DBain 15 Posted January 31, 2019 Share Posted January 31, 2019 This will be my first attempt at pattern welded steel. I’ve made a few SanMai blades with good success. I’m using 15 layers total of 1084 & 15n20. My original stack was 5”L x 1.25”W x 3”H. I welded it up and forged it down to 8”L x 1.5”W x 1.5”H, then crushed in the corners to take the edges off. Now the twist... is it reasonable to expect to be able to put 3 or 4 twists in this 1.5” billet by hand ? I’m wanting to forge a cleaver or modified cleaver so I don’t want to take the billet down any smaller than I have to. Link to post Share on other sites
Brian Dougherty 1,213 Posted January 31, 2019 Share Posted January 31, 2019 You can certainly get 3 or 4 twists in the 8" length. Whether or not you can do it by hand will depend on you. I'm a pretty small guy, and find twisting something that large to be a big challenge. Just for reference data, my twisting wrench only has about 9" handles, and I don't have a great vice setup for holding the bar so I'm not exactly stacking the deck in my favor. If you are a strong guy, adn have a good twisting setup, it may not be a problem at all. I'll be interested to see how you make out. I'd like to be able to do some wider blades with a single twist bar. Link to post Share on other sites
Pieter-Paul Derks 229 Posted January 31, 2019 Share Posted January 31, 2019 I regularly twist material of about that size by hand for damascus rings, it is not easy but certainly possible. It is important to have a sturdy vise and tongs, I use a pipe wrench with an extra handle welded on. the big trick is to take your time and only twist when the material is at a white heat, I sometimes get only half a revolution per heat, but this is better than shearing the bar or your own back. Link to post Share on other sites
DBain 15 Posted January 31, 2019 Author Share Posted January 31, 2019 Twisting at the proper heat without tearing the billet is my concern. I have a heavy vice and a solid work table. I am going to a hammer in this weekend and am trying to get ahead as much as I can but certainly don’t want to take 5 steps back. I’ll touch base with the shop owner and see how he feels about twisting it there. Link to post Share on other sites
DBain 15 Posted January 31, 2019 Author Share Posted January 31, 2019 For what it’s worth here is a cross section of the end of the billet: Link to post Share on other sites
