Joshua States Posted January 12, 2019 Share Posted January 12, 2019 So, this got me thinking I should make some more slip joint folders, because it's been a few years and I already have the templates in a Gatorade can in the shop. They are really 3 different blade types in two different sizes, with 3 different handle shapes. Some of the blades are interchangeable with some of the handle shapes. Basically, there's a Warncliff, a clipped point, and a dropped point blade. Look in the lower right corner and you will see I also found two Damascus blades and one Damascus spring left over from a project that never got made. I also have this little straight blade with a tight W-pattern that could make a nice EDC. I'd do one of my 3-finger frame handles. Then again, there's always the O-1 option. Those cut like mad. 2 “So I'm lightin' out for the territory, ahead of the scared and the weak and the mean spirited, because Aunt Sally is fixin’ to adopt me and civilize me, and I can't stand it. I've been there before.” The only bad experience is the one from which you learn nothing. Josh http://www.dosgatosdesignsllc.com/#! https://www.youtube.com/channel/UCdJMFMqnbLYqv965xd64vYg J.States Bladesmith | Facebook https://www.facebook.com/dos.gatos.71 https://www.etsy.com/shop/JStatesBladesmith Link to comment Share on other sites More sharing options...
Conner Michaux Posted January 12, 2019 Share Posted January 12, 2019 For KITH? You should finish the Damascus folder. That’s just my opinion though. 1 Link to comment Share on other sites More sharing options...
Joshua States Posted January 13, 2019 Author Share Posted January 13, 2019 10 hours ago, Conner Michaux said: For KITH? You should finish the Damascus folder. That’s just my opinion though. Well, that's one vote. Anyone else? “So I'm lightin' out for the territory, ahead of the scared and the weak and the mean spirited, because Aunt Sally is fixin’ to adopt me and civilize me, and I can't stand it. I've been there before.” The only bad experience is the one from which you learn nothing. Josh http://www.dosgatosdesignsllc.com/#! https://www.youtube.com/channel/UCdJMFMqnbLYqv965xd64vYg J.States Bladesmith | Facebook https://www.facebook.com/dos.gatos.71 https://www.etsy.com/shop/JStatesBladesmith Link to comment Share on other sites More sharing options...
AndrewB Posted January 13, 2019 Share Posted January 13, 2019 Here’s an idea use both blades on the same one. Multi blade folder. Link to comment Share on other sites More sharing options...
Joël Mercier Posted January 13, 2019 Share Posted January 13, 2019 That slip joint seems neat! Plus I decided to make one instead of a Japanese style friction. My goal will be to try and do something similar to yours in mono steel. Link to comment Share on other sites More sharing options...
Brian Dougherty Posted January 13, 2019 Share Posted January 13, 2019 If it causes you to lean one way or the other, I will most likely be doing a slip-joint for my entry. 1 -Brian Link to comment Share on other sites More sharing options...
JASON VOLKERT Posted January 13, 2019 Share Posted January 13, 2019 I'd say slip joint but then I saw that little straight blade. I really like that little straight blade Link to comment Share on other sites More sharing options...
MichaelP Posted January 14, 2019 Share Posted January 14, 2019 I spent this weekend at a gun and knife show and was lucky to bump into some of the top notch blacksmiths in my area. We talked about my upcoming project for KITH and I am more excited than ever to be doing it this time around! I'm sticking with the friction folder and I cant wait to see what everyone else comes up with. Joshua, I don't know if this will help or only muddy the waters but I really like that little W pattern fixed blade. When I make fixed blades of that size I usually make a pouch type sheath for inside the front pocket carry with a spring clip made onto the sheath. I love having the strength of a fixed blade in a pocket sized package. I'm sure whatever you decide on will be awesome and I look forward to seeing where this project takes everyone! Link to comment Share on other sites More sharing options...
Joshua States Posted January 14, 2019 Author Share Posted January 14, 2019 @Michael P That would be my intent. Something along these lines. “So I'm lightin' out for the territory, ahead of the scared and the weak and the mean spirited, because Aunt Sally is fixin’ to adopt me and civilize me, and I can't stand it. I've been there before.” The only bad experience is the one from which you learn nothing. Josh http://www.dosgatosdesignsllc.com/#! https://www.youtube.com/channel/UCdJMFMqnbLYqv965xd64vYg J.States Bladesmith | Facebook https://www.facebook.com/dos.gatos.71 https://www.etsy.com/shop/JStatesBladesmith Link to comment Share on other sites More sharing options...
