MatthewBerry 68 Posted June 5, 2018 Share Posted June 5, 2018 (edited) I finally finished my first viking sword that I made all-by-myself. The big challenge on this one is that wide shallow fuller - I've never done that before and it looks difficult to get right. Here's the sword blank (1075 steel) with the bevels forged in. I shaped the initial blank with the power hammer, and then hand forged the tip and the bevels. I didn't take a picture, but the bevels are forged in with a spring tool whose dies are radiused to 6". Here's the result: Slightly crooked, but it gets a lot of the steel to the right areas and significantly widened the blade. It also made it about an inch longer. I did run the fuller all the way back through the tang. One of the biggest challenges on any sword is getting it straight in all dimensions. Here's how I start to establish a straight edge - marking fluid and a scribed straight line down the edge. It will move during the hardening process, but it's much easier to get back to straight when that's where you started. Doing it this way also means that I don't have to rely on the sword sitting flat on a surface. The fuller being straight struck me as the biggest challenge of the blade, so I made this contraption to grind the fuller straight: It's essentially a really big work rest (with legs) and a sled to hold the blade level as I move it. It worked very well for the rough grinding of the fuller. It got it nice and straight. After that all the grinding was done by hand. Not ruining the nice straight fuller is much easier (but not easy) than trying to establish one by hand. The wooden sled is a prototype and I learned a couple important things from it. First, make it metal as I set it on fire during the grinding. Second, without some kind if repeatable indexing for holding the blade you can never get the blade back in the same position again, so make a better sled or do all the grinding you can the first time. And yes, that's a 6" wheel on the grinder. The finished blade was pretty much straight. The sides of the fuller are a bit wobbly because that line can't directly be made straight - it's created by the interplay of the fuller and the bevels and is affected by the thickness of both. All you can do is make both as straight in all dimensions as possible and then do some cheat grinding where you didn't get it quite right. The guards and pommel are carved from wax. I modeled them after an original that I think is in the Swedish National Museum (but I could be wrong). I get the overall shape completed and fit them to the blade before I start decorative carving. That way if I blow some fundamental dimension or the fit, I haven't ruined lots of hours of carving. Skipping over a whole lotta work, here's the final product: The blade is 28" (711mm) long and the sword is 34" (863mm) overall. It weigh 2lbs 13oz (1146g). The handle is stabilized cherry burl, and the fittings are all bronze (90% Cu, 10% Sn) I'm fairly happy with it. I'm going to make the next blade a touch thinner as this one has a little more forward weight than I personally like. But then again another smith who held it said it was the first sword he really like because of that slight forward weight. It does let you know exactly what it's for - cleaving. Edited June 28, 2018 by MatthewBerry 7 Link to post Share on other sites
Kris Lipinski 136 Posted June 5, 2018 Share Posted June 5, 2018 Top notch! Wonderful work! Link to post Share on other sites
Brian Dougherty 1,093 Posted June 5, 2018 Share Posted June 5, 2018 Great work, and a very informative post. Thanks! Link to post Share on other sites
Justin Mercier 65 Posted June 5, 2018 Share Posted June 5, 2018 awesome job Matt ! Link to post Share on other sites
Wesley Alberson 138 Posted June 5, 2018 Share Posted June 5, 2018 That hilt is beautiful! The carvings are large and dramatic, a legendary looking sword. Link to post Share on other sites
Doug Lester 270 Posted June 5, 2018 Share Posted June 5, 2018 Most excellent; well done. Doug Link to post Share on other sites
Vern Wimmer 472 Posted June 5, 2018 Share Posted June 5, 2018 Very impressive. A lot of work obviously but the result was worth it. Link to post Share on other sites
Clifford Brewer 357 Posted June 5, 2018 Share Posted June 5, 2018 Nice job, I was thinking on making a work rest like yours and you answered the question I had about wood versus steel for me. I recently acquired a milling machine and now with it along with my lathe the excuses for not making the custom tooling I want are gone.......mostly,....huge garden, .......huge lawn,......ect. ect....... Link to post Share on other sites
Charles dP 458 Posted June 5, 2018 Share Posted June 5, 2018 Nice Matthew.Very interesting pommel on that one. Thanks for the info. Link to post Share on other sites
Alan Longmire 2,637 Posted June 5, 2018 Share Posted June 5, 2018 Now that's how to do it! And so informative on the process it's getting pinned, so there. Link to post Share on other sites
Wes Detrick 487 Posted June 6, 2018 Share Posted June 6, 2018 Damn that is some fine work! Link to post Share on other sites
Pieter-Paul Derks 207 Posted June 6, 2018 Share Posted June 6, 2018 Amazing sword! the blade is very crisp and I love the handle shape Link to post Share on other sites
Kris Lipinski 136 Posted June 6, 2018 Share Posted June 6, 2018 Again - a great work. Now I had the time to read all and watch the pictures with proper attention I admire the details: particulary bronze castinings and the scabbard - is that curved wood covered tightly with leather? It looks luxury and like it was saying "be in respect what I'm concealing inside!" Great work sir! Link to post Share on other sites
MatthewBerry 68 Posted June 9, 2018 Author Share Posted June 9, 2018 Thanks guys! Glad you like it. On 6/6/2018 at 3:13 PM, Kris Lipinski said: is that curved wood covered tightly with leather? Yup. It's kinda the Peter Johnsson method - two thin slats on each side. The inside is lined with wool felt before gluing. Then i used a layer of hide glue between the slats and wrapped the whole thing up with a bicycle tire tube cut into a huge strip. The outer leather is sewn on wet over a coating of hide glue. Link to post Share on other sites
Kris Lipinski 136 Posted June 9, 2018 Share Posted June 9, 2018 Thank you sir! Link to post Share on other sites
peter fontenla 98 Posted August 1, 2018 Share Posted August 1, 2018 Wonderfull work Matt!!!! Link to post Share on other sites
John Page 68 Posted August 18, 2018 Share Posted August 18, 2018 Awesome stuff Matt! I really like the jig you came up with. It makes a lot more sense than the clamp-to-an-angle-iron thing I tried a few times without much luck. With the blade exposed on both sides it makes centering the fuller on both sides symmetrically a breeze! Next time I'm up in your neck of the woods I'm going to have to pick your brain about lost wax casting. Everything that comes out of your shop is top notch! John Link to post Share on other sites
MatthewBerry 68 Posted August 19, 2018 Author Share Posted August 19, 2018 On 8/18/2018 at 1:43 AM, John Page said: Awesome stuff Matt! I really like the jig you came up with. It makes a lot more sense than the clamp-to-an-angle-iron thing I tried a few times without much luck. With the blade exposed on both sides it makes centering the fuller on both sides symmetrically a breeze! Next time I'm up in your neck of the woods I'm going to have to pick your brain about lost wax casting. Everything that comes out of your shop is top notch! John I have to give credit for the idea to Peter Johnson - Emilliano described the jig Peter was using to me, and this was my first attempt at something of the kind. Definitely stop down next time you are around and I can show you how the whole bronze-casting thing works. Link to post Share on other sites
Conner Michaux 271 Posted August 19, 2018 Share Posted August 19, 2018 Thats one good lookin sword! Link to post Share on other sites
