Leroy Hill 4 Posted December 1, 2018 Share Posted December 1, 2018 (edited) I'm a little unsure as to why you need such a huge piece of steel for a power hammer that's gonna hammer one particular area.. all the ones I have seen have a much smaller surface area than that on which to rest the work piece.. Edited December 1, 2018 by Leroy Hill Link to post Share on other sites
Jeremy Blohm 511 Posted December 1, 2018 Author Share Posted December 1, 2018 These are all the parts I have acquired over the last 3 years preparing to build this and now that I have the anvil it is set in steel. Here is the cylinders I purchased from an online auction for $114 for the pair. here is the main compressor. It is a 10 hp 60 gallon rotary screw compressor. I bought this at auction for $185. I need to build a big rotary phase converter because it is 3 phase. But I have a 3 phase belt sander and a 3 phase hydraulic pump I'm going to run off of it also. And 2 other 3 hp 60 gallon compressors that both need motors that will be additional air supply in case the 10 hp cant keep up. Link to post Share on other sites
Jeremy Blohm 511 Posted December 1, 2018 Author Share Posted December 1, 2018 1 hour ago, Leroy Hill said: I'm a little unsure as to why you need such a huge piece of steel for a power hammer that's gonna hammer one particular area.. all the ones I have seen have a much smaller surface area than that on which to rest the work piece.. This block of steel will be stood on end and there will be holes drilled and tapped to accept different dies just like the larger power hammers except they have dove tails milled into the main anvil to accept the dies. I'm planning on doing a mini version of this. 1 Link to post Share on other sites
Leroy Hill 4 Posted December 1, 2018 Share Posted December 1, 2018 I got you on that then..I thought from the conversation this was strictly gonna be used as an anvil.. makes much more sense as it will be the actual backbone of the machine as a whole.. 1 Link to post Share on other sites
Jeremy Blohm 511 Posted December 1, 2018 Author Share Posted December 1, 2018 Finally I was able to get a picture of the other compressor to upload. Link to post Share on other sites
Jeremy Blohm 511 Posted December 1, 2018 Author Share Posted December 1, 2018 250 lbs of the planned 350 for the tup. Link to post Share on other sites
Leroy Hill 4 Posted December 1, 2018 Share Posted December 1, 2018 (edited) 11 minutes ago, Jeremy Blohm said: Finally I was able to get a picture of the other compressor to upload. That's about the size of the tank I'll be using to build my forge.. looking forward to your finished project.. wish I had more space for my pass time projects. But I'll make due for now Edited December 1, 2018 by Leroy Hill Link to post Share on other sites
Jeremy Blohm 511 Posted December 1, 2018 Author Share Posted December 1, 2018 This might not look like it but it is a 60 gallon tank. I have a 20 gallon compressor that looks just like it only green. Link to post Share on other sites
Jeremy Blohm 511 Posted December 1, 2018 Author Share Posted December 1, 2018 This might be a slow going project but I will keep this updated as things progress. Link to post Share on other sites
Jeremy Blohm 511 Posted December 1, 2018 Author Share Posted December 1, 2018 This old chain fall is worth its weight in gold. And this huge maple tree in the back yard is pretty strong. Link to post Share on other sites
Steve O 18 Posted December 2, 2018 Share Posted December 2, 2018 Jeremy, what size are the cylinders that you have? What is the rod diameter also? VERY cool project by the way, definitely the largest home built hammer I have seen. Link to post Share on other sites
Jeremy Blohm 511 Posted December 2, 2018 Author Share Posted December 2, 2018 (edited) I'm not 100% sure on the size of the cylinders. I will find out but I know the rod diameter is about 1 1/4 inch Edited December 2, 2018 by Jeremy Blohm Link to post Share on other sites
Jeremy Blohm 511 Posted December 2, 2018 Author Share Posted December 2, 2018 I have 16 feet of 18 inch I-beam coming for the frame. Link to post Share on other sites
