Conner Michaux
Little Edc WIP
Hopefully ill be able to finish this one, almost all the knives ive started have come to dead ends.
So hopefully I can finish this one!
This is a stock removal knife, Made from O-1
I havent measured it yet, ill do that soon.
Spent a few hours filing the bevel in, Oh forgot to mention its a single bevel as you can see, the O-1 is 5/32 thick and the thickness at the edge right now is a little bit thick than a sixteenth, (i haven't measured yet thats just a guess)
My question right now is, Does the edge look to thin right now or do i have some more room to file?
Thanks.
{EDIT} Yes I was right the edge right now is just under a sixteenth, and by just under i mean literally a hair thinner than that..
and the blade length is 5 1/8th
plunge line to the tip is exactly 2 inches long.
IMG_1899.jpegOn my house we have chains that the draining water trickles down, and when it freezes it looks pretty cool.
Edited by Conner Michaux
Im thinking  Micarta for the handle, but i'm not sure yet.
What do you think would look good for the handle??
You should be safe taking the edge down to half that thickness.
Thanks, gonna go do that now.
I have some 1/4 brass pins that im going to use, Should I drill the hole exactly 1/4 inch, or should I use a drill bit a little smaller?
I use 3/16 I drill out the hole with the drill press the 1/4 inch bit should be fine if your using 1/4 inch rod.  scuff it up with sand paper before you epoxy.  But that should work okay.  It should match up fine with your brass rod I would test it on a piece of mild steel first though just to make sure.
OKay thanks :)
On too my next question..lol
 Can O-1 produce a hamon??
I reeeeeeally like hamons and I want to try it out, I have some satanite i can use.
My experience is that a 1/4" hole will be just a smidge too small for 1/4" pin stock.  You could get a metric or a letter drill bit that is just a little larger than 0.250" or ream out the hole just a little with a burr on a rotary tool.  Same with other sizes of holes and pins of the same nominal size.
Nope. You need a shallow hardening steel such as 1075, 1095, W1/W2....
It's possible to create a diff. hardening line with deeper hardening steels like 1084, 52100 and 80CrV2 but you won't get anywhere near the activity of a shallow hardening steel.
O1 is just too deep hardening it will through harden even with clay on it.
Edited by Joël Mercier
I would think that O-1 is a little too hardenable to make a good hamon though you could see what you could produce with edge hardening.  Simpler steels like 1075, W1, or 1095 would make better hamons especially if they have a lower manganese content.
Okay, So ive read a bit on the forum about O-1 hardening, and i understand it will harden the most when its able to soak in the heat, but I have a coal forge and every minute the forge is on its getting hotter and hotter.
Since this is stock removal and this knife has never touched heat, do i still need to normalize it??
im not sure how to heat treat O-1 so i'm just going to normalize twice . (if needed) and quench.
Yes, do two or three normalizations, then quench.  That will take the place of soaking at heat.
Alright, thanks.
Is O-1 an oil hardening steel?
Yes it's an oil hardening steel. That what the O stands for and W1/W2 is a water quenching steel hence the W but we still quench in oil because it takes a water quench to harden thicker sections but with a thin knife oil should be fine.
Okay it’s been quenched. How long should I temper it for??
Im thinking. 2 cycles of 400 degrees for 1 hour. Good?
Hopefully you have tempered already, but yes, 400 is good.
Yeah I tempered it once last night and I’m about to do it again.
Finished tempering.
are you planning on forging out that tang a big more make it a bit smaller that is a lot of material for a full tang.
Nope, it’s already hardened. :)  Also the pictures exaggerate the size.
I’m not quite sure how to precede from here. Do I just sand until it’s sharp???
Is there a file that you can use on hardened steel???
That would be way faster than sanding
You'll have to use sand paper or stone. I think you were using a grinding stone before? Use really aggressive paper or the stone first to get to about the right thickness, then go through finer grits.
Alright thanks. Low grit sand paper is treacherous to my fingers.
Use a scrap of leather as a pad between the fingers and the paper.  It does a good job of keeping your fingerprints intact.
You'll probably want to use  a hard backer block rather than leather for much of your sanding so that the bevel stays nice and flat.  However, you can still hold that backer block with leather :)
Sanding blocks are going to be your best friend on this one Conner.  Get a block of wood and wrap or tape the sand paper to the block of wood and do it that way.
