Brian Dougherty Posted May 6, 2019 Author Share Posted May 6, 2019 I made a bit more progress this weekend. I got the blade and spring heat treated without any drama. I wasn't sure what to temper the spring to, but I decide to leave it at the same temper as the blade. (Both were tempered at 400F) I forgot to grind in a nail nick before heat treating, so now I'll have to do that the hard way. Here is a very exciting pic of the parts during the first temper cycle. The crud is what is left of the anti-scale compound. I didn't take any pics while I was adjusting the tip of the spring and the blade tang. To paraphrase Culver, you grind the spring tip back until the blade tip is just a bit lower than where you want it in the open position. Then you adjust the 'kick" and the back corners of the tang to adjust the closed and half-lock positions. Once all of that is roughly adjusted, it is time to drill the second spring hole in the liners thus setting the springs position forever. Culver suggests preloading the spring by 0.015" to 0.030". I went with 0.020". to do this, I clamped the spring in place with the blade open, and measured it's position from the bottom of the liner. Then I removed the blade, and re-clamped the spring in place 0.020" closer to the edge. Measuring the spring position: I goofed here a little. The neutral location of the spring in the half-locked position was actually about 0.010" closer to the edge than it was in the full open position. The result is that the half-locked position doesn't feel as positive. Here are a couple of shots showing the guts. The design has the blade contact the spring in only two points. The gap in the corner creates a space for pocket lint. Here is another goof-up: I just free hand ground the bevels in, and didn't scribe a center-line along the edge of the blade. The end result is I ground it off-center, and the tip isn't centered between the liners. Isn't keeping the blade centered in the liners supposed to be job one with a folder? Oh-well, live and learn... Here is a short video showing the opening and closing action. I'm pretty happy with the locks and the tension at this point. -Brian Link to comment Share on other sites More sharing options...
Gary Mulkey Posted May 6, 2019 Share Posted May 6, 2019 Brian, When you get the blade a little off center you can cheat a little if you want. Force the blade closed with some feeler gauges on the side which is the tightest to slightly bend the liners to compensate. It's not ideal but beats having an off center blade. 1 Gary ABS,CKCA,ABKA,KGA Link to comment Share on other sites More sharing options...
Brian Dougherty Posted May 6, 2019 Author Share Posted May 6, 2019 Thanks Gary. It looks like I can twist the entire assembly very slightly to to get it centered. At least I can flex it there with my hands. We'll see if I can get it to stay there -Brian Link to comment Share on other sites More sharing options...
Brian Dougherty Posted May 8, 2019 Author Share Posted May 8, 2019 I got the nail nick ground in this evening. I used a grinding stone with a dome shape in a little dremel router table. I thought putting the nail nick out towards the tip would be more practical as it gives you better leverage when opening. However, it looks kind of goofy there, so I'm wishing I centered it more. I also worked to center the blade up better in the liners. I used a pretty shady process for this. I clamped the blade to a straight bar, and then shimmed the tip over slightly and put the whole works back into the tempering oven. The bolsters are about twice as thick as I intend to leave them. but I'll mill or grind them down to thickness once I figure out the scale material. -Brian Link to comment Share on other sites More sharing options...
Gary Mulkey Posted May 8, 2019 Share Posted May 8, 2019 (edited) The blade looks much better. The position of the nail nick doesn't bother me. The sharp square edge of the blade at the front bolster area does. Some don't mind it. I have a "thing" about the sharp square corner being exposed. I like to see it covered by the front bolsters. Edited May 8, 2019 by Gary Mulkey 1 Gary ABS,CKCA,ABKA,KGA Link to comment Share on other sites More sharing options...
Brian Dougherty Posted May 9, 2019 Author Share Posted May 9, 2019 I agree about the exposed corner. Culver addresses this in his book. I copied a bit of it here so others can see the trade-off for covering up the joint. In the end I decided the exposed joint was my preference over the look of the open blade with a sunk joint. That is a very function follows form approach which isn't usually my nature. I believe this trade-off is one of the limitations with the slip joint design, but I haven't spent any time thinking about how to design around it. (I've pretty much just been blindly following Culver's pattern) 1 1 -Brian Link to comment Share on other sites More sharing options...
