Ambitious Damascus Project
Aces Gary. All aces on this one.
3 hours ago, Dave Stephens said:
Man oh man . . . that jigsaw puzzle is going to be a challenge to weld. Looks like it would want to fall apart in every direction of the compass. Definitely a "look what I can do" weld! Love it.
Extremely interesting ideas, Gary. Really looking forward to seeing the end result.
Thanks for sharing so generously.
Dave
I've not  tried a weld like  this before but I'm thinking that a lot of the success or failure on this one will depend a lot on how tightly I can fit all the pieces before fitting them into the can.  For many types of welds I can forge any gaps together before welding the pieces but on this one I would be a little leary of doing that so I'm going to take the time to fit everything tightly to start with.  It will require a little more set-up time but should be worth it in the end.
Also, I think that making the can (or canoe) tight enough to hold all the pieces together tightly will be essential to getting good welds.  We'll see.;)
Gary
ABS,CKCA,ABKA,KGA
I think you're spot on, Gary. Cold fit is going to be the key.
Have you considered just running a MIG bead down every seam instead of a can/canoe? It would mean a lot of grinding after the initial weld, but it would hold things in place until you set it, and you could do it without flux.  Just a thought.
Luck!
Dave
http://stephensforge.com
Luck!
Dave
I debated on doing a MIG on each joint but decided not to as even with minimum welding penetration it would waste a lot  of material as well as requiring a lot of  grinding.  I got all of the corners ground to a good 90 degrees this morning as well as to make all of  the squares exactly square.  After a bit of a break, I'll start making the canoe  later this afternoon.  I  plan on super gluing all of the components together, placing them in a partial canoe with just two sides.  I'll then MIG the last two sides (and the cap) on the canoe tight up against the billet to insure a tight fit.  Hopefully that will hold everything in place until it's all  welded solid.  I'll probably set the welds by hand with light blows first before going to the press just to be safe.
Edited by Gary Mulkey
Gary
ABS,CKCA,ABKA,KGA
3 hours ago, Brian Dougherty said:
Can you superglue the pieces without contaminating the weld?  That would certainly be a handy trick!
I don't know. He lost me somewhere on the first page....
Super glue burns off long before you get to welding temp and doesn't  contaminate the weld.
Gary
ABS,CKCA,ABKA,KGA
Well, I got this billet welded today.  I decided to put a spot weld with  my MIG on the confluence of the pieces just for insurance.
IMG_0385_opt
I didn't have any white out to coat the canoe with so I tried some aluminum foil.  this was the first time that I have tried this and it was a mistake.  The canoe welded to the billet anyway and I had to grind it off.  I guess that it  would have been quicker to drive to the store for the white-out.:)
IMG_0388_opt
IMG_0390_opt
IMG_0392_opt
There are a couple of unwelded edges here but those will grind off.  For the most part I'm very pleased with the way this welded.  The white lines on some of the welds will disappear when I  soak this above critical as they are indications of  carbon loss.  Once I soak this billet  above critical there will be enough carbon migration to make those lines disappear.
IMG_0417_opt
Gary
ABS,CKCA,ABKA,KGA
WOW  !!! The pattern is already awesome the finished blade will be also..................B)
If ya can't be good don't git caught  !!                                        People who say stuff can't be done need to
        git the hell outta the way of people who do stuff   !!!
Show me a man who is called an expert by his peers
And I will show you a good man to listen to ......
Show me a man who calls himself an expert
and I will show you an egotistical asshole...............!!
Boom!
Nicely done, sir. That's some ninja welding.
Dave
Gary -- A trick I've heard if you don't have white out is coat the inside of the can with the soot from a too rich oxy-acetylene flame.  Apparently that will keep the can from sticking to the billet.  I've never tried that, but heard it works. Thought I'd pass it along.
This is pure magic. It's easy to understand why pattern welded blades were so revered in ancient times.
Edited by Scott Davenport
Another one is to use heat treating foil and just oxidize the inside with any torch. I use a propane or MAPP gas torch and wrap my mokume billets in HT foil before I stack them in press plates. Ray Rybar taught me that.
Outstanding Gary. What a great pattern. I especially like the way you alternated the W's in the center
Wow Gary. Mind blown again. Thanks.
a think of exquisite beauty. thats what i think of when i think high end custom bowie.
a tech question. when you did the final weld, you mentioned a canoe and white out. is this a form of canister damscus? whats the theory and how does it work, if you dont mind me asking. im looking for any avenue that may help me finally do a successful damascus billet in my coal forge with just a hammer, so any help from any angle from a pro such as yourself might be the key im looking for
Ross Vosloo
Mhara Knives made in Zimbabwe
https://www.mharaknives.com
Ross,
A canoe is simply a can that loads from the side rather than from the end.  The white out is to keep the steel can from welding to  the billet.  The can  helped in two ways.  One it held all of the small irregular shaped pieces in place and two it eliminated any oxygen from getting to the welds.
Gary
ABS,CKCA,ABKA,KGA
