Tyler Reinarts Posted January 27, 2019 Share Posted January 27, 2019 I was doing some research on the composition of historical blade materials and I found out that a lot of the iron they used contained a lot of phosphorus, between .4 and 1.4%. It also seems like they used it on purpose for pattern welding. Here's the links to some articles: https://www.tf.uni-kiel.de/matwis/amat/iss/kap_b/backbone/rb_3_4.html https://www.google.com/url?sa=t&source=web&rct=j&url=https://www.uni-obuda.hu/journal/Thiele_Hosek_60.pdf&ved=2ahUKEwj3s6rbo43gAhUL54MKHVZ7AEUQFjARegQIBBAB&usg=AOvVaw1XYSF1k9B22QPbps6nWetn So my question is: wouldn't that much phosphorus make the metal extremely brittle? I've read that phosphorus increases hardness but reduces toughness/ductility but I don't know to what extent. I guess what I'm asking is how a high phosphorus (e.g. 1% )steel or iron would compare to other materials and if it's still strong enough to be useful to a blacksmith. Link to comment Share on other sites More sharing options...
Alan Longmire Posted January 27, 2019 Share Posted January 27, 2019 High-P iron is indeed a bit brittle compared to low-P iron, but that shows up more during forging than in use. It tends to snap during forging if too cold or if there are sharp corners. Where it is useful is that it work-hardens. That means a cold-hammered high-P blade is substantially harder than plain iron. That was of great value before the role of carbon in hardening was understood, i.e. the first half of the iron age (technically the role of carbon wasn't understood until the late 18th century, but they were manipulating carbon content deliberately by the first century AD). It was indeed used in pattern welding, as it etches darker than ordinary iron. There is a lot of information about this on the forum, both here and in the Bloomers and Buttons subforum. Link to comment Share on other sites More sharing options...
Tyler Reinarts Posted January 27, 2019 Author Share Posted January 27, 2019 Thanks for the info, but did you mean to say that high P iron etches dark? The other places I read says it etches bright. Link to comment Share on other sites More sharing options...
Alan Longmire Posted January 27, 2019 Share Posted January 27, 2019 That's what they say until they mix it with low carbon low-P iron. We do experimental archaeology here rather than theory and guesswork. Link to comment Share on other sites More sharing options...
Tyler Reinarts Posted January 28, 2019 Author Share Posted January 28, 2019 Interesting... I wonder what the flaw in their theory was. Also would you say the ductility/toughness of room temp high P iron is comparable to unhardened high C steel? Sorry if I'm being tiresome, I'm just trying to get a good idea of what it would be like since I am not able to test it myself. Link to comment Share on other sites More sharing options...
Jeroen Zuiderwijk Posted January 28, 2019 Share Posted January 28, 2019 I believe so. The thing you have to keep in mind is that with ancient steel, thick sections generally didn't harden in a quench. So you put carbon steel at the edges for hardness, and P-iron at the core or spine for toughness. Jeroen Zuiderwijk Facebook page: https://www.facebook.com/barbarianmetalworking Link to comment Share on other sites More sharing options...
Alan Longmire Posted January 28, 2019 Share Posted January 28, 2019 The other thing to remember is these ancient irons and steels are not directly comparable to modern homogeneous steels. They are all based on wrought iron, and thus will retain some slag and fibrous structure no matter how well refined. As Jeroen pointed out, they also have no alloying elements to increase the depth of hardening. Manganese is the foremost of these in modern steels, and not coincidentally is responsible for modern high carbon steels etching dark. I believe the academics simply made an assumption (the High-P etching bright is received wisdom from many years ago and I'm not sure who first suggested it) and did not test it. I, on the other hand, made a blade and etched it to see what would happen. It's not a huge amount of contrast, but the plain iron stays silvery-grey and the high-P turns a little darker. Here is that blade: 1 Link to comment Share on other sites More sharing options...
