Brian Dougherty
Design for a boning knife
I could use a bit of advice from people who cook for a living.
One of my more recent interests has been charcuterie, and I find myself disassembling a pork shoulder on a pretty regular basis.  Getting around the funky little bone in them is a bit of a challenge.  Currently the best knives I have in the kitchen (from a cutting perspective) are a 4" paring knife, and a 10" gyuto.  Neither of these are great at cleaning up around the bone, or removing silver skin.
I'd like to make a boning knife, but having never used one, I don't really know what is best for that sort of application.  I have loads of 0.075" thick 15N20 at my disposal, so I was thinking about using it to make something similar to this 6" Victorinox in profile.  I would expect to put a pretty good deal of distal taper into this and temper it a bit high to make it pretty flexible.
So, my questions is: "Is this the right approach for a knife to break down a pork shoulder?"  There seems to be two camps out there.  Some boning knives are stiff, and others are flexible.  It also seems like people divide tasks up into making delicate cuts on things like fish, or rough work on beef and pork.  The latter makes me think I need to make a stiffer knife, but my experience with the paring knife doesn't agree with that.
This is probably one of those ask 5 people and get 6 answers sort of thing.  Maybe I just need to make both knives :)  Anyway, thanks in advance for your opinions!40015.jpgPicture liberated from Victorinox website
If you have the right touch a fish fillet knife seems to work well. As long as you can visualize the bone and what you can't see.
Brian, I think you might have almost answered your own question.
So what is it about the paring knife that you like? My guess is the short, thin blade to get into the tight spots, but you know better than I what you like. What is it about the paring knife that you would change or what makes it not do something well?
Kitchen knives are heavily dependent upon personal taste and how the person uses them, holds them, cuts forward and/or backward etc.
I have more than a couple of sharp objects in the knife drawer and I use different ones for different functions. Believe it or not, the knife I use to cut pork loin into chops gets used because it is the right width to create the perfect thickness of chop. Lay it on its side, stand it up and cut. Perfect chop thickness every time.
If it were up to me, I would leave a bunch of meat on the bone for making soup stock and use what ever knife got the job done with those limits. I sort of rambled off there a bit...….
I've been thinking about exactly that over the evening.  The narrow blade of the paring knife relative to the Gyuto is an advantage, but that shouldn't be news to anybody.
The things I don't like about the paring knife are:
1. It's too short.  This is an easy one to fix :)
2. It tends to catch on the bone when I am carving around the inside curves.  (The pork shoulder blade has a concave surface)  At first I associated this with it being too stiff.  However, the more I think about it, maybe the blade is still a bit too wide.
The paring knife is one of these:  It's probably about 3/4" at the heel.
K7Y0z6Z6sAVE3y-7s8BEclj2Shzr_NC5__TZnxST
I think a long floppy knife would be problematic, but I also think it needs to be more flexible than the paring knife, (Which is very stiff)
I don't fish anymore, but I have an old fillet knife stashed away somewhere.  If I can get an edge on it, I may try it per Vern's suggestion to get another data point.
The boning knife is generally very similar to the Victorinox you have posted in the initial thread. I make them with a 4 inch blade  from 1/8 steel and maintain the same FF grind angle from the width of the blade at the plunge so this induces a distal taper but the blade is not flexible so that it can be used hard against the bone without flexing away from it.  This is the different between the boning knife and the filleting knife which needs a flex so it will not catch and cut the lighter fish bone compared to the harder pork, beef etc bones.
Edited by Garry Keown
1 hour ago, Billy harex said:
4'' blade thats tiny im not used to anything under 6'' or rather don't like to use anything less be interesting to try one
Boning out animals the butchers mostly use the last inch to inch and a half of the blade so anything longer makes for a less accurate use as the tip is further from the hand
https://www.bing.com/videos/search?PC=SL10&q=boning+out+a+leg+of+lamb&ru=%2fsearch%3fFORM%3dSLBRDF%26PC%3dSL10%26q%3dboning%2bout%2ba%2bleg%2bof%2blamb&view=detail&mmscn=vwrc&mid=97BE9CE673ABAC0C8A1097BE9CE673ABAC0C8A10&FORM=WRVORC
Ive been boning beasts for years garry i trained a lot of blokes to bone also.
I don't rate butcher's or their knives to be honest but they wouldn't rate my small cuts either. Boning is all about hitting the right seems and pulling to vet a super clean bone rather than cutting down the bone. I know plenty of blokes that use a smaller knife its all about personal feel my reference to trying one was to one of yours
The
On 11/10/2018 at 2:49 PM, Wesley Alberson said:
My friend makes a nice boning knife, cut from thin stock, heat treated, and ground.
The back of this knife garry is the perfect style for boning its curves hurts your wrist with a striaght back
Thanks for the additional input guys.