Joshua States Posted May 11, 2019 Share Posted May 11, 2019 Great progress. I would temper the spring a little softer. 500-600 for springs 1 “So I'm lightin' out for the territory, ahead of the scared and the weak and the mean spirited, because Aunt Sally is fixin’ to adopt me and civilize me, and I can't stand it. I've been there before.” The only bad experience is the one from which you learn nothing. Josh http://www.dosgatosdesignsllc.com/#! https://www.youtube.com/channel/UCdJMFMqnbLYqv965xd64vYg J.States Bladesmith | Facebook https://www.facebook.com/dos.gatos.71 https://www.etsy.com/shop/JStatesBladesmith Link to comment Share on other sites More sharing options...
Brian Dougherty Posted May 11, 2019 Author Share Posted May 11, 2019 (edited) 1 hour ago, Joshua States said: ... I would temper the spring a little softer. 500-600 for springs Thanks, I'll prob throw it back in for another cycle then. I couldn't find any reference on that. Edited May 11, 2019 by Brian Dougherty -Brian Link to comment Share on other sites More sharing options...
Brian Dougherty Posted May 11, 2019 Author Share Posted May 11, 2019 Today was a good day I decided to use a mill to thin down the bolsters. The original stock I used was 0.250" thick, which I knew was way too much, but I was worried 1/8" wasn't enough, and I didn't have anything in between. I ended up cutting them down to 0.150", but 1/8" would ahve been fine too. They are a much more appropriate size now... -Brian Link to comment Share on other sites More sharing options...
Brian Dougherty Posted May 12, 2019 Author Share Posted May 12, 2019 (edited) Next I thinned down some antler scales I had and roughly fitted them so I could epoxy them in place. I did chores for a few hours, until the epoxy cured, and then roughed off most of the excess material. Each liner has two holes for rivets to hold the scales on. I beveled the inside of the holes with a center drill to create a space for the rivet head. Then hammered a head into some 1/16" brass rod, cut it off a little longer than necessary... ...and peened it over. @Jerrod Miller your little anvils work well for this! The first couple were a little rough, but I got the hang of it by the end. Edited May 12, 2019 by Brian Dougherty 1 -Brian Link to comment Share on other sites More sharing options...
Brian Dougherty Posted May 12, 2019 Author Share Posted May 12, 2019 Then I spent some time filing and sanding the bolsters and scales to shape. I've got a little more shaping to do, but I've sanded through the side of my thumb, and got tired of bleeding all over the knife. This is where I'll stop for the night. 4 -Brian Link to comment Share on other sites More sharing options...
Gary LT Posted May 12, 2019 Share Posted May 12, 2019 My goodness, you are doing a jam up job with this Brian, my hats off to you!! I did a slip joint a few years ago, also saved S. Culver’s instructions via web but haven’t gone back to try another. Great job! Gary LT 1 "I Never Met A Knife I Didn't Like", (Will Rogers) Link to comment Share on other sites More sharing options...
Conner Michaux Posted May 12, 2019 Share Posted May 12, 2019 (edited) Reminds me of the case knives trapper. Looking good! This reminds me, I still need to decide if I’m going to do a fixed or a folder for KITH. Edited May 12, 2019 by Conner Michaux 1 Link to comment Share on other sites More sharing options...
Eric Morgan Posted May 12, 2019 Share Posted May 12, 2019 Dude that’s very nice! 1 Link to comment Share on other sites More sharing options...
Alan Longmire Posted May 12, 2019 Share Posted May 12, 2019 Impressive! 1 Link to comment Share on other sites More sharing options...
Alex Middleton Posted May 12, 2019 Share Posted May 12, 2019 Gorgeous Brian! I've really enjoyed watching this one come together. 1 Link to comment Share on other sites More sharing options...
Brian Dougherty Posted May 12, 2019 Author Share Posted May 12, 2019 I spent some time doing finish work today. This blade is quite a bit smaller than what I am used to making. It certainly takes less time to sand than a chef's knife. I still need to do some final sanding and polishing on the bolsters, but the parts are all getting pretty close. There is no way to create a perfectly smooth transition from the liners to the spring without sanding the back of the knife after final assembly. I wanted the pattern welded spring to be etched, so sanding after assembly is a no go. Even with all the pins as a perfect fit, there would most likely be enough of a ridge to catch a nail after final assembly which I find irritating so I decided to put a slight bevel along the back edges of the spring and the inside of the liners to create an intentional shadow line. I think it worked out pretty well. Here are a couple more shots. I need to get some 3/32" brass stock to make the final assembly pins. I also need to taper the main pin holes slightly so I can peen the main pin. 4 -Brian Link to comment Share on other sites More sharing options...
