Mason Simonet 54 Posted April 30, 2018 Share Posted April 30, 2018 I’ve been planning to upgrade from canola oil to a commercial quench oil. Parks 50 is to expensive plus it’s so hard to find. anybody have any experience with how McMaster-Carr 11 sec works with 1084? Thanks Mason Link to post Share on other sites
jheinen 41 Posted April 30, 2018 Share Posted April 30, 2018 That's what I use. Works great, and I haven't noticed any issues. Jeff H. CFI/CFII/MEI KE7ZMH "Give a man fire and he will be warm for a day. Set a man on fire and he will be warm for the rest of his life." Link to post Share on other sites
Alan Longmire 3,674 Posted April 30, 2018 Share Posted April 30, 2018 And on top of that, Parks 50 is ONLY for water-quench steels. It's too fast for deep-hardening steels like 1084, 5160, 80CrV2, and so on. If you're not going for hamon on 1075, 1095, or W1/W2, you don't need Parks 50. Link to post Share on other sites
Brian Dougherty 1,373 Posted April 30, 2018 Share Posted April 30, 2018 I use it, and is seems fine. Most of my blades are a 50/50 mix of 1095 and 15N20. They harden well in it. However, I can't honestly say that they are hardening any better than when I used canola, and there are some things I didn't like when I first switched to the 11-sec oil. It flames up, which never happened with canola. It also stinks up the shop a lot worse. Without any means of actually testing hardness, I often wonder if the canola wasn't just as good for the steel I use. -Brian Link to post Share on other sites
Joël Mercier 695 Posted April 30, 2018 Share Posted April 30, 2018 130° canola is around 10.5 secs. Just a tad faster. Houghton mentions it as the best vegetal quenchant in terms of stability in their pdf. Some people quench 80CrV2 in parks50 without problems. It has only 0.3% manganese and 0.5% chromium. I wonder if you get 100% hardness though... 1 Link to post Share on other sites
Mason Simonet 54 Posted April 30, 2018 Author Share Posted April 30, 2018 Thanks guys. I’m switching because I felt I wasent getting the full potential in the steel... but that was with admirals 1080, and I just ordered Aldo’s 1084. Ill see how it goes with the 1084 and canola, then I’ll decide if I want to switch. thanks again Mason Link to post Share on other sites
