Brian Dougherty Posted May 17, 2019 Author Share Posted May 17, 2019 40 minutes ago, Alan Longmire said: ... I have learned not to use a gorgeous bit of stag for my scales... It's not really a nice piece of stag. I bought some sambar for a project a couple of years ago, and the same place was selling dyed antler material that looked good on the website, and was a fraction of the cost. I bought some just to see what it looked like, and have had it sitting around for a while waiting for a chance to shine. -Brian Link to comment Share on other sites More sharing options...
Zeb Camper Posted May 17, 2019 Share Posted May 17, 2019 I want it! Top notch my man! 1 Link to comment Share on other sites More sharing options...
Gary LT Posted May 17, 2019 Share Posted May 17, 2019 Hi Brian, thank you for all of your tips in this construction. Especially like the pivot pin heat “temper softening” and beveling. I am looking for a 1 degree pin tapered reamer, where did to find yours? I also remember at a Batson symposium, hearing to make 1.5 turns only. Next question.....how did you peen the brass pins on the liners......the face side on the gnarly stag? Might assume a punch with a socket or indent? Thanks in advance, Gary LT "I Never Met A Knife I Didn't Like", (Will Rogers) Link to comment Share on other sites More sharing options...
Brian Dougherty Posted May 17, 2019 Author Share Posted May 17, 2019 Gary, I used a tapered pin reamer that I had. They are pretty common, and I am sure you can get them from McMaster Carr. In the US, tapered pins are a 1:48 (1" in 48") taper which I believe works out to just under 1-degree. In metric speaking countries, the tapers are actually 1:50 so it would be even shallower. I tried to stop about 1/2-way into the hole, but even with the drill press slowed way down it went quick, and I was quite a bit deeper than that. I used a nail setting punch on the brass pins. The dimple in the end of the nail set made it a little easier stay on the pin. It still required 3 hands to do, and I muffed it up a bit. I will go back and work on prettying up the pins before it is all done. I'm sure someone has figured out a better way to do them. -Brian Link to comment Share on other sites More sharing options...
Gary LT Posted May 19, 2019 Share Posted May 19, 2019 I appreciate you response Brian, thanks. I’ll check with them. Gary LT "I Never Met A Knife I Didn't Like", (Will Rogers) Link to comment Share on other sites More sharing options...
Joshua States Posted May 24, 2019 Share Posted May 24, 2019 That came out great Brian. Now I want to do another slip-joint. 1 “So I'm lightin' out for the territory, ahead of the scared and the weak and the mean spirited, because Aunt Sally is fixin’ to adopt me and civilize me, and I can't stand it. I've been there before.” The only bad experience is the one from which you learn nothing. Josh http://www.dosgatosdesignsllc.com/#! https://www.youtube.com/channel/UCdJMFMqnbLYqv965xd64vYg J.States Bladesmith | Facebook https://www.facebook.com/dos.gatos.71 https://www.etsy.com/shop/JStatesBladesmith Link to comment Share on other sites More sharing options...
Clifford Brewer Posted May 24, 2019 Share Posted May 24, 2019 Wow factor of extreme !! 1 If ya can't be good don't git caught !! People who say stuff can't be done need to git the hell outta the way of people who do stuff !!! Show me a man who is called an expert by his peers And I will show you a good man to listen to ...... Show me a man who calls himself an expert and I will show you an egotistical asshole...............!! Link to comment Share on other sites More sharing options...
Brian Dougherty Posted June 3, 2019 Author Share Posted June 3, 2019 OK, after a bit of touch-up and sharpening, I'm calling this one done. This is way too many photos, but I was playing with a different light box setup, and having fun. I'll probably carry this one around for a bit to see how it performs. Sorry to the eventual recipient, but it's too good of a data point to loose For the sake of posterity: Blade: 3" long made from 1095 and 15N20 Spring: Made from the same billet as the blade Liners: mild steel Scales: Dyed stag Bolsters: Nickel silver And the pics: -Brian Link to comment Share on other sites More sharing options...
Conner Michaux Posted June 3, 2019 Share Posted June 3, 2019 Very cool, very cool, I don’t think i would be able to let that one go.. good work! 1 Link to comment Share on other sites More sharing options...
Eric Morgan Posted June 3, 2019 Share Posted June 3, 2019 That’s about as amazing a pocket knife as I’ve ever seen sir. Beautiful work! 1 Link to comment Share on other sites More sharing options...
Gerhard Gerber Posted June 3, 2019 Share Posted June 3, 2019 Hi Brian Well done, I will be very proud if I can ever make something close to that. Apart from all the other challenges my attempts at restoring an old folder failed at the re-assembly point, do you use a jig of some kind? 1 Link to comment Share on other sites More sharing options...
Alex Middleton Posted June 3, 2019 Share Posted June 3, 2019 I don't know Brian. It looks like the blade is roughly .002" off center when it's closed. Seriously though, that is one hell of a knife. You should be proud of it. 1 Link to comment Share on other sites More sharing options...
Brian Dougherty Posted June 3, 2019 Author Share Posted June 3, 2019 Thanks everyone. I'm pretty chuffed at how it came out, but it's funny how much I overlook a the flaws on my first attempt at anything. If my next one doesn't come out much better, I'll be pretty sour. @Gerhard Gerber, I didn't have an assembly jig, but it seemed like it took 5 hand plus a helper monkey to hold everything when I peened the pins. That is one place that a jig would have been nice, but I'm not sure what it would look like since every knife is likely to be different. If I make many more of these, I'll build one of the fixtures to measure the total lift of the spring (slipjoint guys have a name for that fixture, but it escapes me), but using calipers works well enough for making one at a time. -Brian Link to comment Share on other sites More sharing options...
Gerhard Gerber Posted June 4, 2019 Share Posted June 4, 2019 15 hours ago, Brian Dougherty said: @Gerhard Gerber, I didn't have an assembly jig, but it seemed like it took 5 hand plus a helper monkey to hold everything when I peened the pins. That is one place that a jig would have been nice, but I'm not sure what it would look like since every knife is likely to be different. Yes, a job for the 5-handed knife maker! I've briefly seen an assembly jig during a GEC shop tour video on YT, and yes I would assume they have one for every model. They guy makes it look easy though..... Link to comment Share on other sites More sharing options...
