Making a coal forge
Joshua States
Well, I finally got this to the point where I decided to make this thing. I would like to go through the building process, but first I have to give thanks to those who have done this before. So, if you are thinking of putting together a solid fuel forge, take heed. These threads were incredibly useful for me and they will aid you too. The folks who posted them and those who chimed in with advice, suggestions and technical data provided enough variants that you can make what you want. need or have the scrap parts laying around.
Whether you have a premade firepot like Justin Mercier did, or you want to fabricate your own like Charles du Preeze did, or you want to go the ancient tried and true method of "a box of dirt" like Gerald Boggs, these threads will get you there. Thanks again to all those who participated in them and provided their knowledge and support.
I traded a HF anvil for this rusty old wheel rim forge a few years back. It was packed with some sort of white clay that eroded away over the last few years. The fire pot looked solid and the blower needed a little work, but the set-up wasn't what I wanted. I wanted more of a table type where extra coal could be readily available and I wanted it mobile.
So, I started dismantling it. The bolts that held it together were rusted so bad, it took a little MAPP gas torch and a half can of WD-40 to get most of them to come apart, Some were so bad and unreachable so the fire-wrench (oxy-acetylene torch) was put to use. The pieces parts.
Now to raid the wife's steel yard for frame materials...….
I have a great wife, but alas, that is a phrase I doubt I'll ever get to use.
Thanks in advance for posting your build.  I'll be following along.
-Brian
For the table I have a piece of 1/4" sheet. Well, two pieces actually. The piece I could get was 49" long and 19" wide, so I cut it in half and can make the table about 25' x 39". Then, I cut some 2x2 x1/8" angle iron and built a frame.
Cut out a hole in one of the two pieces for the firepot. As you can see, I put the lower sides of the firepot so they flushed out with the surface of the 1/4" plate. There's a little gap there.
And, used some 1x1x1/8" angles for the fire pot support and to close the gaps between the table bottom and the firepot.
Now some 2x2 square tube for the legs and some 3/16" by 4 " flat plate for the leg gussets. I also added a couple of hand truck wheels and some 5/8" threaded rod for the axle.
Some cross ties to take the twisting motion away, a couple of tool racks and two railroad spike for handles.
Here it is after wire wheeling most of the rust off.
Now it's off to work on the blower.
I'm actually considering making a coal forge again.  I still have a break drum that I haven't used lol it's just been rusting.  I could easily clean it up, Id have to get some 2 inch pipe and a fan.  But I could easily do that.  Don't think Id go as intricate as a metal table but I've already got a fire pot lol.
Looking good Josh. A had to cut the angle-iron frame down in front of the pot as I couldn’t lay longer objects flat. I may still have to do the same to the other side but I’ve not had to work on anything that long and, for the moment, it stops the coal falling off the table :D.
Hi Joshua, nice job so far, looks great! As mentioned by Charles that angle directly in line with the fire pot will get in the way. You only need to remove a small section so you can lay longer stock flat on the table. The "sweet spot" in that fire pot is on a level plane even with the top edge of the pot with about two inches of fuel mounded above the work. The depth of the pile below the work will use up most of the available oxygen giving you a more neutral flame at the top edge of the pot. This especially matters when you're welding and even during normal forging it's nice to have less scale to deal with. Even the small amount of tilt caused by the lip will have your work going in at a less than optimum angle if the stock extends past the edge of the forge table. You can also make a simple flip over gate that can be opened and closed. Close it with shorter work to help keep stray coal on the table and open it as needed. I look forward to seeing further progress!
Thanks for the suggestions Michael & Charles.
I am considering adding a coal stop on either side of the front of the fire pot to create a coal bin on the larger side of the table and removing the current sides of the frame so a work piece can lay flat across the fire pot. The only trouble with that plan is the vertical portion of the frame angle is where all the vertical strength is, and that section is where all of the weight is. So removing that vertical piece will weaken the structural integrity of the frame. I may have to add another support below the current frame to remove that piece.
You already have nice gussets in the corners, just flip some angle with one leg down and tack it on under what's already there before you cut the up turned leg off your angle frame. the extra face hanging below the table will give you attachment points for a tong rackB)
Yep. That's what I was thinking about right after I made that last post. An angle iron on the bottom of the side rail 4" either side of the notch should  suffice. (Make it so, number 2.)
Now where did I leave off? Oh yeah the blower.
Here it is before rehab.
Yes, that's an original rheostat speed controller. I was able to get the fan off the motor and dismantled, I also got the R-stat opened up and cleaned, but I could only get minimal access to the internal parts of the motor. A little rust removal, lubrication and new wires and this baby runs great.
Now I took that cutout piece of plate and a few bits and pieces for supports. Now it's bolted to its own table that is welded to the frame.
A little 3" duct from Home Cheapo and she's ready for business.
