Joshua States Posted January 5, 2019 Share Posted January 5, 2019 13 minutes ago, JASON VOLKERT said: I live New York and have been arrested for a Milwaukee flip open razor blade knife. You know the 1 they sell at every Home depot in the US. They said it was considered a "Gravity Knife" and they charged me with a "E Felony" I had to get bailed out the next morning for $1000. Then I went to court showed the judge my union book that said it was 1 of my tools needed for work and judge said "are you kidding me they locked you up for that" and dismissed the "E Felony". So any pocket knife that you can flip open with 1 hand illegal New York. Craziness!!! Another reason why I left. “So I'm lightin' out for the territory, ahead of the scared and the weak and the mean spirited, because Aunt Sally is fixin’ to adopt me and civilize me, and I can't stand it. I've been there before.” The only bad experience is the one from which you learn nothing. Josh http://www.dosgatosdesignsllc.com/#! https://www.youtube.com/channel/UCdJMFMqnbLYqv965xd64vYg J.States Bladesmith | Facebook https://www.facebook.com/dos.gatos.71 https://www.etsy.com/shop/JStatesBladesmith Link to comment Share on other sites More sharing options...
Conner Michaux Posted January 5, 2019 Share Posted January 5, 2019 15 hours ago, JASON VOLKERT said: I live New York and have been arrested for a Milwaukee flip open razor blade knife. You know the 1 they sell at every Home depot in the US. They said it was considered a "Gravity Knife" and they charged me with a "E Felony" I had to get bailed out the next morning for $1000. Then I went to court showed the judge my union book that said it was 1 of my tools needed for work and judge said "are you kidding me they locked you up for that" and dismissed the "E Felony". So any pocket knife that you can flip open with 1 hand illegal New York. Craziness! Thats absurd.... Now I know never to bring a flipper into NY. Link to comment Share on other sites More sharing options...
JASON VOLKERT Posted January 6, 2019 Share Posted January 6, 2019 9 hours ago, Conner Michaux said: Thats absurd.... Now I know never to bring a flipper into NY. Yeah tell me about it Link to comment Share on other sites More sharing options...
Jeremy Blohm Posted January 6, 2019 Share Posted January 6, 2019 We should have had the 150mm challenge as a choice in the poll. Link to comment Share on other sites More sharing options...
Zeb Camper Posted January 6, 2019 Share Posted January 6, 2019 1 minute ago, Jeremy Blohm said: We should have had the 150mm challenge as a choice in the poll. Whaaa? Link to comment Share on other sites More sharing options...
Jeremy Blohm Posted January 6, 2019 Share Posted January 6, 2019 I guess you start with 3/4 x 3/4 square x 6 inches long and make what ever you want. 2 Link to comment Share on other sites More sharing options...
Conner Michaux Posted January 6, 2019 Share Posted January 6, 2019 Does your KITH knife have to be forged? Or can you forge the blade and stock remove the rest? It would be quite hard to forge the tang on a folder because of all the little nooks where the knife rests on the pins when its opened. Get what im saying? Link to comment Share on other sites More sharing options...
Jeremy Blohm Posted January 6, 2019 Share Posted January 6, 2019 Doing stock removal around the tang is totally fine. Link to comment Share on other sites More sharing options...
Conner Michaux Posted January 6, 2019 Share Posted January 6, 2019 4 minutes ago, Jeremy Blohm said: Doing stock removal around the tang is totally fine. Thats great! Link to comment Share on other sites More sharing options...
Joshua States Posted January 7, 2019 Share Posted January 7, 2019 1 hour ago, Conner Michaux said: It would be quite hard to forge the tang on a folder because of all the little nooks where the knife rests on the pins when its opened. Most folders are done almost completely stock removal for precisely this reason. If you are going to attempt a folding knife (slip joint or lock back) for the KITH, I would suggest you purchase a piece of precision ground flat stock (3/32 or 5/32) and work completely stock removal. It will increase your chances of success dramatically. “So I'm lightin' out for the territory, ahead of the scared and the weak and the mean spirited, because Aunt Sally is fixin’ to adopt me and civilize me, and I can't stand it. I've been there before.” The only bad experience is the one from which you learn nothing. Josh http://www.dosgatosdesignsllc.com/#! https://www.youtube.com/channel/UCdJMFMqnbLYqv965xd64vYg J.States Bladesmith | Facebook https://www.facebook.com/dos.gatos.71 https://www.etsy.com/shop/JStatesBladesmith Link to comment Share on other sites More sharing options...
