Joshua States
Bones says.......
It's dead Jim
VFD controller
Burnt spot on the mother board
Compressor pump
Broken exhaust port
The technical term is "FUBAR".
It's not FUBAR, it's still recognizable.  That does suck, though.  Moving always claims a few nice objects.  Last time it was most of my home brewing setup.
You might get away by just replacing the transistor that used to be in that spot in the VFD.  Most likely some other fault caused it to blow, but for  the couple of bucks it would cost, it's worth trying.
Must be the season of wither; smoked a capacitor on my belt grinder the other day...it is hard to find a replacement here so far. Good luck with repairs.
Actually, there were two burnt spots on the motherboard and I have spent time inside of electronic gizmos fixing and replacing fiddly bits. These were not going to be repaired. Once the board melts, it's pretty much done as far as I'm concerned. I just bought a new one from Beaumont. Cha-ching!
If you'd like to have it, and give the repairs a go, I'll send it to you. Flat rate shipping is probably about $25.
That's a catastrophe!
Just a lot of broken glass to replace.  Cheaper than a VFD by a long shot!
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