The rheostat goes from "Off" to "Full" in a very smooth sweep. So it is capable of very small adjustments.
I plan on building a side-draft hood on the short end of the table behind the fire pot. Then I'll be able to bring it indoors and hook it up to a suitable exhaust duct if necessary.
That's where it stands today. If anyone has any suggestions, fire away. I am all ears.
Looking good, I love that old rheostat!
GIT  ER DONE  !!!!!!!.....................:D
If ya can't be good don't git caught  !!                                        People who say stuff can't be done need to
        git the hell outta the way of people who do stuff   !!!
Show me a man who is called an expert by his peers
And I will show you a good man to listen to ......
Show me a man who calls himself an expert
and I will show you an egotistical asshole...............!!
  • 2 years later...
Well, I really cannot believe it has been this long, but I finally did a test run on this puppy. Starting the fire was its own learning curve, but I got it lit.
Once it was cooking pretty well we started to heat a big piece of 14 ga, sheet to raise a birdbath bowl.
I was the shop boy and tended the fire while Liz did the shaping and forging.
  • Like 7
Very cool, projects like that are where a coal forge really shines.  I also think it is really cool that you and your partner share a lifestyle.
8 hours ago, Welsh joel said:
Can she call my wife and get her in the forge with me?:D
Awesome!
Be careful what you wish for! Sharing a shop space is a deceptively complicated process. Liz has always been a creative person. She has done quilting, Navajo weaving, glass, basketry, and some other art forms I fail to recall. Her attraction to metal came when I bought a MIG welder for my construction business back in 2003. She saw me welding a gate for a client and asked what that was and how to use it. A short time later, we were introduced to forge work by an old friend who we knew through rock climbing. The rest just fell into place as we went along. Now that we used the coal forge for this project, I foresee other things being created in the shop. What is really cool about the design is the mobility. It lives out in the yard under a small cover. I just grab the handles and wheel it over to the shop door when we need it.
When I get back from Atlanta next week, I will be trying another axe. This forge should make the welding a lot easier to manage.
My wife is a city girl... and 20 yrs older.
She doesn't fish. We have a pond.
She doesn't do crafty things. I have a forge, a vinyl plotter, laser engraver, woodworking tools, etc.
She doesn't shoot. I have a backstop, 30 yds and a few toys.
She is the people person, I'm the introvert.
Opposites truly do attract. Lol. 27 years I've tried to get her interested- no dice.
So to me, to have a spouse or partner interested and willing to join in on the fun- is amazing. Congrats and good luck in joint projects.
Edited by Welsh joel
  • 1 year later...
I was just looking for a post like this.  Maybe you guys can offer me an opinion here.
My metal shop - pretty much died over the past 2 years. Recently, a friend of mine had asked if I could help him put together a break drum forge.  He needed to bend large and heavy gauge sheet metal.  He had two diesel truck drums (huge probably 10 or more inches in diameter and 5-6in deep)  he also had 2 more rotors (probably 7in in diameter and 3-4in deep)
I've used a break drum forge before so I knew one of their major pains was a traveling hot stop - and that it was just a huge volume of material to burn for smaller stuff.  Therefore I suggested to use one of the rotors.  In about 3 hours of scrapping and fiddling, once I got a fire built in it with a hair drier I got the darn thing up to welding heat and called that pretty darn good, however would the deeper drums be able to heat larger heaver material?  I've got some 1 3/4 axles that could be remade into tooling.
Secondly since this friend of mine has so much nice rusty scrap and we're just building for some fun, would it be better to just make a fire pot? If so, what is the minimum gauge material you would suggest for a fire pot?
Over the years, my propane forge had gotten me though my projects but it really shined when I need to make a "production run" and make 10 of something at the same time.  It really sucked at my larger art projects, and welding.  I know that a solid fuel forge has always been the way I wanted to go. For starters it will probably just be a fire pot out doors set up for welding and just doing some general tool making.
Edited by Daniel W
I would definitely be looking into a gas rig of some kind for sheet metal.
I've got gas and coal. The one nice thing about coal is that you can isolate heat better than a gasser... smaller sections.
For long heats on sheet I'd look in to what some of the armor guys use and lean that direction.
My guild just bought a fabricated firepot, and it's welded up from 1/2" plate.  I'd say that's the minimum for this purpose.
And I second Don on the gas forges the armor guys use.  They come up with some neat-o designs for sheet.
I've learned everything in coal over the years, and its so dirt cheap here. You get good batches and bad, it's dirty, stinks (but reminds me of Christmas) I've always enjoyed working with it.
I do have a spare burner that I never used that works, so an armorer gas forge is possible. I had planned for it to go into a second gas forge that was going be to more of a design Wayne Coe has on his site. I just never got around to putting it together. Could change now that I got some helping hands and I can retire my current gas forge.
