Eric Dennis Posted April 13, 2018 Share Posted April 13, 2018 I just bought a used grizzly G9742 horizontal bandsaw for a good price. This one: http://www.grizzly.com/products/G9742/parts The problem is, it no longer has the hydraulic cylinder that allows the saw to automatically lower. Buying a new one from Grizzly apparently is almost $200.00!!! Does anyone know of a place to buy cheaper parts that will fit this machine? It would be MUCH appreciated. Best, Eric Link to comment Share on other sites More sharing options...
Brian Dougherty Posted April 16, 2018 Share Posted April 16, 2018 It is just a hydraulic cylinder with a small needle valve to restrict the flow out of the cylinder as the saw comes down. Maybe you can fab something up out of salvaged/recycled parts? -Brian Link to comment Share on other sites More sharing options...
JJ Simon Posted April 16, 2018 Share Posted April 16, 2018 Check Mcmaster carr. They have all kinds of cyclinders. Link to comment Share on other sites More sharing options...
Eric Dennis Posted April 16, 2018 Author Share Posted April 16, 2018 It's a self-contained unit powered just by gravity and the weight of the machine. I actually got hold of the old busted one. I think I can fix it up. Either there is a busted o-ring or the cylinder was simply never filled. I'm gonna try re filling and see what happens. If not then https://www.surpluscenter.com/ has a bunch or else I'll try checking mcmaster. Thanks! Link to comment Share on other sites More sharing options...
Alan Longmire Posted April 16, 2018 Share Posted April 16, 2018 That's what I was thinking, it should be a simple off-the-shelf gas strut. Just need the length and strength requirement. Link to comment Share on other sites More sharing options...
Eric Dennis Posted April 17, 2018 Author Share Posted April 17, 2018 I opened up the original that supposedly didn't work- filled it with hydraulic fluid (it had only a few teaspoons inside. Closed it up with a little teflon tape on the threads, and voila! So far it's as good as new. No external leaking that I can see, and the internal gasket seems to be holding as well. Glad that worked... Link to comment Share on other sites More sharing options...