Robert D. Posted January 14, 2019 Share Posted January 14, 2019 Seems I am not the only one with projects floating around I have not finished that now could work for the KITH... I am going to stick to friction folder for my Kith, but that fixed blade would be a sweet EDC, Now you have me contemplating grinding my blade out of one of the billets I have floating about the shop instead of W2... http://robertjamescustoms.tumblr.com/ Link to comment Share on other sites More sharing options...
Joshua States Posted May 11, 2019 Author Share Posted May 11, 2019 Contestant #1 Take a small piece of burl wood. Fit it to the tang And profile 2 “So I'm lightin' out for the territory, ahead of the scared and the weak and the mean spirited, because Aunt Sally is fixin’ to adopt me and civilize me, and I can't stand it. I've been there before.” The only bad experience is the one from which you learn nothing. Josh http://www.dosgatosdesignsllc.com/#! https://www.youtube.com/channel/UCdJMFMqnbLYqv965xd64vYg J.States Bladesmith | Facebook https://www.facebook.com/dos.gatos.71 https://www.etsy.com/shop/JStatesBladesmith Link to comment Share on other sites More sharing options...
Joshua States Posted May 24, 2019 Author Share Posted May 24, 2019 I did finish this little one. The pics are in Show & Tell. “So I'm lightin' out for the territory, ahead of the scared and the weak and the mean spirited, because Aunt Sally is fixin’ to adopt me and civilize me, and I can't stand it. I've been there before.” The only bad experience is the one from which you learn nothing. Josh http://www.dosgatosdesignsllc.com/#! https://www.youtube.com/channel/UCdJMFMqnbLYqv965xd64vYg J.States Bladesmith | Facebook https://www.facebook.com/dos.gatos.71 https://www.etsy.com/shop/JStatesBladesmith Link to comment Share on other sites More sharing options...
Charles dP Posted May 26, 2019 Share Posted May 26, 2019 @Joshua States at this rate you are going to have a KITH to decide on a knife for the KITH 1 "The way we win matters" (Ender Wiggins) Orson Scott Card Nos, qui libertate donati sumus, nes cimus quid constet. Link to comment Share on other sites More sharing options...
Joshua States Posted May 26, 2019 Author Share Posted May 26, 2019 A few progress shots on contestant #2. After checking the action. After soldering the bolsters to the liners. Checking the closed blade clearance on the liners. Relaxing the spring for a day or two. “So I'm lightin' out for the territory, ahead of the scared and the weak and the mean spirited, because Aunt Sally is fixin’ to adopt me and civilize me, and I can't stand it. I've been there before.” The only bad experience is the one from which you learn nothing. Josh http://www.dosgatosdesignsllc.com/#! https://www.youtube.com/channel/UCdJMFMqnbLYqv965xd64vYg J.States Bladesmith | Facebook https://www.facebook.com/dos.gatos.71 https://www.etsy.com/shop/JStatesBladesmith Link to comment Share on other sites More sharing options...
Brian Dougherty Posted May 28, 2019 Share Posted May 28, 2019 Nice Joshua. Your experience shows as this is more refined than my build. (Part quality is better) Is the dark "Liner" in the last pic just for assembly/testing the blade and spring? 1 -Brian Link to comment Share on other sites More sharing options...
Joshua States Posted May 28, 2019 Author Share Posted May 28, 2019 9 hours ago, Brian Dougherty said: Is the dark "Liner" in the last pic just for assembly/testing the blade and spring? That's one of my templates. With a little luck, and some careful shaping, the template holes all work with the parts I'm working on. It doesn't always work out that way, but this time it did. 9 hours ago, Brian Dougherty said: Your experience shows as this is more refined than my build. (Part quality is better) Thanks, but I'm not sure that's true. Your build came out great. This is also the first time I tried soldering the bolsters on. I usually spot weld them and have a ton of cleanup. Your WIP got me to try the soldering, for which I am extremely grateful. “So I'm lightin' out for the territory, ahead of the scared and the weak and the mean spirited, because Aunt Sally is fixin’ to adopt me and civilize me, and I can't stand it. I've been there before.” The only bad experience is the one from which you learn nothing. Josh http://www.dosgatosdesignsllc.com/#! https://www.youtube.com/channel/UCdJMFMqnbLYqv965xd64vYg J.States Bladesmith | Facebook https://www.facebook.com/dos.gatos.71 https://www.etsy.com/shop/JStatesBladesmith Link to comment Share on other sites More sharing options...