SteveShimanek Posted May 12, 2019 Share Posted May 12, 2019 That is a beauty, and an engineering marvel! 1 Link to comment Share on other sites More sharing options...
Gerhard Gerber Posted May 13, 2019 Share Posted May 13, 2019 Amazing Brian, one day when I'm all grown up I'll try that! 1 Link to comment Share on other sites More sharing options...
Brian Dougherty Posted May 17, 2019 Author Share Posted May 17, 2019 Ok guys, here is where those of you who know what you are doing get to shake your head at me. It's time to peen the final pins, and close this thing up for good. I decided to use nickle silver for the bolsters. However, the blade will pivot directly on the main pin on this knife, so I wanted to use a hardened steel dowel pin that would hold up well. This means that the pin will never truly disappear in the bolster as it is a different material and a different color. Since the pin will be visible, my strategy was to make the pin look as clean and uniform as possible. I started out by using a tapered reamer to lightly bevel the pin holes from the outside. This is a reamer made for tapered pin holes which has ~1-deg taper. This will allow the pin to swell into the bevel, and lock the pin in place. Here is a practice run I did in a piece of brass. It was promising, but there was a bit of mushrooming around the edge of the pin that I would have to overcome. I used a ma rker to blacken the inside of the holes so I could see how far I had run the reamer in. I left the innermost part of the hole the original diameter. Then I ground the pin to be 0.200" longer than the width between the bolsters, and beveled the ends so that the straight section was the width of the bolsters. I figured this would allow me to drive the center of the pin down and swell it out from the inside and avoid the mushrooming. I also tempered the ends to soften them while trying to leave the center hardened. I just used a torch, and ran the colors in toward the center. (Sorry Jerrod ) Here is the pin in place ready to be peened. This is where I started worrying about my hammer control. It felt wrong to start hammering on something I had spent so much time to make. 1 -Brian Link to comment Share on other sites More sharing options...
Brian Dougherty Posted May 17, 2019 Author Share Posted May 17, 2019 So out to the anvil I went (during a tornado warning no less). My test attempt taught me that my small ball-peen was not heavy enough really get the pin to start deforming, so I picked up my 2-lb smithing hammer and went to town. This was very much a death by 1000 small blows approach, and I found at first I could only hit it about 6 times before I would have to flip it over and hit the other side. Otherwise the pin would start to move away from center. However, once the pin started to lock in place I could rap on it a a hundred times or so before flipping it over. Here it is after a few minutes of hammering... ...and I managed to do this without marring up the bolsters too much. In the end, it really went pretty well. The action of the knife tightened up slightly, but not as much as I was afraid it would. I still need to do the finish sanding, but here is the pin all cleaned up. I had put the final brass pins in at this point as well. I'm getting close to finishing it up. I have to admit that I am going to have a hard time letting this one go. 2 -Brian Link to comment Share on other sites More sharing options...
Jerrod Miller Posted May 17, 2019 Share Posted May 17, 2019 25 minutes ago, Brian Dougherty said: Sorry Jerrod This did not go un-noticed. I'm judging you...harshly. This whole package is junk now. You'd better keep it for yourself, as it would be unfair to another smith to have this abomination forced upon them. 1 4 Link to comment Share on other sites More sharing options...
Alex Middleton Posted May 17, 2019 Share Posted May 17, 2019 Damn that's nice. I think I'd have a hard time parting with it as well. Thanks for taking us along on the journey for this one. A slipjoint is on my list, and I'm sure I'll be coming back to this thread for reference. 1 Link to comment Share on other sites More sharing options...
Bruno Posted May 17, 2019 Share Posted May 17, 2019 Man That Sure is nice. With the kith Date a mere 4 months away, I better get started. You are setting the bar High there. 1 Link to comment Share on other sites More sharing options...
Alan Longmire Posted May 17, 2019 Share Posted May 17, 2019 I need to start too, but I have learned not to use a gorgeous bit of stag for my scales. I would have a hard time letting it go too! I hope mine comes out at least a quarter as nice. 1 Link to comment Share on other sites More sharing options...
