First knife/mini cleaver WIP
Adriaan G
So this is my first knife and i want to make a mini cleave because i like the way they look. I've only done a bit of grinding to get the shape a filing to smooth it out a bit. Its made from a scrap piece of leaf spring which is thick, making it quite beefy. The piece is a hair under 7mm but im on holiday so im for the job of working with such a thick piece. Any ideas and helpful critique is welcome and i also need ideas for handle mateial
Filing jig is built so its time to start filing. The knife is not exactly perfect because i tried to straighten it with a hammer. It was not a good idea. Not only did i not straighten it but i also left hammer marks in it so on some edge its not gonne meet op with the handle nicely. I then decided to take some flat rectangular tubing heat the knife and the clamp it to a flat surface. It sort of worked its all most perfect but the hammering thinned a part of the tang.. I geuss atleast the knife will be a good learning experience.
You have more than enough material there to make it worthwhile to taper that tang. If you do that you will move the balance forward which is a benefit to a chopper.
Not sure how to much a tapered tang with hand tools. Balance is allready a bit forward
Edited by Adriaan G
