Jeremy Blohm
Eitr seax of King Eric Bloodaxe.
Is that a Seax or axe? :D
Yeah, it's pretty big. I would just draw it out longer and make that point longer too. If you can.
It's about a half inch wide also. I had a delamination at the tip so I cut it out before it could progress any more. I had to stop for the day but it looks like everything is solid. It wouldn't be a problem to draw it out more. I'm getting propane in the morning g so I can work the whole blade hot. I think that's how the tip started delaminating. It was a little to cold when I was drawing out the back of the blade. And I flipped it on its side and hit the tip a little cold.
This will be my first seax....so naturally I have a couple questions. First the grind...full flat no plunge line? Second...distal taper? Third...slight reverse taper with a slight belly under the break of the spine?
Read through this. I'll give you what little knowledge bequithed to me that I could access if you want more.
Edited by Zeb Camper
And remember it's a reverse taper. It gets thickest at the peak of the spine, then tapers to the point.
Thanks zeb!!!
Here is A sneak peak at the pattern
19 hours ago, Jeremy Blohm said:
Resized_20180820_162957.jpeg That.. is one giant knife..
Wicked!  But full flat grind if you want to be accurate.  As a magical/fantasy blade though, that rocks!
Thanks Alan!!!
Got the call today with a surgery date... September 10. Its sooner than I thought it would be.
In going to have to look that one up.
The one image I seen looks really nice. And very similar. I'm going to search a little deeper.
I'm tempted to move this to show and tell as a WIP now that it's a blade and not a failed attempt.
I got the fittings for the handle roughed out and dropped the tip a little to make it look more seaxy.20180824_143205.thumb.jpg.3413f1a9a5fa926b95b87b2ee65c54db.jpg
I will get a picture of all the handle components in a little while when o get back to the shop.
The blade is hardened and I just put it through its first tempering cycle. I will temper again in the morning and it's back to the shop to do the final grind and start assembling the handle.
Cool. Can’t wait to see her finished.
I'm almost finished with the grind. And then it's on to the handle. I will have the grind done tonight. I had to take a break for the day. It doesn't help in need a bigger drive wheel to get the grinder going faster. Looks like I'm heading to OBM's Ebay store.
Time for hand sanding.
We finally have power back at the shop. I had brought my 2x72 home to do all the grinding. There is a big rust spot on my back patio. I wonder if the appartment manager will get after me for it. :lol:
Hand sanding is done. I am going to acid etch it today and I'm going to start getting the handle components drilled tonight. I have all day tomorrow to assemble the handle and do some finish work.
Dry fit
In know historically a seax rarely had metal fittings but I chose to use a piece of wrought on the end and I'm going to peen the tang so I have a mechanical hold. This is the second through tang I have done so I don't want to take any chances.
Almost done!!! Just some finish work to do.  I didn't realize how long the handles were historically until after I had everything assembled but I think it looks OK.