Brian Dougherty Posted May 28, 2019 Share Posted May 28, 2019 No, your parts are definitely nicer. I know where all the goofs are on mine and not yours which probably sway each of us in the other direction, but there is no doubt that you know how to grind a blade, and I am still figuring that out I'm glad the WIP helped a bit. I owe this community a lot as it has been my sole source of learning this craft. -Brian Link to comment Share on other sites More sharing options...
Joshua States Posted May 29, 2019 Author Share Posted May 29, 2019 11 hours ago, Brian Dougherty said: there is no doubt that you know how to grind a blade, and I am still figuring that out Well, I have ground a bunch of them in the last, never mind how long, so I had better have figured it out by now. I made a 2-part video of my process. It's on my boobtube channel. Folder blades are very difficult to deal with because they are so small. Most folder guys will make two at a time so they can use one piece of flat stock and lay out the blades with the tang ends in the center of the bar and the points at the ends of the bar. If you do it this way, you can hold the bar easier when grinding. They take them all the way to 400 or 600 grit before HT and then separate, finish off the tangs and go to HT with anti-scale or foil wrap. For this project, I made a little holding clamp for grinding. I think I'll keep this around. 1 “So I'm lightin' out for the territory, ahead of the scared and the weak and the mean spirited, because Aunt Sally is fixin’ to adopt me and civilize me, and I can't stand it. I've been there before.” The only bad experience is the one from which you learn nothing. Josh http://www.dosgatosdesignsllc.com/#! https://www.youtube.com/channel/UCdJMFMqnbLYqv965xd64vYg J.States Bladesmith | Facebook https://www.facebook.com/dos.gatos.71 https://www.etsy.com/shop/JStatesBladesmith Link to comment Share on other sites More sharing options...
JeffM Posted May 29, 2019 Share Posted May 29, 2019 I'd vote for the short straight blade....they make excellent EDC.... Link to comment Share on other sites More sharing options...
Joshua States Posted May 30, 2019 Author Share Posted May 30, 2019 4 hours ago, JeffM said: I'd vote for the short straight blade....they make excellent EDC.... Unfortunately, my boss disagrees with you. Something to do with having stuff to sell in the art show this November...….. “So I'm lightin' out for the territory, ahead of the scared and the weak and the mean spirited, because Aunt Sally is fixin’ to adopt me and civilize me, and I can't stand it. I've been there before.” The only bad experience is the one from which you learn nothing. Josh http://www.dosgatosdesignsllc.com/#! https://www.youtube.com/channel/UCdJMFMqnbLYqv965xd64vYg J.States Bladesmith | Facebook https://www.facebook.com/dos.gatos.71 https://www.etsy.com/shop/JStatesBladesmith Link to comment Share on other sites More sharing options...
Joshua States Posted June 23, 2019 Author Share Posted June 23, 2019 And contestant number 2 is getting into shape. 1 “So I'm lightin' out for the territory, ahead of the scared and the weak and the mean spirited, because Aunt Sally is fixin’ to adopt me and civilize me, and I can't stand it. I've been there before.” The only bad experience is the one from which you learn nothing. Josh http://www.dosgatosdesignsllc.com/#! https://www.youtube.com/channel/UCdJMFMqnbLYqv965xd64vYg J.States Bladesmith | Facebook https://www.facebook.com/dos.gatos.71 https://www.etsy.com/shop/JStatesBladesmith Link to comment Share on other sites More sharing options...
Brian Dougherty Posted June 24, 2019 Share Posted June 24, 2019 Cool! 1 -Brian Link to comment Share on other sites More sharing options...
Joshua States Posted June 30, 2019 Author Share Posted June 30, 2019 Slip joint folders are evil little things. “So I'm lightin' out for the territory, ahead of the scared and the weak and the mean spirited, because Aunt Sally is fixin’ to adopt me and civilize me, and I can't stand it. I've been there before.” The only bad experience is the one from which you learn nothing. Josh http://www.dosgatosdesignsllc.com/#! https://www.youtube.com/channel/UCdJMFMqnbLYqv965xd64vYg J.States Bladesmith | Facebook https://www.facebook.com/dos.gatos.71 https://www.etsy.com/shop/JStatesBladesmith Link to comment Share on other sites More sharing options...
Alan Longmire Posted June 30, 2019 Share Posted June 30, 2019 46 minutes ago, Joshua States said: Slip joint folders are evil little things. Bite you, did it? Link to comment Share on other sites More sharing options...
Gary LT Posted June 30, 2019 Share Posted June 30, 2019 Joshua, they are all excellent, my 2 cents is the fixed blade for an EDC. Just easier to use everyday in my opinion. Gary LT "I Never Met A Knife I Didn't Like", (Will Rogers) Link to comment Share on other sites More sharing options...
