GPrimmer Posted May 22, 2018 Posted May 22, 2018 I'm a little confused - I've been reading "The Backyard Blacksmith" as well as "The Complete Bladesmith" (referred by this forum) and both authors refer to the most effective "temperature colour indication" for mild steel. However, Lorelei Sims says "forging is most effective when the metal has turned yellow"(2100°F)... while our friend Jim Hrisoulas says that "most of the carbon steels" beginners will use should be worked at "the cherry red range" (1500°-1800°F). I'm fairly certain they're considering the same steels so what is up? If I'm just starting with 10 series steel what guideline should I use?
Jerrod Miller Posted May 22, 2018 Posted May 22, 2018 ASM Heat Treater's Guide recommends forging temps of: 1060: 1500-2200 F (forge near the upper end) 1095: 1500-2100 F (forge near the upper end) And those in between are in between. Generally, colors aren't a great guide, because my definition of "cherry red" is going to be different from yours (and likewise from everyone's), and ambient lighting skews things. Personal experience, especially with a knowledgeable guide present, is going to be your best guide. And before you get to tempering: please ignore temper colors. They are not accurate enough. Get a method of using thermal mass and an accurate thermometer.
D. Giagni Posted May 22, 2018 Posted May 22, 2018 "The Backyard Blacksmith" mostly deals with mild steel which can be forged a lot hotter than the steels used for knives.
AndrewB Posted May 22, 2018 Posted May 22, 2018 I found this chart online not sure if its exactly what everybody is talking about here or not.
Jerrod Miller Posted May 22, 2018 Posted May 22, 2018 2 minutes ago, AndyB said: I found this chart online not sure if its exactly what everybody is talking about here or not. That is the tempering color chart I was referring to (note that it only goes up to 600F). The OP was asking about forging temps. Do yourself a favor and forget that the chart you found even exists. 1
AndrewB Posted May 22, 2018 Posted May 22, 2018 (edited) Ah those, yep no clue from me on that one. I also found this chart it might help more Edited May 22, 2018 by AndyB
Jerrod Miller Posted May 23, 2018 Posted May 23, 2018 Unless you have a glowing version right next to your forge, no, it isn't really that helpful. That was my original point.
Vern Wimmer Posted May 23, 2018 Posted May 23, 2018 Observation and experience are far more valuable than color charts since there are too many variables involved that affect color both to an individual's perception and in individual environments. Spend some time initially with your steel getting used to what it tells you. For instance. Heating it up initially use a magnet as the steel heats. When the steel stops attracting the magnet, with 10xx series you are in the 1415-1425 F range. Get to know what that color looks like to your eyes in those conditions. Next you want to watch for the decalescence effect. This will be of great importance in the hardening process. Get to know what color, again to you, that occurs at. The next milestone is when sparks come off the blade. In technical terms, for the purpose of forging on an homogeneous bar, it is called "too frigging hot !" You are burning the steel. Don't do that again. To put it in simple terms forging should happen in that zone between ""tfh" and when it cools to the point it stops moving readily under the hammer. Your reading should have told you the effects of forging too hot or too cold.
steven smith Posted May 23, 2018 Posted May 23, 2018 Oh no, according to those charts ive been forging in the liquid range!
Alex Middleton Posted May 23, 2018 Posted May 23, 2018 The good thing is that liquid steel moves really easily under the hammer!
Vern Wimmer Posted May 23, 2018 Posted May 23, 2018 2 minutes ago, steven smith said: Oh no, according to those charts ive been forging in the liquid range! Good thing the steel didn't read the charts. It didn't know that. Is it really true that the austenite level is hotter than the burning level ?
Alan Longmire Posted May 23, 2018 Posted May 23, 2018 Going back to the original post, one thing nobody has addressed (although Mr. Giagni came close) was the question of whether the steels in the blacksmithing book were the same as those in the bladesmithing book. No, they are not. Blacksmiths use mild steel, low carbon in in the 0.18-0.25-ish %. Bladesmithing steels are in the 0.60-1.20% carbon range, which makes a huge difference in behavior. Then there are the other alloying elements we use that blacksmiths do not. Our steels have more manganese, chromium, vanadium, silicon, tungsten, nickel, and other fun things that can cause problems if forged too hot or too cold. Problems like turning into the steel equivalent of cottage cheese when too hot, or filling with microfractures when too cold. With mild steel all you have to worry about is burning or breaking at higher and lower temperatures than we usually use.
