nprovos
Rebuilding a Side Blast Forge
At the shop, we have been using a side blast forge for general blacksmithing. It's a great tool as clinker can be removed quickly without great interruptions to the fire. The side blast forge relies on a water cooled tuyere. After more than ten years of great service, the air pipe finally rusted through. I have attached some photos of the surgery and reconstruction.
Forge area with tank removed:
Tank cut open with plasma cutter - at that point it was clear already that the tank needed to be rebuild as well:
Removing the air pipe with a die grinder:
Fitting the new pipe:
Rebuilding the tank from 3/16" steel plate:
Finally leak testing the rebuild tank:
It still needs to be installed and tested but this is how far I got during my holiday break.
Happy hammering.
Niels.
Interesting!!
Looks good!  And illustrates why I never built one, getting it watertight with my pitiful stick welding skills would be an impossibility.  :lol:
Is a side blast forge better than a bottom blast?  I'm just curious.  I haven't seen too many youtube videos out there from anybody in the US that's using side blast forges most the guys I see using them are in Europe or in the UK.  I've always wondered like I said if they actually work better.
Just put it outside for a week and let it rust up, the rust will seal the holes.  And no, I'm not joking :-)
Looking great already!
 If my shop had the space I would go for a side blast forge, it would be so nice to build a big reducing fire sometimes.
Here is the latest progress:
Installed pivot for the air lever.
Plasma cutting and extremely poor sheet metal welding to repair the back. I replaced it with 16 gauge instead of 17 which might make it last a little longer:
Finally installed the tank and the tuyere:
Almost looks like new :-)
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
