Vern Wimmer Posted July 12, 2018 Posted July 12, 2018 I decided to read through threads in the last couple of years, to make sure the information was current. Here is a set of links to threads that are almost certain to contain the answers to questions in the minds of beginners. I can't stress reading all of them strongly enough. If you do that you will have enough knowledge to go forward with a forge build. The only thing I will add is that it is not necessary to use an old propane tank with the inherent dangers. A new tank, a freon tank or an aftermarket air tank will also work as will many other improvised shells. BUILDING THE FORGE.https://www.bladesmithsforum.com/index.php?/topic/35951-my-propane-forge/https://www.bladesmithsforum.com/index.php?/topic/20420-buying-a-gas-forge/https://www.bladesmithsforum.com/index.php?/topic/37464-new-forge/https://www.bladesmithsforum.com/index.php?/topic/37437-yet-another-forge-build-question/https://www.bladesmithsforum.com/index.php?/topic/35170-applying-kast-o-lite-to-ceramic-wool/https://www.bladesmithsforum.com/index.php?/topic/36345-lining-forge-question/ BURNERShttps://www.bladesmithsforum.com/index.php?/topic/25573-blown-burners-the-care-and-feeding/https://www.bladesmithsforum.com/index.php?/topic/36658-blown-twin-burner-experiment/https://www.bladesmithsforum.com/index.php?/topic/26862-my-take-on-a-venturi-burner/https://www.bladesmithsforum.com/index.php?/topic/36415-that-could-have-ended-poorlyburner-issueq/https://www.bladesmithsforum.com/index.php?/topic/36128-atmospheric-vs-blower-burners/https://www.bladesmithsforum.com/index.php?/topic/36915-forge-burner/https://www.bladesmithsforum.com/index.php?/topic/35082-first-burner-build/https://www.bladesmithsforum.com/index.php?/topic/36472-cfm-for-electric-blower/ 1 2
Wayne Coe Posted July 13, 2018 Posted July 13, 2018 Don't forget the Build a Gas Forge and the Ribbon Burner attachments on the Forge Supplies page at www.WayneCoeArtistBlacksmith.com. Let me know if I can help you. I prefer e-mails. 1 Wayne Coe Artist Blacksmith 729 Peters Ford Road Sunbright, Tennessee 706-273-8017waynecoe@highland.netwww.WayneCoeArtistBlacksmith.com
GPrimmer Posted July 13, 2018 Posted July 13, 2018 HAHAHAHA... Vern, did Andy and I finally drive you off the deep end? Nice compilation!
Daniel W Posted July 16, 2018 Posted July 16, 2018 I kinda wish this list was pinned up and available when I was doing all my forge building experiments. I must have searched through the forums for quite a while looking for old posts that I remembered with good info on the subject. I do feel like I should now add a little to the link that I started as some things have changed to my "First burner build" that has resulted in a easier burner to put together. I also have not yet put any IR reflective coating on my forge walls, and I do want to get to that.
Kenneth Mauldin Posted July 16, 2018 Posted July 16, 2018 Awesome I am going to build my first forge soon and I recently startes reading old threads.Thanks for this thread
Gerhard Gerber Posted July 17, 2018 Posted July 17, 2018 ....and I will build another... ...one way or the other!
Ross Vosloo Posted July 17, 2018 Posted July 17, 2018 needs a pin Ross Vosloo Mhara Knives made in Zimbabwe https://www.mharaknives.com
Vern Wimmer Posted July 17, 2018 Author Posted July 17, 2018 (edited) 21 hours ago, Daniel W said: I kinda wish this list was pinned up and available when I was doing all my forge building experiments. I must have searched through the forums for quite a while looking for old posts that I remembered with good info on the subject. I do feel like I should now add a little to the link that I started as some things have changed to my "First burner build" that has resulted in a easier burner to put together. I also have not yet put any IR reflective coating on my forge walls, and I do want to get to that. Your thread and the addition you just added are great. Not just for the build info but for the way you logically tested it and analyzed the results. Edited July 17, 2018 by Vern Wimmer
Daniel W Posted July 20, 2018 Posted July 20, 2018 Thanks Vern, when I started the forge build I used materials that were available at the time so that I could get to work. I did want to show that it is possible to put together a forge with those materials - but ultimately, it will not work as well as the tested materials. Now that I've reached out and made some networking connections - I now have access to the better materials so when I need to reline the forge I expect it to preform better. Something else I want to stress to new comers too . . . You don't need a very big forge. At first I though my forge would be too small, but turns out at times it's really too big! I'm doing much more decorative and architectural things, and the propane forge is never just the right size for me. But If I were working flat stock knives, I'd be able to work 20 of them at a time. For people wanting to build a forge just for knife work, you can get away with making a really nice tight compact design that will not kill your budget when your going after materials. The right materials. 1
Sam F Posted February 3, 2020 Posted February 3, 2020 Has anyone tried using compressed air, in place of a blower? If you put compressed air up the pipe it will create a vacuum and suck more air with it.