GPrimmer Posted May 23, 2018 Author Posted May 23, 2018 (edited) 54 minutes ago, Alan Longmire said: Going back to the original post, one thing nobody has addressed (although Mr. Giagni came close) was the question of whether the steels in the blacksmithing book were the same as those in the bladesmithing book. No, they are not. Blacksmiths use mild steel, low carbon in in the 0.18-0.25-ish %. Bladesmithing steels are in the 0.60-1.20% carbon range, which makes a huge difference in behavior. Ahhh... thanks! That would explain the difference..they both used the same terminology and didn't seem to contradict each other at any other point. Odd though, I went back and looked and while Jim mentioned 'carbon steels', Lorilei never mentions what particular steel she is working with in that section. Vern, thanks for the details! Lastly, I don't have a lot of equipment and tools, but one thing I do have access to is a Temperature Gun as shown here: http://www.reedinstruments.com/product/reed-r2007-dual-laser-infrared-thermometer I'm kind of shocked I've not seen it used before in any of the online videos or instructionals, but I thought, as a beginner, it might help me pinpoint these 'colours' more effectively...at least starting out. Edited May 23, 2018 by GPrimmer
Alan Longmire Posted May 23, 2018 Posted May 23, 2018 Yep! Lorelei is using mild steel, which over here is usually A36, a grade of remelted scrap that does not have a carbon content specification. It just has have a minimum tensile strength of 36 Kpsi. The carbon can vary wildly, but there's never enough for a good blade. We can also get 1018 and 1020 if we're willing to pay extra for clean, easier to weld mild steels. You don't see us using IR thermometers because they are both expensive and do not work on glowing steel. They are calibrated for black body emissivity, and if you throw incandescent heat at them they freak out. That one does spec that it reads up to 2012 degrees F, which is much higher than I have seen on any other unit, but I have my doubts it does so with any accuracy. When we need to know the temperature we use a pyrometer setup consisting of a type K thermocouple and something to read it with.
Brian Dougherty Posted May 23, 2018 Posted May 23, 2018 23 minutes ago, Alan Longmire said: You don't see us using IR thermometers because they are both expensive and do not work on glowing steel. They are calibrated for black body emissivity, and if you throw incandescent heat at them they freak out. That one does spec that it reads up to 2012 degrees F, which is much higher than I have seen on any other unit, but I have my doubts it does so with any accuracy. When we need to know the temperature we use a pyrometer setup consisting of a type K thermocouple and something to read it with. I get about as irritated when people use these things as Jarrod does when people talk about tempering colors. I have seen them be 200% off with surfaces that had emissivities that were odd. Many years ago I was a test engineer in an elevator manufacturing plant. I got into an argument with a design engineer over a new product were were making. There was a shiny (reflective) copper plate in the product that I was concerned was getting too hot. This guy came out with his IR temp gun and told me there was no issue, that it was only 120F. You could see the heat (and smoke) coming off of it, so I told him to touch it if he felt his measurement was accurate. (He declined) The guns are tuned for something that has an emissivity near 0.95. (A perfect black body is 1.0) A shiny surface will be much lower. If I remember right, I back calculated that the copper must have been closer to 0.3, but that was 20 years ago. I do remember that once I finally got a thermocouple bonded to it, it was over 350F. As Alan said, the inaccuracy gets worse once the surface is incandescent. There are optical pyrometers out there that are supposedly good for glowing materials, but I haven't had the opportunity to use one yet. The ones I have seen for sale are quite expensive. -Brian
GPrimmer Posted May 23, 2018 Author Posted May 23, 2018 That's excellent feedback, Brian & Alan...thanks for commenting on the temp gun. I'll learn the ol' fashion way then.
Brian Dougherty Posted May 23, 2018 Posted May 23, 2018 I came off a bit harsh... The "IR guns" do have their place, and I actually own two of them. I keep one in the kitchen to check the temp of my cast iron frying pans before the food goes in, and I use another to check the shell temps of my pet tortoises. -Brian
Jerrod Miller Posted May 23, 2018 Posted May 23, 2018 I had the chance to play with an IR gun that was supposed to work on liquid steel. You had to determine the emissivity constant for that grade, but once you did that and plugged it into the unit it worked fairly well. Until smoke or slag got in the way. Which it did. Constantly. And that gun was $30,000.
