebook https://www.facebook.com/dos.gatos.71 https://www.etsy.com/shop/JStatesBladesmith Link to comment Share on other sites More sharing options...