Conner Michaux Posted January 7, 2019 Share Posted January 7, 2019 (edited) im going to do a friction folder. 3 minutes ago, Joshua States said: I would suggest you purchase a piece of precision ground flat stock (3/32 or 5/32) Is that just really flat steel? Where should I get it? Edited January 7, 2019 by Conner Michaux Link to comment Share on other sites More sharing options...
Joshua States Posted January 7, 2019 Share Posted January 7, 2019 Almost any knife making supplier sells it. You will probably have to use O-1 for a HC steel or a stainless steel. You could also use 15N20 if you can find it in pieces thick enough. Check Jantz, Texas Knife, and K&G supplies. They all sell precision ground flat stock. 12 minutes ago, Conner Michaux said: Is that just really flat steel? Pretty much. Do you have a way to clamp the blade & spring between two aluminum or copper plates after quenching? “So I'm lightin' out for the territory, ahead of the scared and the weak and the mean spirited, because Aunt Sally is fixin’ to adopt me and civilize me, and I can't stand it. I've been there before.” The only bad experience is the one from which you learn nothing. Josh http://www.dosgatosdesignsllc.com/#! https://www.youtube.com/channel/UCdJMFMqnbLYqv965xd64vYg J.States Bladesmith | Facebook https://www.facebook.com/dos.gatos.71 https://www.etsy.com/shop/JStatesBladesmith Link to comment Share on other sites More sharing options...
Conner Michaux Posted January 7, 2019 Share Posted January 7, 2019 3 minutes ago, Joshua States said: Pretty much. Do you have a way to clamp the blade & spring between two aluminum or copper plates after quenching? I have a vice, If thats what you mean. Link to comment Share on other sites More sharing options...
Joshua States Posted January 7, 2019 Share Posted January 7, 2019 33 minutes ago, Conner Michaux said: I have a vice, If thats what you mean. A vice will work fine, if you can fit two plates or bars in the jaws. “So I'm lightin' out for the territory, ahead of the scared and the weak and the mean spirited, because Aunt Sally is fixin’ to adopt me and civilize me, and I can't stand it. I've been there before.” The only bad experience is the one from which you learn nothing. Josh http://www.dosgatosdesignsllc.com/#! https://www.youtube.com/channel/UCdJMFMqnbLYqv965xd64vYg J.States Bladesmith | Facebook https://www.facebook.com/dos.gatos.71 https://www.etsy.com/shop/JStatesBladesmith Link to comment Share on other sites More sharing options...
JASON VOLKERT Posted January 7, 2019 Share Posted January 7, 2019 (edited) Since it looks like a folder is going to win. I plan on making a Japanese Higonokami. I have never made 1 and since this is "bladesmithsforum" I want to make some that I can forge. This kind of pocket knife is almost all forged construction. Here is a link to 1 being made Here. I always wanted to make 1. Edited January 7, 2019 by JASON VOLKERT Link to comment Share on other sites More sharing options...
Joshua States Posted January 7, 2019 Share Posted January 7, 2019 @JASON VOLKERT yep. That's what is generically referred to as a friction folder these days. “So I'm lightin' out for the territory, ahead of the scared and the weak and the mean spirited, because Aunt Sally is fixin’ to adopt me and civilize me, and I can't stand it. I've been there before.” The only bad experience is the one from which you learn nothing. Josh http://www.dosgatosdesignsllc.com/#! https://www.youtube.com/channel/UCdJMFMqnbLYqv965xd64vYg J.States Bladesmith | Facebook https://www.facebook.com/dos.gatos.71 https://www.etsy.com/shop/JStatesBladesmith Link to comment Share on other sites More sharing options...
