Paul Carter Posted August 7, 2018 Share Posted August 7, 2018 How can I lock the tempering color into the blade? Can this be done by quenching in oil after taking out of the temper oven? Thanks for any help. Link to comment Share on other sites More sharing options...
Wesley Alberson Posted August 7, 2018 Share Posted August 7, 2018 While beautiful, the tempering colors on steel are very thin and can be rubbed off easily. Using oil or some sort of wax could possibly create a barrier to keep the surface from rusting, but it won't really help if the knife is used. Even processes like color case hardening are only used for fittings on knives and guns that won't come into contact with many things that could rub it off. If you are looking to give your steel some color, I would recommend looking into cold bluing, which is somewhat durable, and I have seen others use it on blades. "Yeah, well, you know, that's just, like, your opinion, man" -The Dude, Instagram: https://www.instagram.com/rougemont_forge/ Link to comment Share on other sites More sharing options...
Paul Carter Posted August 7, 2018 Author Share Posted August 7, 2018 Thanks! I was afraid there was no real good way to lock in the color. Soapy water washes it right off. Link to comment Share on other sites More sharing options...
Jerrod Miller Posted August 7, 2018 Share Posted August 7, 2018 Also, please don't rely on those colors to achieve a reliable temper. They are not consistently accurate. 1 Link to comment Share on other sites More sharing options...
