Jeremy Blohm
30 hp phase converter build
I have several pieces of equipment that is 3 phase one of them is a 10 hp rotary screw compressor which will require quite a large converter. I also have a 6x48 Kalamazoo belt sander that has a 3 hp 3 phase motor and the hydraulic pump I have for the press im going to build is 3 phase. So I need a lot of 3 phase power and I dont plan to get the power company to run it to my shop.
I just won this 30 hp motor that I plan on using for the rotary portion and all I have to get is the panel in the next week or 2. You wont believ what I won this motor for. The only concern I have is that it is rated for 480 only. I did some research and most of the balador 30 hp motors and what I seen was mostly 230/480 so I have my fingers crossed. If not it looks like i have a 500 lb chunk of iron i cant use.
https://bid.orbitbid.com/lots/1467619#aWQ9MTQ2NzYxOSZsaW1pdD0zMCZvZmZzZXQ9MCZwYWdlPTEmcHJldltwYWdlXT13bCZwcmV2W3dpZF09MSZzdGF0dXM9dXBjb21pbmcmdHlwZT13YXRjaGluZw..
Here is The panel I plan on buying. It should have everything I need. I might have to add a capacitor to get it to balance right but that should be it.
https://www.ebay.com/itm/30hp-Cnc-Balanced-3-Phase-Rotary-Converter-Panel-10-year-warranty-/232281998435
Wow that's some serious horse power
  • Haha 1
I cant wait to have this thing built and try out this air compressor and get this belt sander running at full power. Right now it's running off of a static phase converter and it only runs a 2/3 its rated horsepower.
Baldor does make motors that are only 460v. Give me the catalog number and I will look it up.
I dont have any info on the motor yet. I am going to pick it up tomorrow or Friday. They didn't take any photos of the info tag. I will know more in a day or two.
well, that was about $0.10/lb or probably something like $0.0005/$ of the original price.  Hopefully you can make it work for a converter.
I've been on the hunt for the right motor for quite sometime. If i cant make it work then I can always try to sell it or scrap it and get my money back. But I have many food processing plants around me and I have worked at 2 of them. I could try to sell it to one of them for $100 and make a dollar off of it. I was maintenance at the 2 places I worked at. And my cousin is maintenance manager at one of them so I have some inside sources that maybe I can make a trade for a motor I can use.
I took a gamble buying this motor and it paid off!!! This thing is brand new. It said in the description that it appears to be rebuilt but there has never been anything on the shaft of this thing. Ther is a couple dings on it but other than that it looks new.Resized_20190110_151259.jpegResized_20190110_151359(1).jpegResized_20190110_151329.jpegResized_20190110_151339.jpeg
Looks good and 230/460. You're good to go. :)
To get a sense of how big this is here it is setting on my 3800lb block of steel.:lol:
Jinkies, that's large. Please do be sure to not skimp on the electrical tape when wiring... :ph34r:
  • Haha 1
Ok this took me a lot longer than expected but I have ordered the panel and all the components for this build and as soon as it gets here I will get the motor in the shop and start wiring it up.
Edited by Jeremy Blohm
That is a big 'un! Looking on with interest.
It looks like your caps are held in place with some putty or adhesive.  That might be fine, but don't underestimate how much force the magnetic field around a wire can generate.  I've seen massive feeder cables that weighed several pounds per foot blown out of cable raceways from the start-up current on big motors :ph34r:
Edited by Brian Dougherty
I'm finally going to finish this thing and have 3 phase power to the shop. Hopefully by the end of the weekend it will be up and running.
Still can’t get over the size of that beast.
