A tale of 6 blades.
So am I...…….:blink:
If any of our "newer" makers get anything out of this thread, I hope it is that things just don't go the way you plan, most of the time.
Any way, the best laid plans often go awry. The second side of that practice piece didn't turn out right. I am now very grateful that I had the foresight to create a practice piece. After that little slip that made a flat line in exactly the wrong location, I realized that I have a bunch of really good quality files, and it would be best to slow the process down and do things by hand. I also learned that it would be best to leave the profile shaping of the round ends into bishop hat shapes until later in the process.
So the real guard went back into the file jig and using a lathe file I cut the bevels. This went surprisingly quickly.
I sanded these flats down on the disc sander at 400 grit. I finished filing with an 8-inch mill file, so they were pretty smooth from the file.
I have to smooth out those ridges caused by the file stop. First I bevel the edges.
Then I went back to the 10 inch wheel at a very slow speed and blended the ridges down.
Then I shaped the ends. Now it's hand sanding time with some 400 grit paper! Yay!
I also used some very fine needle files to move the lines around.
Side 1
Side 2
There's a little more work to do on this and then I will sand the profiles and try and smooth out the visible bottoms of the curves and the ridges on the surfaces.
Preparing for the final assembly.
  • Like 7
5 of 6 are now done. One is on the injured/reserved list after a catastrophic bluing accident.
  • Like 7
Well, Josh, I can say I approve of the remaining 5!  Beautiful knives, one and all.
Chris
www.chrischristenberry.com
WHEW!!!  If I could only know now what I "thought" I knew back then....................
Tremendous effort Josh.
  • 3 months later...
For those of you who were wondering, there were two knives started in this thread that I finally finished.
The boot knife is a frame handle with .06" 416 vine file work around the entire handle, and 15N20 vine file work in the spacer.
The other one was what I call a "field knife" or a Hiker. Sort of a general use sheath knife. This is a take-down with Nickel-silver guard, nickel-silver and bronze spacer and pommel. This one is W2 from that Hunk O'Steel I bought from Ray Rybar back in 2016. Ironwood handle.
Crazy activity in the Hamon.
Love that fine filework on the spine Josh. A good pair of eyes and a steady hand would be a must.
Von Gruff
http://www.vongruffknives.com/
The ability to do comes with doing.