Jeremy Blohm 511 Posted December 10, 2018 Author Share Posted December 10, 2018 On 12/2/2018 at 6:30 PM, Steve O said: Jeremy, what size are the cylinders that you have? What is the rod diameter also? I finally made it over to the shop and took a look at the cylinder and it is a 6 inch bore, 1 3/4 inch rod, and a 30 inch stroke with a 250 psi envelope pressure. Link to post Share on other sites
Jeremy Blohm 511 Posted February 26, 2020 Author Share Posted February 26, 2020 I havent forgot or gave up on this project. I've still been gathering up all the materials needed. I just acquired what I needed to make the base plate Link to post Share on other sites
Zeb Camper 782 Posted February 29, 2020 Share Posted February 29, 2020 Just remember to fine tune your matierials to match a design rather than the other way around. That's where I ran into trouble. Im still performing tuneups. If I did it again, I would buy plans and try my best to make the measurements around all the moving parts the same. Good luck! Link to post Share on other sites
SteveShimanek 112 Posted February 29, 2020 Share Posted February 29, 2020 That cannon pattern is rocking; have you cast it yet? Link to post Share on other sites
Jeremy Blohm 511 Posted March 1, 2020 Author Share Posted March 1, 2020 I have not cast the cannon yet. I have almost everything I need but the green sand and the materials to melt. I was going to start a topic on that soon. I'm thinking i might have to build a furnace big enough to fit 3 or 4 of my crucibles in at one time. Or buy a big enough crucible to make one pour. I have crucible tongs big enough for a really big crucible but they take 2 people to use. The also have a locking mechanism so I'm sure they can be used to pour also. Link to post Share on other sites
Alan Longmire 2,821 Posted March 1, 2020 Share Posted March 1, 2020 You need to build a big cupola furnace... Link to post Share on other sites
Jerrod Miller 462 Posted March 2, 2020 Share Posted March 2, 2020 On 2/29/2020 at 6:26 PM, Jeremy Blohm said: Or buy a big enough crucible to make one pour. Uninterrupted pouring is very important in getting quality castings. If you go with multiple small pours you should have a second person that can start pouring before the first person finishes their pour. Bigger ladles/crucibles are often the easier approach. Link to post Share on other sites
Jan Ysselstein 67 Posted April 20, 2020 Share Posted April 20, 2020 Jeremy... For what it is worth my suggestion is get a 3" diameter cylinder maybe a 14" stroke...and a weight of under 100 pounds for the hammer head. Get done and see how it works for you..look at your speeds and operating variables ( air requirements , costs ). Now you have a hammer with a weight ratio of 100/infinity that is really good. Then look at the math of that cylinder each stroke is 4 times the volume of the 3" cylinder and the large volumes of that 30 inch stoke will kill you by using a lot of air that is doing no work. Good luck on the sand smelting caution it is habit forming ...wash the sand and let it dry before cleaning with a magnet. Heat it with a propane torch and see if a foul smell comes off ...that is sulfur. 1 Link to post Share on other sites
Jeremy Blohm 511 Posted April 20, 2020 Author Share Posted April 20, 2020 I have thought of going mechanical just to eliminate the air consumption problem. A 100 lb weight with a 3800 lb anvil would be extremely efficient. I had my supervisors help me move the anvil in front of the shop this weekend. Now I have to try to move it into the shop and stood up.... Link to post Share on other sites
Jeremy Blohm 511 Posted April 25, 2020 Author Share Posted April 25, 2020 (edited) Well this project is getting put to the side. I'm buying another self contained hammer. This one will be a Kuhn though!!! This is in Austria and the owner is letting me pay payments!!!! $500 shipping. I'm paying $4300for the hammer and it has a 57# hammer weight. Edited April 25, 2020 by Jeremy Blohm Link to post Share on other sites
Charles dP 493 Posted April 25, 2020 Share Posted April 25, 2020 200 strokes per minute? Wow. Link to post Share on other sites
Alan Longmire 2,821 Posted April 25, 2020 Share Posted April 25, 2020 Small mechanical hammers run fast. A 25 lb little giant runs around 300 bpm. My Star 50lb runs around 220bpm. I'd still rather have that Kuhn... 1 Link to post Share on other sites