AndrewB Posted January 7, 2019 Share Posted January 7, 2019 On 1/4/2019 at 7:07 PM, JASON VOLKERT said: I live New York and have been arrested for a Milwaukee flip open razor blade knife. You know the 1 they sell at every Home depot in the US. They said it was considered a "Gravity Knife" and they charged me with a "E Felony" I had to get bailed out the next morning for $1000. Then I went to court showed the judge my union book that said it was 1 of my tools needed for work and judge said "are you kidding me they locked you up for that" and dismissed the "E Felony". So any pocket knife that you can flip open with 1 hand illegal New York. Craziness!!! Seriously? I’m glad I live in Washington here if I wanted to I can carry a Bowie knife of course on my belt it would have to be in a sheeth of course but the knife laws here are not as strict. Link to comment Share on other sites More sharing options...
Joshua States Posted January 7, 2019 Share Posted January 7, 2019 I'm still supporting this idea: something along the lines of a knife with a 3 inch or less blade. Your choice of fixed or folder, any ethno-centric origin, single or double edged. 1 “So I'm lightin' out for the territory, ahead of the scared and the weak and the mean spirited, because Aunt Sally is fixin’ to adopt me and civilize me, and I can't stand it. I've been there before.” The only bad experience is the one from which you learn nothing. Josh http://www.dosgatosdesignsllc.com/#! https://www.youtube.com/channel/UCdJMFMqnbLYqv965xd64vYg J.States Bladesmith | Facebook https://www.facebook.com/dos.gatos.71 https://www.etsy.com/shop/JStatesBladesmith Link to comment Share on other sites More sharing options...
Brian Dougherty Posted January 7, 2019 Share Posted January 7, 2019 11 hours ago, Joshua States said: I'm still supporting this idea: something along the lines of a knife with a 3 inch or less blade. Your choice of fixed or folder, any ethno-centric origin, single or double edged. I agree, and it seems most others do as well. The poll is really just a guideline, so I'm all for calling official along the lines of what Joshua said. -Brian Link to comment Share on other sites More sharing options...
Robert D. Posted January 7, 2019 Share Posted January 7, 2019 Might get more people involved if the target is an EDC with just blade size being the requirement, Then those that want to do a fixed little blade can, and those that want to do a folder can. Personally I want to do a folder, but thats because I want to give them a whirl and see where I can go with them. But I totally understand others feeling questionable about attempting it. One of the best things in my opinion of the KITH, is getting to follow along the WIPS everyone posts. http://robertjamescustoms.tumblr.com/ Link to comment Share on other sites More sharing options...
Alex Middleton Posted January 7, 2019 Author Share Posted January 7, 2019 I'd be all for that as well. I'm going to try a folder too, but it would be nice to have something to fall back on and still participate with if time/skill level/patience don't allow me to complete it. Link to comment Share on other sites More sharing options...
Joshua States Posted January 7, 2019 Share Posted January 7, 2019 Yeah, and @Bruno can make his stiletto switch blade thing too! “So I'm lightin' out for the territory, ahead of the scared and the weak and the mean spirited, because Aunt Sally is fixin’ to adopt me and civilize me, and I can't stand it. I've been there before.” The only bad experience is the one from which you learn nothing. Josh http://www.dosgatosdesignsllc.com/#! https://www.youtube.com/channel/UCdJMFMqnbLYqv965xd64vYg J.States Bladesmith | Facebook https://www.facebook.com/dos.gatos.71 https://www.etsy.com/shop/JStatesBladesmith Link to comment Share on other sites More sharing options...
Brian Dougherty Posted January 7, 2019 Share Posted January 7, 2019 Let's call it done then. "Any knife in the spirit of EDC with a blade 3" or less. Fixed blade or folding knife are all fine." -Brian Link to comment Share on other sites More sharing options...
Conner Michaux Posted January 7, 2019 Share Posted January 7, 2019 I say lets do that, The idea of a Folder has devoured me...Im very excited! I would also like to start KITH now but its not up to me. Can I buy the materials I need before it starts? Link to comment Share on other sites More sharing options...
Jeremy Blohm Posted January 7, 2019 Share Posted January 7, 2019 Yeah....start getting what you need. Its always good to be ahead of the game. The deadline creeps up quick. Link to comment Share on other sites More sharing options...
