Joshua States
Two little ones
Two little Damascus hidden Tang knives. Ready for fittings and handles
I started the handle for one of them tonight.
First I copy the drawing, cut the handle portion out and superglue it to a piece of sheet stock for the frame. Then I cut out the frame and rough grind (220 grit) the profile.
Then I surface the scales so both sides are parallel and layout the scale orientation.
Scribe the frame to the scales and cut out the pieces.
Mark the pin holes and drill them.
Cut out the tang slot and fit it snug.
Scribe the scales for the tang relief and hollow the area out.
Fit the pins through the frame to one scale and grind/sand/file them down so they will fit into the other scale. Get a nice tight fit. These are now ready to blind pin the spacer to and profile.
Nice work!! Can't wait to see the finished products
Thanks for posting this Joshua. Also can’t wait to see the rest of the process.
Before I profile the scales, I blacken the edge of the frame so I can see when I get down to it. put the other scale on and profile to 200 grit or better on the 2x72. Hand sand the profile to 400.
Then I mount the spacer package with blind pins to the handle scales and scribe the rough shape of the handle to the spacer package. I pin the spacer package to a piece of 1/4" MDF board and rough cut the spacers on the bandsaw.
The general shape is then refined on the 9 inch disc sander to 400 grit. Once the shaping is done, I start to file work the frame.
The guard is the last thing I do. I assemble the entire handle onto the knife and scribe the spacer to the guard. This shot is the second time to refine the guard shape. The guard is also shaped on the 2x72 using a Trizac A45 gator belt and then an A45 regular belt.
Hand sand the edges of the guard and buff.
The handle (without the guard is assembled and buffed out before glue-up. The scales are hollowed out to accept glue around the frame and deep into the heel area.
The finished knife & Sheath.
Beautiful!!! I really like that combination of materials you used there.
Edited by JASON VOLKERT
Oh, yeah, BTW: Stabilized black ash burl and nickel-silver.
Man that black ash burl is something else. I never heard of it before
The burl from any of the good handle woods always seems to "lift" the presentation visual to the next level
Stunning Joshua! B)
