DMW
Help with pin holes
Hey guys, I forged a blade out of a 3” x 1/2” piece of coil spring. It hasn’t been heat treated yet and the problem I’m having is that I can’t get the pin holes for the handle drilled. I’ve tried iron oxide, titanium and cobalt drill bits with no luck. I got one hole drilled half way with the titanium bit then it stopped. I tried the second hole with the cobalt bit and it just made a small dimple. I’m at a loss on how to get it done. I’m thinking about trying to heat the blade then allowing it to cool overnight in the wood ashes I have in my annealing bucket. Do you guys have any other suggestions?  Thank you guys for any help.
Wouldn't hurt to try. Hard to say with an unknown steel. Simply normalizing it might help.
Are you using a drill press or a hand drill?
Sharp bits, slow speed, pressure, lubrication... you need all four.
Sometimes you might come across a tough alloy that requires a carbide bit.
Thanks for responding Don. I’m using all four and a drill press. A carbide bit was my next choice. This is some hard steel and I didn’t want to crank too hard with my press and snap the bit. These are brand new bits.
you want a proper 3x normalisation at descending temps, followed by a sub-critical anneal, aka super temper. Heat to just below critical and let it air cool. A wood ash/vermiculite anneal will likely do more harm than good by setting up lamellar carbides...
Edited by jake cleland
This^^^
Also, you could put the blade in the ash/vermiculite after the sub-critical anneal if you want.  Just don't do it from above critical.