I've been promoted at work, which is generally a good thing, but the transition has kept me from my hobbies the last few weeks.  Once I get back into the swing of things, I'll need to get my boning knife made.
So it seems ive greatly upset you garry it was not my intention i wish to apologize on this forum also you say im a self proclaimed expert m not an expert at all n any fashion and defiantly dont think that in any way shap or form i thought i was just pointing out the obvious as some times that gets over looked. Hope you can take this for what it is and not take it personally as for the whole never replying to me again im here for knowledge for people wishing to pass on their skills. Again my apologies for upsetting you ill tred lightly in the future
I musta missed something... Garry just gave his opinion. I dont see that he got upset at all. I could be wrong, but I see no red flags. Everyone will have their own opinions. Don't sweat the little stuff man!
On another furum told me he will no longer speak to me i said something that offended him an it probably was in regards to me being new and unknown definitely not my intention he quoted this thred i didn't even know i was speaking to the same person im Just trying to apologize and move on because i would hate to lose his seemingly amazing knowledge of knife building i thought if i apologized on here also where i may have upset him would help
You do seem to have a very opinionated idea on boning knives both here and on the other forum. You might use a boning knife (and teach others to use them) but just as there are differing sizes of animals that require differing sizes (and styles ) of knives it does not mean that one style is wrong and only your idea of a style is correct. A self proclaimed "expert" is not a good look.
Your posts have become tiresome in a very short order and I will not be responding to them again.this is my telling of here i said to get this reaction no one seems to understand what a seasoned boning knife looks like. So i can see where his coming from i just didn't know it was tge same bloke his name is von gruff on the other one
Well, not everyone agrees and not everyone will like you. It's just the way life is. It's best to handle these types of things in a PM though. Chances are you're apology will be taken more sincerely in private, as it seems a bit standoffish as of now.
Maybe the mods can come clean this up?
Gentlemen: I think that's enough on the matter. Let it go.
Sorry im not even sure how to msg or that we can im super new to all the groups and 100% understand ive been a bit brash Thanks for your advice i am taking it all on board im new to this whole talking on a computer thing as well so my communication skills need a kick in the pants
No worries, this particular forum is all about respect.  Fair dinkum, if I may try Aussie idiom.  Garry has proven himself a good maker.  I'm sure you're a good butcher, but so's my dad.  He likes a 6 inch boning knife himself, but he leaves a lot of meat on the bone because he's after speed over efficiency.  But that's neither here nor there.  On this forum we are ladies and gentlemen, and respect for one another, and above all the Art, is what it is about.  Have it out elsewhere if you must.  Just not here.  Understood?
I am off for the night, shake hands and make nice.  Brian, sorry about the hijack!
9 hours ago, Billy harex said:
Understood indeed sir my apologies are fair dinkim. im about to grind out a blade from a unknown steel wish me luck
Good luck! Post pics!
Sorry for the hijack Brian. Looking forward to see what you make!
Im not a butcher thou i dont rate butcher's knives at all I've trained a few butchers to bone beasts and their knives are always poor grind poor edge im always fixing them thenthey can winge and quit because its to hard if you bone say bovis 10 hours with a straight back knife your arm, hand are sore the curve helps to ease the wrist
This thread may be long dead (have you made your boning knife yet?), but I'll chime in anyway. I was a chef and restauranteur for a bunch of years. I use two knives for boning: a traditional 6" blade that is stiff (identical in shape to the victorinox you've pictured, it is a thiers issard carbon and has a very pronounced bolster), and a very small, very sharp paring knife. It's a nogent with a 2.5" blade and a straight edge. The round hilt makes maneuvering in tight spaces a breeze. Interestingly I have the exact same knife (thiers issard nogent paring, fyi) in the 4" length and I cannot use it for boning. It's just a weird, in between size for the task. That said, for big jobs, like leg of lamb or pork shoulder, I almost always start with the boning knife. The very curved blade (a rarity among knives that chefs use) is perfect for the 'waving motion' that is required to separate skin from muscle and slide along nerves and tendons and bones. If you watch videos of boning (if you're doing charcuterie you've likely seen a few), you'll note that the hold is different. A chefs knife or paring knife is held on the hilt, often with fingers on the blade itself, for fine control of the tip and the and the angle of the cut. A boning knife is held entirely on the handle, as the motions used and control needed are entirely different. Boning is a very subtle touch, where you're slicing with the 'waving' motion and trying to feel slight differences in texture and density so that you can slide through and get as much meat as possible. A relatively thick blade means that you don't have to change knives when going around large bones and you can work through joints with both dexterity and strength. It should also be long enough to take a whole piece of skin from say a pork shoulder or belly. In some instances I wish mine was 7" for that purpose. I hope some, or any, of this is helpful. Good luck.
Edited by Aaron Matzkin
adding photo
  • Thanks 2
I have no boning knives in the book but I'll come back here for reference if need be. Thanks Aaron!