Alan Longmire Posted February 3, 2020 Posted February 3, 2020 The trouble with that is you get way too much air in the mix, which gives you a very oxidizing forge atmosphere. You really don't need very much air at all. That's why venturi burners work, they use compressed propane to suck in the air, and we then choke the intake to reduce the amount of air getting in. Just the reverse of using compressed air, but they both use Bernoulli's Law.
Jerrod Miller Posted February 3, 2020 Posted February 3, 2020 Also, this is pretty big in the industrial side of things: Compressed air is more expensive than you think it is. Blowers are much cheaper and if you can get away with a blower instead of compressed air, you should.
Sam F Posted February 3, 2020 Posted February 3, 2020 I was thinking of using the compressed air as a ventruri. One thing I didn’t think about is nether moisture that’s would come with it. I’m using an old 16” dia air tank for my forge. It will be about 24” long. I was going to make a 12”-14” ribbon burner. How would I figure out what blower I need?
Sam F Posted February 3, 2020 Posted February 3, 2020 When I say compressed air, I mean using the air from my shops air compressor. I was thinking of using the compressed air as a ventruri, where it would suck more air in with it. I could regulate the air flow with a regulator or a valve. One thing I didn’t think about is the moisture that I would get out of the compressors. I’m using an old 16” dia air tank for my forge. It will be about 24” long. I was going to make a 12”-14” ribbon burner. How would I figure out what blower I need? .
Jerrod Miller Posted February 4, 2020 Posted February 4, 2020 Considering you are asking these questions, I will assume this is your first forge. I'd shelve the ideas you have now and read a LOT more. That is a gigantic forge. You do not want to have one that large unless you absolutely need it. Start much smaller. You will want more than one forge eventually anyways. They are like tongs and hammers, each has their purpose, some more than one, but no one is good at everything. There are a lot of forge build threads on the forum (and all the links at the start of this thread). Read them and choose a small forge to try out. Learn small, work bigger.
Alan Longmire Posted February 4, 2020 Posted February 4, 2020 More good advice from Jerrod! For a forge that size, which is indeed huge, a 2"x6" ribbon burner is more than enough to melt the lining. This is with a 100cfm blower choked almost closed. You really, really do not need that much air.
Sam F Posted May 25, 2020 Posted May 25, 2020 When I say compressed air, I mean using the air from my shops air compressor. I was thinking of using the compressed air as a ventruri, where it would suck more air in with it. I could regulate the air flow with a regulator or a valve. One thing I didn’t think about is the moisture that I would get out of the compressors. I’m using an old 16” dia air tank for my forge. It will be about 24” long. I was going to make a 12”-14” ribbon burner. How would I figure out what blower I need? . Thnx for you help
Geoff Keyes Posted May 25, 2020 Posted May 25, 2020 Are you making connecting rods for a locomotive? The forge you are describing is sized for jobs like that. I have forge that is 16" long inside with common rail twin burner. I only use it to make damascus billets because I make big billets. And I have a 30 ton press to weld them and draw them out. When they get so long that I can't reach the controls on the press, I cut them off. You don't need a forge this big to forge knives, or even swords. I have forged a 32" blade in the same forge I use to make 3 inch hunters. Now when it comes to heat treating longs blades it's simpler to have a long forge, but in fact, if you're clever, you can do that in a 6 inch long forge, it just takes some patience. A big forge is also a gas hog. But a 100 - 150 cfm fan would still drive it. In short, your forge is about 4-6 times bigger than it needs to be, unless steam engines are in your future. Geoff "The worst day smithing is better than the best day working for someone else." I said that. If a thing is worth doing, it is worth doing badly. - - -G. K. Chesterton So, just for the record: the fact that it does work still should not be taken as definitive proof that you are not crazy. Grant Sarver
