Quick & Dirty Design method.
Joshua States
A question came up on another forum about proportions of handles to blades and the ensuing discussion was rather diverse. It did lead me to put together a short step-by-step of how to design a knife from scratch and I thought I might post it here for those of you struggling with freehand sketching and getting the form and profile to flow.
First I decide on what type of knife it will be. For this one, I will do a smallish Bird & Trout/EDC knife.
In the first step, I draw a cross on a piece of plain paper. This represents the Center line of the handle and the front face of the guard.
Now I make two lines perpendicular to the center line to denote where the end of the blade and grip areas are.
Then I decide on the width of the blade and draw parallel lines to create a design box. This B&T will have a 3/4" wide blade so the lines are 3/8" either side of center.
Take a French curve and put in the edge. Decide what type of point (in this case I decided to drop the point a little) and define the ricasso if you have one, and the guard thickness.
Add the Choil, the guard length and the spacer (again, if you have one)
Start sketching the handle profile freehand using the box as a guide.
Make a bunch of erasures, change it a little here and a little there until it looks like it might just work.
Then I place the drawing on the floor and walk around it to get multiple perspectives. I will make more subtle changes to this drawing as I go. Once I have the profile set, I start adding more details in the form of notes along the side of the drawing. Handle materials, furniture material, pins, handle type (frame, solid, etc.) any embellishments (file work, multiple spacers in a package, etc.) Then I'll add a top and bottom view sketch and a cross section of the heel and the guard. Then I make photo copies and add the tang inside the handle/spacer and prepare templates for the blade and handle from the copies. Then I am ready to start forging the blade.
Nice break down of the geometry, like  a cross between basic drafting logic and art 101 base lines for sketching.
Well done Josh................................B)
Edited by Clifford Brewer
If ya can't be good don't git caught  !!                                        People who say stuff can't be done need to
        git the hell outta the way of people who do stuff   !!!
Show me a man who is called an expert by his peers
And I will show you a good man to listen to ......
Show me a man who calls himself an expert
and I will show you an egotistical asshole...............!!
Quote
So, you've used 4:4.75 .
Was that the consensus in this 'other' discussion? (I like your design, by the way!)
There was no consensus. There are too many variables based on style and function. The only real consensus is that form always follows function. The proportions are a facet of form and will vary based on style and function. The ratio of handle to blade will differ across typologies. A chef's knife will have different proportions than a puuko which will differ again from a Bowie.
That's why the initial design drawing becomes a critical step in the process. It allows the maker to lay out the proper proportions before any fabrication starts.
