Quenching my first knife
Jeff Rangel
So this will be my first official quench but my question is, since this will be a quench at home using oil, what do I use to put the oil in so I can get it up to temp before the quench? I was thinking of using a ammo can as I have a few of them lying around. How would I go about getting the oil up to temp safely?
Thx
Ammo Can would be great.  Just make sure it water tight before you put oil into it.
I used to just heat up a piece of steel (usually a piece of rebar) in my forge at the same time I was heating the blade, and then quench it into the oil until it was temp I wanted.
http://www.krakenforge.net/
4 hours ago, Alex Middleton said:
Another option is a turkey fryer set real low.  Typically by the time I normalize and quench the oil temp is just about perfect.   Good luck!
That is a good idea!
Just remember that Liam Fuller on FiF burned his shop down not closely watching the turkey fryer he was using to heat his quench oil.
A hot piece of steel as Wes suggested, a small electric hot plate, a camping stove set on the lowest heat you can get, however you do it, keep an eye on it. Charles ain't kidding about burning the house down. Also, go to the nearest grocery store and get a nice meat thermometer to check the temp with.
  • 3 weeks later...
There is a bit of an issue with using an ammo can. A majority of them are not sealed enough and using some kind of compound isnt meant to be used under liquid for a long period of time. If anyone is interested I am picking this up:
https://www.ebay.com/itm/Knife-Blade-QUENCH-TANK-Heavy-Duty-Pro-Quality-2-Sizes-Available-blacksmith/303033148282?hash=item468e2ee37a:m:m812Wa47vfaXSki6TkcGBoA:sc:FedExHomeDelivery!78109!US!-1&frcectupt=true
